Everything posted by JohnMack
- 1.2 tsi cracked vacuum lines causing engine to hesitate ?
I don't believe there is not a demand for manual cars.
Easier...without doubt. More enjoyable ?..... I enjoy deciding when I change gear. Like you say, cost will be less for servicing. Personally, I enjoy driving therefore I enjoy having total control .
2010 Fabia 1.6tdi Elegance Estate - From no MOT purchase to smart modded Daily Driver!
Ah, I see. Mine are wool carpet off-cuts. Your Fabia is worth better than TEMU !! Liking your progress, it's sitting nice. That spring kit was a good buy. 👍
The mats brighten a slightly dull interior I think. Have similar carpet cut offs in one of my cars....I love them.......lets embrace floral off cuts !😆
Israeli Yeti
I'd put money on that starting and driving !
SOLD - Skoda Octavia MK1 1.9 TDI Elegance VRS Style | 13Yrs Owned | S3 Recaros
Having recently sold on a slightly newer VRS tdi with slightly more miles, I know what it takes to keep them looking good and mechanically tip-top. However your older car looks in better condition than what ours was. It's clear to me you know how to look after a car. Good luck in your new home 👍
That's a nice looking wagon, great advert too. Good luck with sale 👍
- Gear oil change- 2019 mk3 Octavia VRS petrol 6 speed manual box
01/2017 VRS estate tdi rear shocks
Let us know what you think of the Meyle shockers 👍
Octavia vrs limited edition mk2 pre facelift
I'd say it's on the money if maybe a bit cheap compared to other stuff for the same money. Good cars 👍
Rear suspension arm lower bolts - Spring replacement
Sorry can't help on the part numbers, easy enough job though. Done this on our old VRS, I just used a trolley jack under the arm to release the spring tension...wasn't much tension. I never replaced the bolts either and had it in bits a few times, if you're mechanically minded and not a monkey then reusing these bolts isn't a problem.
Octavia 2016 belt or chain?
Belt.
OCTAVIA MK II. - 1.6 BSE engine won't start
How long is a long time ?!! Have you removed the old fuel and added fresh fuel?
Scala brake fluid change
If the job's done correctly, yes the fluid should be bled from the clutch slave cylinder as well as the calipers .
Octavia 3 Front Brake Pad Plate Removal
A pair of tin snips will help 👍
Front wipers have stopped working
I'd check the linkage hasn't seized up first, take the nut off the motor spindle to free the arm, then check that you can move the wiper arms by hand.
Octavia Alternator Removal
Sounds like keeping an eye on it is the thing to do.
If alternator cable is hot and you suspect a high resistance due to corrosion then you could maybe just disconnect at the alternator and at the "big" fuse and fit a new cable between the two?.......just leave the old cable in place and fit the new cable in a route to your liking ?...until the weather gets better!! You mention a "scanner" would be helpful, as far as I know your mk1 Octavia doesn't have a control unit as such for the charging system, it's control unit is the regulator. Regards a "specific resistance", resistance isn't really worth checking as it's done with the engine switched off....... checking voltage drop under load IS worth doing. Have you considered bypassing the big fuse and just hard-wiring the alternator cable to the battery terminal?....the more connectors then the greater chance of resistance?
Skoda Kodiaq Haldex Service
If it's to the correct VW spec. then it should be ok.......or just get it from the dealer then there's no doubt ?
?Faulty oil level sensor 1.9 tdi pd
What a great post As an old school kinda guy, and of the thinking that a car is a mechanical device to get from A to B whilst enjoying the fact you've looked after and serviced said car and not just bought(rented?) a computer on wheels to keep up with the neighbours ...... You gotta love an old diesel !! 👍 Glad it was just a senior glitch 😉
Digital service record
I've done the same, any self respected honest garage will have no problem stamping the book and noting what work has been done.
Turbo lifespan (buying my first Skoda)
We've just done what you're thinking of doing, bought a 2018 VRS tdi with 100k miles to replace the 270k miles VRS we'd used for 10 years(original turbo, injectors, DPF, clutch!, starter, alternator).....it was 6 years old with 118k on it when purchased. They're great cars in my opinion although it seams(as suggested above) the newer ones do have a tendency to sip oil, maybe due to servicing or lack of ? The heater matrix can become blocked due to the silica bag in the expansion tank bursting, so check the heater works and consider replacing the tank if you get the car. I'd personally go with a manual gear box although many folks love the DSG which could be costly should it malfunction. All the best whatever decision you make.
Contact Haldex Repairs, they'll confirm . It's not in their interest to sell you the wrong parts. 👍
