Felicia 1.6 Custom Gauge Cluster
I searched these many years ago, usually were in CZ stores but now can be found in other e-stores. Here is an example: https://www.ebay.com/itm/123114442820 https://www.ebay.com/itm/123114442334?hash=item1caa314e5e:g:1IMAAOSwG4xa7CC9 I remember that i had searched also for these fancy chrome-look "rings" around those gauges. I stopped when other users informed me that they had problem with sun reflections while driving in sunny days.
Favorit/Felicia Front and Rear Brakes - UPGRADE
I didn't said about those kits which have everything but for those patents in which try to "marry" things. No matter if the parts they are from well known brands the driver must know from other drivers test if these are working in every road situation. Many years back in Greek auto-forums some guys wrote negative comments after made patents because their car wasn't controllable at the last meters of the braking. Others made complains that they couldn't find new parts and installed used calipers, others that every time had to replace or fix something had a nightmare trying in various stores to find parts etc. IF there is a certified and proved by the time brake solution then GO.
Few months ago i visited the most famous Brake specialist in Athens to make an upgrade to my Felicia brakes. I said to him that from Skoda forums i have read that the A guy did this, the B guy did that etc but was didn't impressed, he said he know about these ''patents'' from many other cars but he insisted that: ONLY if many guys have done absolutely the same and that worked after many Kilometres on the road-track then the new customer can do this. Yes the C guy may done some ''miracles'' and posted them but he had to certify that what he done worked perfectly while braking in curbs-straight lines-on rain-on emergency braking situation etc. There are so many other factors (car factory balance-tyres-rims-suspension-ABS) that the owner must take consideration otherwise may end-up with a fancy brake system but in ''tough times'' can turn to a nightmare. The ''ready to installed'' kit's are much preferable but we the older car owners can not have often that luxury.
Felicia AC to Favorit
I was in cellphone last night and i couldn't see those 2 small buttons below. Yes as it is in my Felicia. The small motor is outside inside the engine bay, easy access with only one screw that holds the cap.
Are you going to replace those two empty buttons with one for a/c and the other for air recycle?
What type of cats we call black Siam in Greece: https://mypet.gr/wp-content/uploads/2022/12/maures-gates-facts.jpg Of course there are others in different colours. What we call Sellotape: https://www.24hr.gr/el/προϊόντα/προσφορές/κολλητική-ταινία-σελοτέιπ-logo-tape-clear-διαφανής-12mm-x-33m Different brands, different colours-thickness-length-sizes, transparent or non transparent, with plastic reel or without etc, all these are clarifications that follow the main word "Selotape" that you have to say to the seller or write in your search on the web. The same happens with the word "Paraflue", yes it was a Fiat additive for aluminium radiators and after some time every Coolant was called "paraflue" no matter what brand was or concentate-premixed-colour etc the first established word in older mechanics was one: "Paraflou" (that's the way we spell it). When a seller or a mechanic or a fellow driver here asks you about your radiator system: "do you have paraflou in your car?" he asks you if your car has enough Coolant.
Looks like Siam, lovely. Here we call it "Selotape"
Electrical diagrams and devices: Heating and air conditioning https://epowering.cz/skoda-felicia-dilenska-prirucka-elektrika/ (a part from my second link), it's far better than the Haynes manual.
These are from my book. I also found this in CZ language: https://skoda-virt.cz/cz/clanky/elektrika/845-el-schemata-felicie/ Click to enlarge the photo. This is much better, has ALL the manuals but not in english https://epowering.cz/skoda-felicia-dilenska-prirucka-elektrika/ For sure from the photos you can understand much more things than me.
- Felicia AC to Favorit
- Brake System Maintenance Question
Some guys use the:- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI glued temporary the two pieces from the part of the plastic socket which has been cut-off. As you can see in the photos (front-rear) it's not round but oval shape. That means ''Overtighten'' is the cause of the problem so keep this in mind for your own coolant hoses, don't to my mistake.- 1999 Felicia stalls occasionally after around 1-2 km
No spark? I don't think so. https://www.thisdaylive.com/index.php/2023/01/07/5-signs-of-a-failing-crank-sensor/ https://mechanicbase.com/engine/crankshaft-position-sensor-symptoms/ Crank sensor ''issues'' in the past caused me 2 times the car tun-off suddenly in the middle of the road.- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIt's impossible to find such a part here those days,the latest arrive of Felicia here was April 2000 so after few years the local official Skoda dealer stopped to import parts from Skoda Cz for this model. Even in Cz stores all you can find is like these from China: https://www.autobyznys.cz/x29272-en/hadice-hrdla-termostatu-favorit-felicia-1.3-cn-6u0121101 https://www.autodily-stancl.cz/motor/hadice-a-trubky/hadice-chladice-horni-felicia-13-cn-6u0121101.html or like these: https://autodilycz.cz/nahradni-dily/hadice-chladice-594152/?s=2573526 https://www.autokelly.cz/Product/XS-6U0121101/8673579 They don't say Genuine Skoda but even if you manage to find an original they don't have Paypal or credit card system but only bank transfer which means: delay plus money commission.- 1999 Felicia stalls occasionally after around 1-2 km
