Actual v estimated mileage and charger anxiety
4 minutes ago, Stonekeeper said:
My problem with acc is that it acts like a "pursuit" way of driving and for me closer to the vehicle in front than I would be. I look at traffic as far as i can see and respond to that not just the car in front.
I agree that can be an issue. I always use the distance setting on top of the ACC lever to set the maximum distance.
I'm interested to know if that has an impact on mi/kWh? To me, I don't think so, but could be wrong!
Can I ask you. When using ACC on the motorway and you come to those occasional places where there are chevrons and signs saying "Keep two chevrons apart". Where is the car in front?
That's a good question that deserves an answer! I'll check when I next get the chance and report back.
Others may already know of course?
Cars too close together is one of the biggest reasons why cars come to a halt on the Motorway for apparently no reason.
Each following car has to brake harder eventually leading to stationary traffic.
I can slow down well before the car realises traffic is slowing down and I am less likely to be hit from behind
Indeed that is so and you are correct. However, I can always override the ACC by applying the brake myself if I see a need arising ahead of me. Similarly I can accelerate manually as well if I should need to. I, the driver am always the one in control and ACC is my servant merely helping me.
I see so many drivers that must be touching their brake pedal for no apparent reason as we are all going along nicely and they start a chain reaction. Must be the ACC affect....
Edited by Evolution13
Maybe. I had always put that down to being a nervous driver as I observed it long before ACC came into being.
I have as well for many years but now if is many hybrids, phev,s and EV,s. Especially TESLA,s.
@FrankL When i bought my enyaq 60 in Sept24 i logged the mileage and usage stats on here until I retired last September, it may give you some insight as to what to expect in the Winter.
I am glad I bought it in the Autumn because I saw the worst first.
My recent home charge to 100% gave a result of 100%/274 miles.
The miles seems to be creeping up.
I suspect this is a combination of the car intelligently monitoring my driving style (I'm now getting an average 3.9/4.0 mi/kWh) and perhaps the battery needs some time to settle down into my charging routine.
Anything else?
^^^^ That is the guesstimate for the ambient temp and your recent efficiency. Can you go 174 miles of further. or using 50% of the battery 137 miles and showing 137 miles range?
Rapidly approaching 80 I purchased my Elroq 60 as my first venture into EV driving. As another subscriber wrote, I was pleased to take delivery at the end of November 2025 as with winter on the way, I was getting my first experience in the worst part of the year. With nobody to give me any tips I think I was happy getting about 3.5 kWh. I have barely played with settings but have turned off air con and always get above 4 kWh but in this current heatwave I have on occasions have on 6-8 mile return journeys got home achieving 5 kWh. I must say that with the heads up display I love the prompt to lift off the gas and coast.
One concern I have had that didnt help with range anxiety was that a couple of times when on a long journey dropped below 20%, the 12v battery warning light illuminated. Is this normal and if so what is it trying to tell me about the 12v battery
Hi Dave. There is an amber battery warning light that comes on once the charge level is down to 20% but it isn’t for the 12 volt battery. It’s just to keep your attention drawn to the low state of charge. I’ve attached a photo with that lamp illuminated.
The 12v warning light is a red battery symbol just like the battery/alternator warning on a traditional petrol or diesel car.
If you’re sure it was the 12v lamp I’d get it checked as that would indicate a fault.
Edited by classic
Photo attach
With the Tesla's at least, a lot of those seemingly spurious brake indications will be regen braking when driver is backing-off the throttle.
With mine there is a "bing" and a message stating that i need to start looking for a charger, that quickly goes away leaving an icon with an orange battery symbol, this happens at 20%
3% 7 mile, you must have nerves of steel 🤣
I’ve got a better one with 1% 😎.
Yesterday 265 mile from Devon to Lancashire (I do not recognise GM because I was born before 1974) used 51.6kw = 5.1 miles/kwh. Details from the Skoda App.
Only 3% battery left and the warning symbol is still only yellow? 🤔 I haven't driven my fairly new Elroq to lower that 14% yet, but in my VW ID.3 with quite similar display, it turned red at 10%. And the one time I went below 5%, it was replaced with a red turtle. I was driving uphill, and it turned off the heat with -15C outside. 😨 Luckily I had only 2 minutes left to the charger.
It trusts me now !
Had a bit of a supprise on sunday morning after charging to 80%. The guessometer showing 356 miles! on my Elroq 85 edition. Did not see this level last summer. This is over more that 100 miles more compared with what was achieved during the winter'
^^^ That is good. 20*oC Ambient temp. 82 actual capacity minus 20% is 65.6 kWh. 356 miles divided by 65.6 = 5.4 miles a kWh. So if you can get 5.4 miles a kWh the Guessometer is spot on. Just a question of doing 350 miles and still having a few miles left and you will know.
This looks very unrealistic, isn't that more than you'd expect even from 100%? I wonder how you car arrived at this. My last drive was 8 km downhill with negative consumption (it told me -7.3 kWh per 100 km) and still it doesn't give a wild guess like this.
So I'm waiting for my elroq 85, I currently drive a 58kw id3, this has a simular range to the elroq 60, I have found the worst battery killers are
HEATING (by a long way) if driving long distance in winter and can stand it just turn on your steering wheel and seat heating with a window slightly open to prevent windows steaming up. And turn off your heating
SPEED drop your speed on motorways to 60 if poss makes a huge difference.
Doing this allows me to get over 220 plus in winter and another 20-30 when car was new
AIR CON has a much smaller effect on range in summer
I am easily hitting 4-5kw in summer and 4 in winter doing this. I always charge to 100% for long journeys and main battery is fine I've lost around 20 to 30 miles from new where I was exceeding stated max range.
This doesn't mean sitting in slow lane at 50mph but full heating at 70 kills range
On 27/05/2026 at 19:08, BoxerBoy said:
I’m interested in threads like this. Playing with arithmetic and Miles per kWh, etc.
My present Kodiaq has crept up to 21p per mile now that fuel prices have risen, so I will want next car to be cheaper.
Roll on Xmas time when I’ll have to make a choice for next vehicle to suit lead times for a custom spec vehicle.
I’m trying to tell myself to remove my “Skoda blinkers” and widen my options. But it’s difficult.
I haven't waited till Xmas. Elroq VRS ordered. Roll on April.
