RDLs not working
Soo, I have just gotten my hand on a Fabia MkII from 2014. Some things here and there that I want to change. However, the first thing is that I have noticed that my running daylights aren't working, and can't seem to figure it out.
I do have them in the bottom of the car, right beside the fog lights, but they aren't turning on.
Checked the fuses, not blown, checked the computer with VCDS, found them, cannot remember the byte right now, enabled them, no change.
After a while I found that there should be a switch at the fuses, don't have that!
Is it true that I may have the lights, but cannot use them as the switch isn't there??
The switch for DRL,s was deleted by 2014.
Well, that makes sense why it isn't physically there, even though the slot is there. Also looks to make sense why VCDS can see monitor that RDL is "not active" rather than "not installed" (the mid row)IMG_1730.jpeg
  • 2 months later...
@Evolution13
You have any more guesses? Still looking for the solution, and enabling DRL in the BCM in byte 23 bit 6, just error 31
Well, found out why now.
Seems the relay 484 is missing, together with the wiring... So I'll either have to find a wiring diagram, find the wires, install relay 484 or get it into a service workshop and pay for it.
Anyone got a wiring diagram for the DRL in Fabia II 5J ?
Switch Wiring Diagram  SKODA FABIA II 2013 - Daytime running lights switch - Fuse holder B
E1
Light switch
E579
J519
Onboard supply control unit
SB
Fuse holder B
SB17
Fuse 17 on fuse holder B
SB21
Fuse 21 on fuse holder B
T5f
5-pin connector
T17a
17-pin connector
T73a
73-pin connector
T73b
73-pin connector
  B554
Connection (fog light), in main wiring harness
Only models with daytime running lights
Wiring Diagram  SKODA FABIA II 2013 - Left daytime running light bulb - Right daytime running light bulb - Left static cornering light - Right static cornering light
J519
L174
L175
M51
M52
T73b
73-pin connector
  374
Earth connection 9, in main wiring harness
  379
Earth connection 14, in main wiring harness
Wiring Diagram  SKODA FABIA II 2013 - Steering angle sender - Dash panel insert
G85
J285
Control unit in dash panel insert
J519
K
Dash panel insert
K17
Fog light warning lamp
T32a
32-pin connector
T41a
41-pin connector
T73b
73-pin connector
  373
Earth connection 8, in main wiring harness
  B281
Positive connection 5 (15a) in main wiring harness
  B320
Positive connection 6 (30a) in main wiring harness
  B383
Connection 1 (powertrain CAN bus, high), in main wiring harness
  B390
Connection 1 (powertrain CAN bus, low), in main wiring harness
Edited by Jack25
The first is for the DRL switch
the second one is for the DRL bulb
the third is for the steering angle sender
If you want you can add the cornering function by making two differrent connections on the bcm (my fabia was already equipped whit DRL and switch so I've "retrofitted" the cornering function). like here: Corner funkcia (vozidlá od 2010-2015) – wirer.sk from @wirer
Edited by Jack25
5 minutes ago, Jack25 said:
The first is foe the DRL switch
See now we are talking.
But how does that match up with the comment from @Evolution13 about the switch to be removed from my model year? I don't understand why it should be that, just to still be installed if wanted to use
it's maybe based on the conutry if i remeber correctly for the UK market was mandatory to have the DRL always on while the ignitoin was on and headlight off, but I could be wrong because I'm from Italy and I've read something about that here on Briskoda time ago
Not mandatory in the UK to have DRL,s fitted as standard at the factory with Mk2 Fabia, or even Mk3 because there was no New Type Approval from the Regulation coming in February 2011. They do not need to be on with the ignition. PS, handy if posts / questions on the vehicles say which country they are in. Even just so that members might know if left or right hand drive.
Edited by Evolution13
