Škoda Felicia OBD port
I have somewhere in a mail extra rules, are not those of the link, they send them to me just after register. I have an account but no posts, i don't like all these rules and still all these years no Felicia members. Coincidence? No applications as others models have, even in indicators have no titles ! I have post some pictures, if feel they cheat me i have an almost useless OBD reader, i see indications but i don't know what are they so to do what with them?
No applications available for felicia. they have a forum https://forum.obdeleven.com/board/6/koda but i read the rules they are so strictly that almost forbid a member to ask something that in the past some other member mention. https://forum.obdeleven.com/board/50/felicia So the result of this foolish Moderation attitude is no one has ever been open a thread.
Yes. https://www.briskoda.net/forums/topic/492909-obdeleven-diagnostics/#findComment-5537183 https://www.briskoda.net/forums/topic/515077-which-obd/ https://www.briskoda.net/forums/topic/524233-obd-reader/page/2/#findComment-5860748 With my photos ''in action". https://www.briskoda.net/forums/topic/524233-obd-reader/page/2/#findComment-5876506
Škoda Favorit tachometer going crazy
In Felicia the speedometer wire has a square nose which goes 1cm inside the teflon plastic socket and the 2 ''ears'' they ''click'' and hold it place. is the nose comes out for a reason you hear a characteristic ''Tzzzz'' sound as it bounches. In Favorit is like this https://www.ekodiely.sk/galeria/produkty/max/2022/07/20/38792204178-1658301702.jpg more robust connection. https://scdn.autodoc.de/catalog/categories/600x600/10661.png At tachometer https://media.pazar3.mk/Image/727ff982-5a49-4920-a626-fdfef011e110/20210805/false/False/1280/1024/skoda-favorite.jpeg?noLogo=true the suddenly prm jump from 2500 to 8000 (it's the limit) means gauge proplem or possible connection (plug) issue.
Some modern OBDII scanners they don't support the Felicia's ISO14230 (KWP2000) protocol which uses for communication between ECU,sensors and OBD socket. Here is one that i tested and never-ever worked because is an OBD II and we have OBDI (or plain OBD). Also those cheap Chinese also they do not work! So @DemoVrh is the connections are the proper but the scanner does not work, you can not do anything about it. I paid for 2 and lost money and time-effort, the OBD11 works (but has no fancy gauges on your smartphone) and the VCDS via laptop.
Immobiliser intermittent fault?
The cost for a copy here in GR is about 25€.
Not common, if the immobiliser is ''on the way to grave'' you would have problem with the 2nd key also. The solution is to go to a well-known locksmith which works with cars, will reprogramme the old or in worst case based on the 2nd will make you a new one. By the way have you ever changed the battery in the first (the ''old'') key?
Škoda Auto Area served Worldwide (except Japan, US and Canada)
I have and OBD11 device just for simple scanning and code erasing, i am not car-electrician but @Thefeliciahacker has a VCDS programme and more experience on this matter.
More pictures and text here https://skoda-virt.cz/cz/clanky/elektrika/8248-bmm-spi-felicia-1-3-to-s105-rapid/?gotopost=3325708
This is helpful? https://www.briskoda.net/forums/topic/515068-code-readerscanner/#findComment-5772995
Koni Special Active Shock Absorbers
KONI Shock Absorber Repair For service, repair and restoration of Koni road and race dampers. https://www.koniuk.co.uk/service-repair/
Skoda Felicia hood scoop?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI put a piece of electrical tape (upside down) to see if i close the hood then the activated carbon cabin filter will contact firmly with the oval shape rubber seal? The yellow mark shows the exactly point that i put that tape, i close the hood and yes, the tape stuck to the sheet so no gap, things are OK. 👍
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFor 15 euro per unit i can make at least 8 "sheets" so this filter will last 4 years if i use 2 of them per year. The "seal test" was successful, more in a future post with photos.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI took that activated carbon cabin filter and disassembled it, measure and cut it. creating a ''sheet'' which i put it via adhesive tape beneath the factory hood oval shape hole thus ''filtering'' the incoming air before goes to the cabin. For sure this patent can not compared with a factory cabin filter but it's better than nothing and far better than the sponge-solution that i had. What's next? A sealing test and a real-condition air flow test (since i don't have the proper equipment to do more experiments).
