01276 ABS Pump
Thanks @Alasdair1 for the quick reply. I checked the fuses, they all look fine. Did the voltage test too. No signs of wear and tear on them. I did an output test today with my obdeleven, I could hear the pump humming and it was vibrating when I touched and felt it. Could it be a jammed pump? I tried the loose gravel breaking again but it is still there. I found some on my the marketplace for a 50, do I try it? My only concern is the bleeding, I don't want to deal with it now, I'd rather give it to a mechanic to fit it.
- Skoda Yeti Head unit clock 00:00
Skoda Service Plan - paying for spark plugs
Hi. Interested to know how this ended... thanks
longbloke started following Access to erwin Skoda , Skoda Service Plan - paying for spark plugs , First Service Cost and 3 others
First Service Cost
What kind of things are included for free as part of the plan? Spark plugs, filters oil? Thanks!
Hi
Just joined from UK - thanks for having me. Not a Skoda owner yet but hope hope to be soon and getting lots of useful info here Cheers
Advice on an Octavia I'm on the edge of going for
Thanks. Definitely feeling risk averse after the experience so trying to learn lots fast. Definitely keen on the Octavia though
It's a great choice. Coming from a focus as well with the wet belt. It's been a dream to drive even at 119k. I replaced timing belt, aux belt and gear box service a couple of weeks after picking it up. Hopefully keeps me going for a while
I'm looking at Octavias now after our Ford Focus Ecoboost did what they do and never drove again
I did yes
General feedback re: mk3 octavia 1.0tsi vs 1.5tsi
Can't help answer your question I'm afraid, but interested as I'm having similar thoughts on whether to buy 1.0 or 1.5 used octavia. What did you decide in the end and has it worked out? Anyone else have advice? Thanks
Skoda superb sportive estate 2023 suspension to soft
Good evening. Its a hatchback. I have no modified that suspension height at all its all standard. It amazes me how the suspension is soo soft as standard. Never had this issue on any car I've had hence why I thought it to be an issue with a fault somewhere. Do I also need springs aswell?
@fishsoup did you buy the car in the end?
- Access to erwin Skoda
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
longbloke started following Skoda Octavia Mk3 (2013 - 2020)
longbloke joined the community
Handbrake button came off
Had the same issue August 2026, ordered new button from skoda parts direct £20 (now asking £40 ?). Dealer wanted £44, so aware of problem and said they had not had to replace whole hand brake only replace button. I had read all posts, so not sure new button would work, but knew to pull control rod out to get ratchet to work. Guess what, yep failed, on a hill in the dark in slow moving traffic Sept 2026. Did not actually see button go when released the hand brake, doing multiple stop and move on, up hill. Reached down to pull brake and felt no button (dont press on pulling). I pulled the control rod out and pulled the handbrake at same time. Wife put hazards on for me and we had to let traffic pass, before trying to move off. Reported as safety issue to central skoda, clearly other manufacturers recalled on similar issue e.g VW T5. Dealer charged £115 investigation fee for known issue, plus £440 (£249 + vat for whole hand brake) to fix, two bits of plastic failing. Skoda parts, which is Skoda, £191, but dealer has to use TPS. Like other gent, needed car fixed quickly. I've raised safety issue with DVSC. All need to do this. Some customers get lucky with new button. But it's an un safe design. We found button and spring in back of car. Dealer said car was unroad worthy...so clearly unsafe. I would have gone small claims, but apparently got to go ombudsmen, they have it sawn up, apparently its dealer not manufacture if wear and tear, but it's a issue with the design in my mind. oh and I've done less that 58k...so less than original warranty distance. Rant over ....did buy gorilla glue ...should have used.
pijhol started following Handbrake button came off
Real exhaust tips for Kodiak MK2 Sportline
How much did it cost?
peshetoman started following Real exhaust tips for Kodiak MK2 Sportline
Assistance services suddenly become unavailable during journey
Thatās interesting. I recently posted an account of my car performing a sudden emergency stop while travelling at 70mph in the centre lane of the M20. It braked hard, locked the steering, came to a full stop and turned off the engine. I hadnāt given it much thought until you mentioned it but the common factor with your incident is that I too had the drowsy/take a break message just a few minutes before my incident. I wonder if itās related š§ As a result of my incident I sold the Superb as I felt we had had a lucky escape, might not be so lucky next time. Picked up my new car this morningā¦
Advice on update 0334
Thank you for the replies. I have tried doing a factory reset 3 times without success. I have also tried removing the fuses that feed the unit and also the ones that feed the SIM/sos unit without success. I think that it is somehow linked to the account settings. I have tried deleting that account and setting up a new account on the app which appears to go through successfully and I get a welcome message. If I enter those new details in to the unit it just comes up with incorrect password even though the app says that the new password is correct. According to the screen when you delete a user account that existing user get a message to tell them that their account has been cancelled. I have never received any email saying that the account was cancelled, even though the new account that I tried setting up was with a completely different email address.
pijhol joined the community
Rabiega95 joined the community
Sunroof leak ....another.
I bought a 2019 Skoda Karoq scout DSG 4x4 last year and all has been well up until about a week ago. I noticed my passenger side footwell was wet and upon closer inspection i found my carpet completely soaked .I cleaned both front drain tubes with a long wire and both are clear. I then researched the problem online and it seems to be a well known problem within the VAG group of cars. I think that its shocking that this hasnt been put out as a recall on what is basically crap engineering. The drain tubes for the panoramic roof as simply placed onto the sunroof cassette with no means of securing them in place. The tube goes down the door pillar to connect into a small rubber grommet ( push fit also ) in the firewall behind the dash. The grommet drains out into the area where the wiper motor sits. Seems the actual drain pipe shrinks over time and pops out of the fitting either at the top or the the bottom of the hose. I have phoned various skoda dealers and ive been told i need to book it in for investigation even though i know where the fault is?? they asking for a 4 hours investigation fee as £100 an hour. The id need to pay what they ask for in repair costs. Plus most skoda dealerships seem to be booked up into oct/nov This will be my last car with a sunroof. Id fix it myself but the job looks a bit tricky ..
Advice for buying a 2018 Karoq 2.0 TDI Edition DSG
What is the reason for choosing diesel & 4x4? What will your usage look like in terms of weekly usage? As @thamestrader has already alluded to, an elderly diesel with questionable usage could have all manner of issues just waiting to bit you on the *rse. Also note that the car will be too old to take Skoda's All-in service/warranty when the initial warranty has expired. There's quite a lot of relatively common faults like door locks, electric boot struts, leaking sunroof (if it hasn't been well maintained), fuel flaps, etc. together with the DSG & 4 x 4 system that you ideally would want covered. 19" wheels are prone to damage & many find the ride too compromised on the low profile tyres.
Out of interest, what were the weather conditions at the time? I've found that the sensors/cameras which provide the input to all the 'assist' systems are far more susceptible than they ought to be to moisture, condensation, etc.
New old Scout owner, just joined...
Hi there - bought a 2015 Skoda Octavia Scout last week. Love it so far but am aware there are things I also need to be aware of, so came across here to join up!
scoutista joined the community
Mk 2 Octavia - door strap replacement
The rivets are N 91078801 and are 6.4 x 10mm. I got a two handed rivet gun to do my sons when the regulator totaled itself. Got them on ebay for around £10 for 10. Put part number into search and a few should ping up. Make sure your not paying a fortune for just one rivet! Alasdair
