  2. I’ll have a look in the menu. Do you know which bit/byte in abs needs activating?
  3. Yesterday
  4. mistac posted a topic in Škoda Elroq
    Folks - just pulled the trigger on the above in Velvet Red (other than that standard spec) - currently driving a Karoq 1.5 DSG Sportline Edition. Due in approx December and will be my first EV - hoping I have made correct choice. Current and new Elroq purchased via PCP scheme and Ohme Home Pro included as part of PCP offer. Would be grateful for any owners views/comments!
  5. mistac started following Sportline 85
  6. JoeMK2VRS started following VRS steering rack
  7. Bit desperate for some help. The steering rack on my Skoda Fabia MK2 VRS has fully gone. Been told I need to find a replacement by the part number: 6R2423055J. But having an absolute mare in trying to find a reasonably priced one. Are there any other VAG cars that share it ? Or cheaper options in general? Cheers.
  8. JoeMK2VRS joined the community
  9. btrppl joined the community
  10. Had this exact problem. DPF is likely too far gone. Need to delete/clean/replace. With the amount of work involved in removing it, there's no way I'd be putting one back in.
  11. jaychen started following Constant DPF regen
  12. Knocked up a downpipe the past couple days in between jobs. Turned out ok. Is basically no louder than the factory setup while driving. 3" to the standard back half of the exhaust. [img] [img] [img] [img]
  13. Wieso die Druck teile, weil die 2Q0 Radar Steuergeräte deutlich kleiner sind als die 5Q0. Wenn diese vorhanden sind, wieso neue Halter kaufen? Gedruckte Adapter rein und dann Steuergeräte einsetzen. Why the printed parts? Because the 2Q0 radar control units are significantly smaller than the 5Q0 ones. If you already have them, why buy new brackets? Just use the printed adapters and then insert the control units.
  14. But you have to Set IT activ in the Car settings. Also Coding in the Abs
  15. Sunset a few nights ago..........
  16. I put a full set of Linglong Greenmax all season tyres on my Octavia, 205 55 16 91v, 7 months ago, so caught the tail end of last winter. They were decent on snow/ice/slush, good all year round. Although I don't drive to their limits often, I just wanted a tyre I could use all year round that felt safe. No they're not as good as Michelin tyres, but I've had those in the past, too. I paid £54 per corner for them, fitted. I drive an estate with 16" wheels fitted, so it suites my needs, don't need to drive it like a sports car. They are also wearing very well, as I've only lost 0.5mm from the front two over 5k driven, so far. I thought I'd give them a try, as I generally fit mid range tyres, not disappointed. If I still have my car by the time they hit 3mm, I'll replace all 4 with whatever I fancy, next. Probably all season tyres again, as they suit my needs.
  17. Hello does anyone know how i can unlock smart link or carplay in my 2017 skoda octavia MST2_EU_SK_ZR_P0369T multimedia version I heard that there are some solutions via SD card if someone can help me
  18. Goranche joined the community
  19. This might could be a model year difference, I ditched CarPlay because it wasn’t fully integrated with the steering wheel controls and the digital dash in my 2023 Sportline- but I understand in later cars 25/26, it is.
  20. GWW1990 joined the community
  21. AliExpress blind spot kit did not perform reliably enough. So that’s now been stripped out again. Front parking sensor retrofit now complete too. Full install details here: https://www.briskoda.net/forums/topic/541006-front-parking-sensor-retrofit-4k-to-8k-rhd-combi/
  22. waze is displayed via android auto. Works beautifully. Voice defined destinations too.
  23. Not just smooth but good body control by using advanced multilink suspension rather than torsion as oft used in B segment cars. Paired with low centre of gravity too. Much better than my first Renault 5 Campus of decades ago.
  24. Lee01 replied to Lee01's topic in Motoring News
    "An electric car approaching," says the license plate. But only in some countries - Škoda Storyboard https://share.google/cuTKt5b2hrPNIEdqE
  25. Mine is also booked in at National Windscreens. The online reviews are mixed to say the least! Hope I have a similar experience to yourself. Where is the manufacturer label on the windscreen? Some reviews I read indicated they don't use genuine parts. Thanks for the heads up. Will do.
  26. Does anyone have a map for this update?MOI3_EU_SK_R7880L_MU1788 It is currently This version is currently MOI3_EU_SK_R6680L_MU1668
  27. Renault has always had a reputation, along with Citroën for an excellent smooth ride.
  28. Nardo_44 joined the community
  29. Good to drive too with its suspension geomerty. 18 inch wheels bit big and I wish uk had the All Season option with 16s or 17s. Other than that ok for a 2 or 3 adult seater and 1 or 2 smallish kids.
  30. Is that a round crater I can see in one of the valves (images 3&4)? A lot of pitting on piston crown - I'd suspect that could lead to issues given the conditions during combustion.
  31. Thanks. Yes I don’t think I’ll try it out with a wall! Nice to know it’s there if it’s needed!
  32. Note, that Maneuver braking doesn't activate at very low speed und cuts off over a certain value. I can't remember the exact values, but just on the top of the head, I would say it activates from 3-5 km/h to 15km/h. 'Electronic systems gurus', feel free to correct me if these values are wrong. Otherwise, you can make some test with an empty cardboard box behind your car. It won't be risky. 😉
  33. On Kodiaq MK1 FL (TDI200 DQ381), coasting is also set in Normal mode. But I have to say coasting activation is quite smooth and I don't really notice it. Thus, it doesn't bother me when it's activated... I think, they've made progress in the geabox settings...
  34. This is what I would do. I already jumped the gun on the previous project and bought Passat B8 LEDs and a spare set of mirror housings to mount them in to. Will need cutting and gluing but a significantly cheaper option than the pre-made ones on AliExpress, or OEM.