- Felicia battery turns back on again after turning ignition off
Felicia Combi 1.3 - what oil?
Motul Specific 0101 10W-50 110282 VOLKSWAGENDensity at 20°C 0.854 Viscosity at 40°C 121.3 Viscosity at 100°C 17.8 HTHS viscosity at 150°C 4.6 Viscosity Index 163.0 Flash point 244.0 °C Pour point -45.0 °C / -49.0 °C Q8 Formula F1 10W-50Pour point -33°C Flash point 210°C Viscosity at 40°C 119 Viscosity at 100°C 17.6 Density 0.86 g/cm³ at 15°C
I have use in the past Amsoil, excellent product. Red Line were and are far the more expensive engine oils in the GR market, for example 1 bottle of 10W-40 (basically is 946 ml) costs 25,00 € so the cost for 5 of them is 125 € plus the oil filter plus the work from the mechanic and the cost for an oil change is skyrocket.
Koni Street rebuild.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHave i posted this in the past? I can't remember. https://www.zimmerframeracing.com/koni_shocks/index.htm Koni rebuild in a BMW motorcycle. Another happy Koni user.
I have different car than yours but i have Koni shock absorbers installed for many years. Rebuilt them in 2023 https://www.briskoda.net/forums/topic/519830-koni-street-rebuilt/ with original Koni parts plus one year warranty, always happy with their perofmane.
Yes i do, now only 20W-50 and 0W-20 can be found here https://www.skroutz.gr/c/1228/Ladia-Autokinhtou/m/22964/Millers-Oils.html and in some other stores but for Industrial or Truck-Bus use.
Millers Oils EE Performance 10W50This product is for a performance engine oil featuring NANODRIVE low friction technology for vehicles requiring an A3/B4 or A3/B3 10w50 specification, predominantly for European and Asian extreme high performance vehicles. PERFORMANCE PROFILE: • Manufactured to far exceed the requirements of API SL/CF and ACEA A3/B4 • Suitable for operating at 125oC with peak temperatures up to 150oC DATA SHEET NO: 7955 DT: 04/01/17 • For fast road use or track days in engines where a 10W40 is normally specified Specific Gravity at 15°C 0.869 Kinematic Viscosity at 100°C 20.0 Kinematic Viscosity at 40°C 139.9 Viscosity Index 165 Pour Point °C -42 Flashpoint °C 240 Motul Specific Abarth 0101 10w-50 Fully SyntheticDensity at 20°C 0.854 Viscosity at 40°C 121.3 Viscosity at 100°C 17.8 Viscosity Index 163.0 Flash point 244.0 °C Pour point -45.0 °C / -49.0 °C
No way ! ............. Fuchs Titan Race Pro S 10W-50 Ester Fully Synthetic Engine Oil Kinematic Viscosity at 100ºC 18.17 mm2 Kinematic Viscosity at 40ºC 116.5 mm2 Viscosity Index 174 Specific Gravity at 15ºC 0.869 Pour point -33ºC Flash Point 210ºC ___________________ TotalEnergies QUARTZ RACING 10W-50 Kinematic viscosity at 40°C 127.5 Kinematic viscosity at 100°C 19.8 Density at 15°C 0.8531 Viscosity index 178 Pour point (to be measured) Flash point 224ºC The quest continues...
@nta16 my main concern in cases like this (engine oil in GR climate conditions) are these parametres: Viscosity at 100 °C Viscosity Index
My Felicia has a broken windshield wiper
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanWell done, the grease isn't too much?
