Constant app updates
I’ve been having this issue for a few months now, constant updates for the store. I let it update, I get successful installed but it always reappears every single day
Anyone else have this?
Me too. For a couple of months now I've been getting about 2 updates per week.
Also had an update to 334 a couple of days ago.
334 being the main OS?
Dozens of reports on the Facebook groups. Skoda supposedly deploying an update to fix it.
Yes
Same on ours.
I've noticed a few times the infotainment takes a while to start up so I hoped it was loading an update. Only for the update message to reappear.
I've been getting this too, from posts elsewhere it would appear that a download is being rolled out in batches of VINs. Today I got the message and was driving the car long enough to actually get the download downloaded and then theres a message to install it which takes 20 mins,, after that theres a further message to install the Apps which can be done in the background.
I get this almost every time I get the car out, 'more info' tells you nothing and nothing happens if you select 'install', ps its a '23 Kamiq
Right now its also telling me it wants an oil change, back to Arnold Clarks then
Edited by johnnie47
add on
Yea I get this most days and it's been doing it for months on end now, Karoq 1.5 sel 20 model year.
I’ve never had my car update it’s main OS over the air
I believe this is just the Infotainment system software and not the software in the ECU which only Skoda dealers can update. For example the fix to ensure Kessy does not lock the car with the let’s inside could only be done by a dealer.
I’m meant the infotainment system
Well something of note has been downloaded to our 24 Reg SEL - one of my major gripes has been the brief ‘on screen’ warnings, one bong and no more than 2 seconds on screen - I had to be quick to see what the fuss was about - last night however I was treated to three bongs and five seconds or so on screen - sufficient time to actually read what was up, turned out to be the all too common ‘drive in the centre of the road’ warning…….
The car has updated, despite being in a concrete garage during the process, it informed me of the item being updated, job done, or so I thought until I started driving off up came that familiar message again, yes it wanted to do another update, I was driving so I didnt press update, neither did I press 'later', info was not available while driving, did the shopping but the update message has not, as yet, reappeared
Something has definitely happened in the last couple of days, apart from my above mention of the warning bongs/screen, all my personal settings have been reset, the two I noticed this a.m., the radio doesn't shut off when reversing and the rear wipe now does its thing every minute or so when the front ones are on - I'll have to go through the settings when I get a spare half hour.....?
How odd, the only affect the update had on my Karoq was to update the version number to 0334 from 0330 and it no longer gets the Update Available message.
Since then the car has successfully done the second update thanks to AI instruction to swipe down the screen from top to bottom and select 'notifications'
Something you guys might want to check.
Not sure if it was the result of the work a dealer did last week or a subsequent OTA update, but my instrument/infotainment lighting is now stuck on max, with the slider to adjust doing nothing. Makes driving at night problematic due to the high level of light beamed into the eye line. 🤬
My car has never updated its infotainment system over the air before
I raised these constant updates with Skoda UK yesterday, to be told today "Our technical team has previously applied a general solution to prevent the reappearing software update for all affected vehicles. As the notification about the update keeps appearing in your vehicle, we would like to additionally investigate this situation with our experts. Please provide a phot of the update notification in the Infotainment system for additional analysis. We apologize for the persistent technical difficulties and appreciate your understanding."
I've since sent photos of the first basic message asking me to update the software, and then ones describing what will get updated, and also one showing my car's software levels. Not sure what this will do though apart from confirm their fix hasn't worked on my Karoq!
When I had my recent problems I was told by the technical team that they have an update that would cure it. They would send the update to the local Skoda dealership who would install it for me. Only problem was that the dealership wanted £200+ to do the update.
Hi Ian,
Yes I'm just waiting for them to try that one on... But the fault must surely be a design/manufacturing fault not wear and tear? It's their update software that is faulty, and if they try to charge owners just because we are out of warranty we need to publicise their inadequacies I reckon.
@CJJE @ian-inhome what version. Hardware and Software do you currently have? Prior to the update I had Hardware H25 and Software 0330, after the update 0334. This is for Amundsen unit - Columbus has different hardware and software versions. Maybe the latest download only works with 0330.
@thamestrader My Amundsen hardware is H22, and software 0276! But my dealer told me at the last service that there were no updates required.
You could well be right that Skoda have forgotten about all the cars with early software levels as I also have problems with the map updates. Despite paying for the automatic map updates, the the map date is back in 2024 (although to be honest they seem accurate as I drive around.)