Have you checked your spark-plugs? Have you installed other type for example Iridium? Have you checked the crank sensor? Connections or dirt beneath it? Have you ever cleaned your injectors?- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanStill can be found here in Greece. https://kritosparts.gr/part.aspx?expression=6U0121101 https://www.getparts.gr/gates-solinas-psygeioy-vag-513382 https://onparts.gr/index.php?route=product/search&search=6U0121101 Shown some signs before the end or suddenly cut off?- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSome months ego my mechanic made a ''pressure test'' and found 2 tiny leaks, tighten the screws but from instinct i went the very next day and a bought a new hose-clamps ''just i case". I had the new radiator hose-clamps from last year in my shelf and in my mind was that in the next coolant change (before summer vacations trip) i will make the replace but the bad luck overtook me. I learned a lesson from this: Don't overtighten the screws of the clamps if there is no serious reason for this. The radiator has another 2 hoses below, i will leave them ''as is'' and i will don't touch their clamp's screws. Here is a yesterday's photo, the engine bay was cleaned this afternoon and i checked for leaks, none was found.- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThis is a photo from today. The new hose if pushed all the way to the remain of the socket and a new clamp installed, tightened properly although i wanted this clamp few millimetres more to the right. I wonder if i use plastic epoxy putty like this https://www.chatziathanasiou.gr/en/putty/840-permatex-84330.html to ''build'' the whole area and ''bond the hose and the plastic frame of the radiator would be a good idea? Of course this means that the hose would be extremely difficult to be removed even for a repair. This is ''one way only'' solution which means there is turning back, if in the future something goes wrong with the hose then the radiator (and the hose) must be replaced.- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI had a spare hose in my self plus new clamps The part code for the hose is 6U0121101 Is already installed with new clamps plus new coolant, the air removed procedure is done plus a road test for some kilometres but the question remains: Will that patent last or i had to make a repair or buy a new radiator? The 3rd solution means at least 200 euros for buying-shipping plus fitting-new coolant etc totally at least 300 euros.- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYes the radiator is from 1999, it's the original.I posted a new one to show you the point were the damage has been made. One thought of mine is to remove that original radiator, go to a local plastic parts-specialist that we have hear to make a ''reconstructed" socket or make an insert from aluminium or bronze so the hose will fit to this. For sure he will use a strong epoxy glue for plastics to hold that insert with the main plastic body of the radiator. When i say ''insert'' i mean something like this Is that i good idea or not?- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere are two photos of what remained from the plastic socket on the radiator's frame. Thankfully it didn't broke deep inside but lets say at 2/5 so some material remained, checked and it's robust. The bad thing is that has not the "protrusion" so there is a danger for the hose after some years to start ''slide'' to the outside and inevitably suddenly will come-off and i will have another road tragedy. I suggested to the mechanic to use some epoxy glue for plastics to the bottom of that remained plastic socket (for extra holding of the hose to that part) and said he didn't agree with that.- Cooling system problem (AGAIN) in my Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThanks a lot, i will have this in mind for future purchase. Yes i have a new set, at 6100K with 2 functions, straight beam and strobe effect controlled by a switch on the steering wheel plastic column (i will make a new thread as a project for all these extra switches) Sad but i have lost the spring band many-many years ago and i am using inox screw clamp. My theory is: the main hose was old and ''dry'', with all the repairs-coolant changes etc has tightened too many times so all the tension was going to the plastic socket which after 23 years didn't lasted and broke. Here is the old coolant hose, as you can see from the marks was under lot of tension. This side was in the plastic socket of the radiator. The hydraulic oil small plastic tank was removed and the mechanic pushed the new hose as far as he could. New inox screw type clamp, new coolant added, test for leaks (No), road test some kilometres and no leaks, excess air removed, added some antifreeze to the proper level, another road test and no leaks.- Cooling system problem (AGAIN) in my Felicia
The sector that has caused me the majority of problems in my Felicia is the Coolant system. I have repaired or replaced almost everything and one time i had to call the Road Assistance because my car was one click from overheating(the radiator fan was Out). Since this system is my ''nightmare'' i pay attention every day to the temperature gauge in dashboard plus very often i check the connections, signs of coolant leak etc. Thursday noon while i was on the road to work i noticed that the needle raised at 100 'C and first signs of ''smoke'' came out from the grille, my first reactions was a ''Not AGAIN", turn the alarm on, moved to the right and when i cam out i saw this: I was extremely angry not because i would be late at work plus i couldn't imagine the cause of this since i had changed the coolant recently-check the hoses, the clamps, i had a new expansion tank plus new cap etc. I lift the hood and i saw the main coolant house out plus coolant all around he engine bay, bad odour and my first thought was that the clamp get loosed and i can fix it quickly, i wear my glover and made the first try-failed. Again and again but the same result: Failure. Every time the coolant hose was ''popped out'' no matter how tight was the clamp, full of agony i turn my flash light and then i discovered the terrible true, the plastic socket for the hose was broken! Yes, broken! 😵 I put my finger inside the coolant hose and i found the remains, i couldn't believe of what happened and my main question was ''Why?'' Take a look of how it is from a vertical view (photo from a spare parts shop), as you can see it's not something robust (die cast), looks like 2 pieces stuck together. I started to worry, send some photos and an email to my work that i am going to be late, call my Road Assistance and after my mechanic ''make a space to your garage because i am coming". The guy of the RA came and said ''i can't do anything" and load my Felicia to his truck, i took a taxi to go to work and in my mind was ''How this happened'' and ''how i am going to fix this" because i knew that the price for a new radiator is about 200 euros plus the work from the mechanic plus the parts (new hose, new antifreeze etc) and of course many days without a car. (To be continued...)- Brake System Maintenance Question
You can still find TRW-Brembo-ATE-Ferodo-FTE etc for us. - Felicia AC to Favorit
