Everything posted by TMB
Battery sensor wire routing?
Great work guys!
Remote Central Locking Only Working Inside Vehicle
But your eyes blinked three times and you made bleeping noises.
Try another battery. Even though you've changed it, it might be faulty.
- Engine oil
Engine oil
I knew a guy who had an OHC Mk3 Cortina, and he filled the sump with something called Genklene, which is a solvent for cleaning parts. He started the engine and it made a horrible noise and buggered the camshaft. Daft bugger
Loose gear stick after something snapped
^ Thanks. Mine doesn't have that plastic bit....
That doesn't look like part of the shifter mechanism to me. Where does it fit exactly?
AnnoyingPentium's 2006 Fabia 1.2 12v Ambiente-ish
^ Cool
Seats looking nice, Ryan! 🙂 Did all the bolts come out ok?
Water under floor carpet. Found unplugged holes underneath.
No problem 🙂 I bought some off ebay but they came from Lithuania.
Yes, there should be 40mm bungs in those holes. Part number 1K0 899 185
Skoda Fabia dash cluster
Be aware that the cluster contains the immobiliser and you can't just swap in a used cluster without having it coded to the car.
Mk1 Fabia rear hub bolt size?
Item 4 here?.... https://skoda.7zap.com/en/cz/fabia/fab/2004-225/5/500-500020/#4
Bought a 2004 MK1 with no service book, need advice.
You need to remove the drums to inspect the brake shoes, cylinders & drum friction surfaces. The rust on the drums is normal, you could clean them up a bit with a wire brush.
CV Boot Dumb Question
I made the washer myself 🙂
Well done I have this CV joint puller...
Those front discs are well past their best. Can't see anything with the drum brakes as the drums are still on.
Yeah, that rust on the wishbones is entirely normal. Most cars look like that underneath unless they are pretty new. As for the drop links - it's often difficult to feel any wear in them on the car. Best just renew them as they are a common failure and cause of knocks.
Skoda Fabia MK1 Pop and Bang?
Put some Rice Krispies in the tank and it will go snap, crackle and pop 😛
My MK2 Fiesta didn't have one from the factory and it was like a wet sponge round corners
I can strongly recommend Meyle HD drop links. They are even better than the factory ones. Part number: Meyle 1160600000/HD
Glove box: took it off now can't get it back on. :)
No, it just has screws. If the screws won't bite it's possible that one or two of the speed nuts has fallen off. Starting at 6:20.....
Might be an idea to check/change the cabin filter too.
Which engine?
Recent pics of your fabia for no reason, just stick em up!
Next-door letting me use their drive whilst we get new facias and guttering installed.
