Sportline 85
Folks - just pulled the trigger on the above in Velvet Red - currently driving a Karoq 1.5 DSG Sportline Edition. Due in approx December and will be my first EV - hoping I have made correct choice. Current and new Elroq purchased via PCP scheme and Ohme Home Pro included as part of PCP offer. Would be grateful for any owners views/comments!
mistac started following Sportline 85
JoeMK2VRS started following VRS steering rack
VRS steering rack
Bit desperate for some help. The steering rack on my Skoda Fabia MK2 VRS has fully gone. Been told I need to find a replacement by the part number: 6R2423055J. But having an absolute mare in trying to find a reasonably priced one. Are there any other VAG cars that share it ? Or cheaper options in general? Cheers.
JoeMK2VRS joined the community
btrppl joined the community
Constant DPF regen
Had this exact problem. DPF is likely too far gone. Need to delete/clean/replace. With the amount of work involved in removing it, there's no way I'd be putting one back in.
jaychen started following Constant DPF regen
Custom CUPA downpipe
Knocked up a downpipe the past couple days in between jobs. Turned out ok. Is basically no louder than the factory setup while driving. 3" to the standard back half of the exhaust. [img] [img] [img] [img]
Wieso die Druck teile, weil die 2Q0 Radar Steuergeräte deutlich kleiner sind als die 5Q0. Wenn diese vorhanden sind, wieso neue Halter kaufen? Gedruckte Adapter rein und dann Steuergeräte einsetzen. Why the printed parts? Because the 2Q0 radar control units are significantly smaller than the 5Q0 ones. If you already have them, why buy new brackets? Just use the printed adapters and then insert the control units.
Amundsen MIB2 Firmware Update
Part number of the unit?
Front park assist retrofit help required!
But you have to Set IT activ in the Car settings. Also Coding in the Abs
Photography Thread
Wheels and Tyres
I put a full set of Linglong Greenmax all season tyres on my Octavia, 205 55 16 91v, 7 months ago, so caught the tail end of last winter. They were decent on snow/ice/slush, good all year round. Although I don't drive to their limits often, I just wanted a tyre I could use all year round that felt safe. No they're not as good as Michelin tyres, but I've had those in the past, too. I paid £54 per corner for them, fitted. I drive an estate with 16" wheels fitted, so it suites my needs, don't need to drive it like a sports car. They are also wearing very well, as I've only lost 0.5mm from the front two over 5k driven, so far. I thought I'd give them a try, as I generally fit mid range tyres, not disappointed. If I still have my car by the time they hit 3mm, I'll replace all 4 with whatever I fancy, next. Probably all season tyres again, as they suit my needs.
Hello does anyone know how i can unlock smart link or carplay in my 2017 skoda octavia MST2_EU_SK_ZR_P0369T multimedia version I heard that there are some solutions via SD card if someone can help me
Goranche started following Amundsen MIB2 Firmware Update
Goranche joined the community
waze direction arrow incorrectly displays on centre consol
This might could be a model year difference, I ditched CarPlay because it wasn’t fully integrated with the steering wheel controls and the digital dash in my 2023 Sportline- but I understand in later cars 25/26, it is.
thamestrader started following waze direction arrow incorrectly displays on centre consol
GWW1990 joined the community
AliExpress blind spot kit did not perform reliably enough. So that’s now been stripped out again. Front parking sensor retrofit now complete too. Full install details here: https://www.briskoda.net/forums/topic/541006-front-parking-sensor-retrofit-4k-to-8k-rhd-combi/
waze is displayed via android auto. Works beautifully. Voice defined destinations too.
the truth about electric cars
Not just smooth but good body control by using advanced multilink suspension rather than torsion as oft used in B segment cars. Paired with low centre of gravity too. Much better than my first Renault 5 Campus of decades ago.
Skoda News
"An electric car approaching," says the license plate. But only in some countries - Škoda Storyboard https://share.google/cuTKt5b2hrPNIEdqE
New windscreen
Mine is also booked in at National Windscreens. The online reviews are mixed to say the least! Hope I have a similar experience to yourself. Where is the manufacturer label on the windscreen? Some reviews I read indicated they don't use genuine parts. Thanks for the heads up. Will do.
Nardo_44 started following MOI3_EU_SK_R7880L_MU1788
Does anyone have a map for this update?MOI3_EU_SK_R7880L_MU1788 It is currently This version is currently MOI3_EU_SK_R6680L_MU1668
Renault has always had a reputation, along with Citroën for an excellent smooth ride.
Nardo_44 joined the community
Good to drive too with its suspension geomerty. 18 inch wheels bit big and I wish uk had the All Season option with 16s or 17s. Other than that ok for a 2 or 3 adult seater and 1 or 2 smallish kids.
Broken spark plug - ruined engine? 1.4TSI CZCA
Is that a round crater I can see in one of the valves (images 3&4)? A lot of pitting on piston crown - I'd suspect that could lead to issues given the conditions during combustion.
Thanks. Yes I don’t think I’ll try it out with a wall! Nice to know it’s there if it’s needed!
Note, that Maneuver braking doesn't activate at very low speed und cuts off over a certain value. I can't remember the exact values, but just on the top of the head, I would say it activates from 3-5 km/h to 15km/h. 'Electronic systems gurus', feel free to correct me if these values are wrong. Otherwise, you can make some test with an empty cardboard box behind your car. It won't be risky. 😉
Coasting
On Kodiaq MK1 FL (TDI200 DQ381), coasting is also set in Normal mode. But I have to say coasting activation is quite smooth and I don't really notice it. Thus, it doesn't bother me when it's activated... I think, they've made progress in the geabox settings...
This is what I would do. I already jumped the gun on the previous project and bought Passat B8 LEDs and a spare set of mirror housings to mount them in to. Will need cutting and gluing but a significantly cheaper option than the pre-made ones on AliExpress, or OEM.
Hi, @Binx1310 Just sharing my humble experience. I used to have BSD LEDs in the mirror glasses on my ex Superb Mk3, but I way more prefer the BSD LEDs in the mirror housings on my current Kodiaq Mk1. Additionally, you can trim the LEDs intensity from the MMI (assuming you get OEM parts and correct coding). Much safer!
