MK1 vRS - Stage 2 R-Tech Tuned
Phil-W
Recommended Posts
Righty, service time today. Was under 10k since the last one but roughly a tad under 12 months. MOT is on Thursday so I thought it would be good to get fresh oil in the old girl.
Then I had the clever idea to do the oil pick-up pipe at the same time. I'm going to the Nurburgring in 2nd week of September so I wants to rule out any issues with blockages.
So, not particularly exciting pictures but here they are;
Pollen filter first, good job I did it as the air coming into the car was beginning to smell.
963043CE-5AB7-4318-996E-E71AA7691F34-341
Spark plugs, old ones all looked pretty evenly worn so happy days there;
503BA923-83BE-4C61-A064-98E653F4FE79-341
The fuel filter was done last year as well but thought it best to change it, new one will now only have V-Power etc run through it.
F2FF2E27-13FF-4CCE-8492-66618C1C76A3-341
Then it was time to get the sump off. Pickup pipe was actually not too bad, couple of little bits in the mesh but not as bad as some. Car is on 71k for reference.
4EEEFB77-4235-4884-B5B0-13CE66DDED4B-341
The sump was pretty minging so I gave that a good scrub up too;
2B2663F8-BFAD-476D-90B9-23ADAC0B2BF8-341
793F1598-C5D6-41F9-BAE1-5F9B72092F71-341
8F4D59B3-E399-4513-A21B-671E299A3A9C-341
Pickup pipes side by side, and new one fitted:
4A97E925-EDDD-43C3-90A4-3B89D8A5D723-341
0B9AB86E-A44D-4291-8D18-CD1A063E55C7-341
Filled it up with fresh oil and started her up. Went for a quick drive and parked back up to check the sump and disaster, a leak!
Tightened up the bolts a touch to see if that would work and it didn't. Luckily the leak was coming from a small gap so I squirted some more sealer in there, looks ok at the moment but ill keep watch over the next couple of days.
Job done for today, got fresh gearbox oil to go in but no 17mm hex bit so i need to get one.
Finally another daylight picture of the wrapped grill;
261B540A-572E-4F1B-B434-0DD8984D3C27-341
  • Like 1
Link to comment
Share on other sites
Ok, car had its MOT yesterday. The day before my pads sounded like they were dragging so I parked up and had a feel of the wheels. The OSR wheel was red hot. After trying some tips recommended on here, no amount of effort was going to work and I had a goosed caliper.
Knowing this, I sent it for MOT anyway as the retest was free and I could rectify any other faults highlighted, what I wasn't expecting was BOTH calipers to be binding. I had to order another caliper, and new discs and pads whilst I was there.
One caliper is here (TRW/Lucas with the Audi Symbol ground off!) so im waiting on the other bits to arrive so I can fit them and get the retest done.
ECD05A59-B778-41E6-8CB1-F369B55CBFBA-546
Link to comment
Fresh calipers, discs and pads fitted last week. No pics but it was a nice easy job, made use of my eezibleed as well.
Both rear calipers were seized, one more so than the other, have a guess which side was the worst??
A1B80C6D-7AB9-4E2D-B822-BFB29EAC7BA1-142
Link to comment
Yep it was the driver side. All new stuff is on and working fine however I'm not really using the handbrake at the moment, I want to buy the return springs to fit first.
Link to comment
Nothing much happening at the moment, I'm in the USA with work so the car is parked on the driveway gathering dust.
I have a new OSR door lock on the way from Oet (thanks!) as the current one doesn't want to unlock, luckily dead locks are not on though. I have also ordered a pack of stainless cable ties for the rear exhaust hanger (Y shaped one) as they have snapped for the second time, chaffing on the opening that was made so that needs smoothing.
Also had to send OSR tyre off for major repair as it picked up a nail on the outside section of the tyre.
Bought the above picture from the 'ring trip, too. Love it :)
  • Like 2
Link to comment
759F4F35-6387-403C-A9F3-249445B3A644-191
Not sure tbh
I think it looked better without all the tape over the back bumper, and the sticks attached to it :giggle:
  • Like 1
Link to comment
116F58D7-C94C-493A-9CAA-4203F76A23FB-223
55B2E329-60E5-490D-980F-52DE132D0434-223
Looks good I think. Isn't *quite* flush with the curve of the bumper underneath, plan is to bolt at either end and the middle and where there's a bit of an air gap underneath use washers as spacers. Must have moved a little bit as we propped it up!
Verdict and 42's are in. Slop has gone especially left to right, feels good changing gear, reasonably heavy but it feels quite 'weighted' now :)
Edited by Phil-W
  • Like 3
Link to comment
Well.. That's it now! I've considered my options on where to go next with the car and the answer is... No where. I've spent as much as I want to spend on the car now, aside from maintenance I've spent my lot on the Red Baron.
I'll be keeping her another 18 months or so and then changing/upgrading :)
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
