Everything posted by pab567
Octavia MK3 Smartlink Activation
MIB STD2 Toolbox is the answer
It's never Plug&Play. New unit must be reworked - patch must be applied for Component Protection and activations, unit must have coding and adaptations adjusted to match car's equipment.
Yes, remote rework for single SD units is not possible. Another yes - swapping single sd card MIB2 unit in the glove box for a double SD card MIB2 unit means you could use a sd card patch to activate it. No need for the display unit to be changed.
Amundsen MIB2 Firmware Update
PM sent
PM sent
@EvilBono you must have SMS soldering skills, QNX knowledge and either UART or EMMC-SPI. This will allow you to load MIB STD2 Toolbox into your unit that you can later use to activate new features like SmartLink and othe FEC/SWaP activated features.
PM sent
2016 Fabia Infotainment Upgrade AndroidAuto Apple CarPlay
Yes, I will contact you in PM.
Firmware Update Skoda Octavia 3
Weird, but sound issues are typical HARDWARE issue of dry joints in power amplifier ICs.
- MIB2/Apple CarPlay upgrade
Sent in PM
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
I sent you download lonk for MHIG_EU_SK_K1552... what do you expect from the new firmware?
Reverse camera help
Confirmed :)
infotainment update
Check your PMs
infotainment update
Forget Chinese Android units, you need Bolero 5Q0035842x / 565035842 or Amundsen 5Q0035874x / 565035874. New unit must be patched first.
Emergency Download
@kasfearless PM sent
I sent you download link in PM. Concerning the rest of your request - as I wrote: don't ask me how to use MIB STD2 Toolbox or how to modify metainfo2.txt.
2017 MIB 2 Screen retrofit 5E0 919 605 M
@robinio you have Amundsen MIB1, with Bluetooth, with DAB, part number 5E0035874A, with USB 5Q0035726B and fortunately you don't have CANTON sound system. To use display you bought (5E0919605M) you also have to replace glove box unit, either with MIB2 Bolero, Amundsen or Columbus. If you do not need video playback from SD, DVD and USB then I suggest Amundsen as with Bolero NAV button will not work. If you would like to use Apple CarPlay then you also have to replace USB port. All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them: - MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB - MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster) If you are interested in P&P version pls contact me in PM.
- Firmware request
- Amundsen MIB2 Firmware Update
Firstly, check your PMs for download links. Secondly, how many times it must be repeated that: None official firmware update activates new features, e.g. SmartLink It's NOT possible to upgrade from 02xx to any other soft than 02xx, from 03xx to any other than 03xx and from 04xx to any other than 04xx without patching unit first. To patch the unit you can use MIB STD2 Toolbox. Units with OEM navigation (two SD slots) can be patched from SD. Units without OEM navigation (single SD slot) can NOT be patched from SD, they must be reworked on bench as some files must be manually replaced in EMMC. To use MIB STD2 Toolbox you also have to enable developer mode in adaptations. to upgrade from 02xdx to 03xx or 04xx, or from 03xx to 04xx, you MUST modify metainfo2.txt And pls, don't ask me how to use MIB STD2 Toolbox or how to modify metainfo2.txt - I give you a fishing rod, not a fish, you have to use your brains (and Google...)- infotainment update
This is English forum so pls use English language.- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
