Hesitation
Bought a 1.8T Octavia last week - Test drive was fine but since then occasionally I notice what seems like a flat spot on acceleration.
Usually in first gear between 1500-2000 revs the car seems to hesitate then go again.
Any ideas?
  • Replies 55
  • Views 5.8k
This is a common problem, loads of threads about this best bet is to do a search.
What gear is this most noticeable in?
You should't be giving the engine much throttle in that rev range anyway - your turbo wont be at boost and will labour.
What gear are you noticing this in?
Just read your post - first gear. Im a NUMPTY!
Should shift in first but being smooth applying the throtle can be quicker on these turbo engines.
It's when I pull away slowly that it does it - I don't want to banzai it from standing all the time to avoid the problem.
This morning, I had a possible related problem.
Started the car and pulled away, car bunny hopped slightly. Used the car's idle speed (ie no throttle) to run the car out of our junction and up to a main road.
Pulled across on-coming traffic and the car died but didn't stall. Revs hunted slightly below 1000 rpm. Pushing the throttle pedal had no affect at all.
Put my hazards on and kept pushing the throttle pedal - After 30 seconds the revs grew and I pulled away only for it to happen again. Repeated procedure as above and then it was fine??
I bought this car as a family car - If I'd have pulled across fast moving traffic I could have been in trouble - Not impressed :thumbdwn:
I'm expecting this to be sorted under the 12 month warranty I got with the car - Any idea's what it's likely to be?
As mentioned before, this has been covered 7 million times already. There's a sticky about it if you look right at the top of the page in this section of the forum.
Try starting the car up and leaving it for about 1-2 mins before driving anywhere. Then start your journey. I'm guessing you jump in your car, fire it up and drive off instantly first thing in the morning.
I start then wait for the revs to drop (1 minute), otherwise i pull off and get the same symtoms as you.
Worse on the colder mornings to.
I think this purely a trait of the engine, which no-one will ever get to the bottom of. It's just a case of letting the engine settle before setting off on your jounrney. Besides it's better for your engine if wait a little while to let fluids circulate a bit
I did look at the sticky, but that seemed more when the car was at speed in higher gears.
I was under the impression that letting your car idle wasn't better - That you should start it and go.
Maybe it is maybe it isn't, who's to say I must admit I always thought that. But if you want to "cure" your cold start splutter, follow my advice. Besides 1-2 mins ain't gonna hurt. I can understand if you turn it over then go back into the house for 15 mins like some people do :)
I must admit i just jump in and go on a morn and never have any probs,although i do drive steadily until warm.
So did all this happen in the first 1-2 mins when the secondary air pump was working or after that?
That on the odd ocassion when I have jmped in and driven off quick mine seems ok as well. A little flat perhaps but not as extreme as some people have mentioned
I thought both types of hesitation and lumpiness where in that one. Mine runs rough for about a minute when you first start the engine from cold, this is to do with some air pump. I think the other hesitation around 1500-1800rpm mark is mentioned in there too. I think there are quite a few possibilities to try to rememdy that one with. That thread does go on a bit, so it can be a little tricky to get staight at the answers you want!
I drive all car's with mechanical sympathy - My last car was an impreza which had a very heavy, juddery clutch from cold.
From this experience , I can understand a car being a little difficult to drive when cold, but the car just died on me halfway across a busy junction.
The throttle pedal felt like it had become disconnected - Didn't do anything for about 30 seconds.
Basically, yes.
I've had the hesitation between 1500 and 2000 revs when the car's warm though.
As I said before - I bought this as a family car - I don't want the risk of no power when I'm halfway across a busy junction with my family in the car...:mad:
Should I get the dealers to sort out the throttle body sensor or the whole body itself?
Will they pay?
did you get to the bottom of this as mine does the exact same.:thumbdwn:
I had what sounds like the same symptom with my vRS as did my friend with his vRS. I’ve had the car from new (03) and the problem started some time ago and just got progressively worse. It began when the engine was cold, first 40 second or so until the revs dropped, in the end I wouldn’t even attempt to drive the car for the first minute as it would ran like a b***h. Then I noticed some time after a running problem when the engine was hot, slight surge, flat spot or hesitation when feathering the throttle, this was more noticeable when picking up from slow down. To cut a long story short I did some research and had the throttle body cleaned just last week, this has cured both the hot and cold running problems and now I’m a happy bunny.
Same cure for my long-running hesitation/splutter problem. Local garage cleaned out the throttle body properly (unlike a previous garage who just SAID they'd done it!). Drives impeccably now:), can even drive comfortably with the secondary air pump running. I'd recommend giving this a go before replacing any expensive bits (dealer reckoned a new throttle body at £???!).
have read this thread and it sounds like the same sort of problem i have just started to get with my vrs! is it an easy job to clean it out or does it really need to go int o a specialist? ta:)
Neil it's VERY easy.
Took me about 15 minutes in total including taking it off, cleaning, putting it back on and re-alligning with vag-com :)
Order a new gasket from Skoda tho as it's wise to change.
It's really a case of just take off the throttle body (4 5mm allen screws), unplug the TPS, the breather pipe and air intake pipe.
Clean.
Re-fit + re-allign!
dont suppose you or anyone else has any pics? (am used to working on offroaders but the other half has asked me to have alook at this as it getting on her nerves!! got to keep her happy) ta very much
Sure bud, here's a pic.
White is the white is the throttle body.
Red is the little breather pipe that needs taking off, you'll need a 13-16mm jubiliee clip as the clip on there is a once use clip.
Yellow are the 4 5mm bolts.
You'll be able to see the connector on the bottom of the throttle body no problem when you're doing it. Have some gunk or carb cleaner handy to clean it out good. I put some foil over the intake just to make sure nothing fell in there too! :D
thanks for all your help mate:) will let you know how i get on:thumbup:
