pab567
FREEDOMTech
Everything posted by pab567
  1. Pls share part number of your Bolero or VIN of your Fabia.
  2. 1. format SD (best max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
  3. @matbeva you don't need dLink for MIB STD2 unnits. Do you have UART interface to connect it to the unit?
  4. @Paulygee22 I sent you download link in PM. If this doesn't help then I beleive it's a HW issue.
  5. 5Q0 035 820 C does NOT support SmartLink. If you want to use SmartLink you must have infotainment reader (glove box unit) replaced with Bolero 5Q0 035 842 C / 565 035 842 or Amundsen 5Q0 035 874 C / 565 035 874.
  6. Your unit is MY16 - software 02xx (0245). APP button is supported in MY17 and newer units, i.e. units with software 03xx (e.g. 0369) or 04xx (e.g. 0480). All other buttons and features will work.
  7. Yes, but APP button will not work as it requires SW at least MY17 (03xx)
  8. Sure but this is something extra you can do in the future :)
  9. Yes, you can replace your instruments cluster with digital one, called Active Info Display (AID) or Virtual Cluster (VC) as in teh picture below: Yes, you can save money and install a simpler version of MIB unit with CarPlay support and keep your current display Looking at your requirements I believe Amundsen is the right choice. I will PM you for details.
  10. Indeed, factory setup is Columbus MIB1, with Bluetooth, with DAB, part number 5E00358020A, with Media In port and fortunately you don't have CANTON sound system. You can install one of four different OEM glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You don't have to replace display unit unless you want to go for MIB2.5 Columbus as the only display unit that works with it is 5E0919606D. You also have to replace Media In with USB port. The question is what is your budget and which of listed below features are "must have": - Video playback from DVD, USB, SD - CD playback - OEM navigation - displaying OEM maps in Virtual Cluster (Active Info Display). All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them: - MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB - MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
  11. @Matess36 I confirm what @varaderoguy wrote, in such case I believe this is either some HW issue with your infotainment unit or broken microphone harness.
  12. @mystique4u was Columbus MIB1 factory installed? Could you pls share VIN so I can check compatibility and share the options with you?
  13. I do NOT recommend chinese ANdroid based units if you want to drive this car for a few years. OEM solution (Bolero or Amundsen) is the only one I can recommend.
  14. You already have most recent SW version for your unit.
  15. There might be different reasons: Coding issue. Do you have any diagnostics tool to check coding and adaptations? Software issue. Pls go to service menu (long press MENU button) then see FEC/SWaP codes and post a list of installed and valid codes. If you don't see menu item for FEC/SWaP codes then you need to enable developer menu in adaptation of 5F unit. Also pls post part number and current SW version (menu SETUP then SYSTEM INFORMATION) - your unit might require software update. Hardware issue. If coding is OK, unit has current SW version and FEC/SWaP code for Bluetooth (00050000) is installed and valid then probably Bluetooth module inside your infotainment unit is broken.
  16. Forget 5L0035680A, it does NOT support Android Auto neither Apple CarPlay, just MirrorLink which is obsolete and has been abandoned by all phone manufacturers. Rework of 5C0035680B to Skoda that I make includes: Firmware upgrade to MST2_EU_VW_PQ_P0480T Loading modified SKODA HMI from MY18 MQB unit Patch for Component Protection (CP error remains in diagnostics but unit works normally) Activation of all supported features (Voice Command, navigation, SmartLink, Sport menu) Fix for exiting Phone menu in MaxiDot Change of buttons backlight LEDs from red to green. The only issue is you are located in Australia and I am in Poland...
  17. part number of your MIB STD2 PQ unit? buttons LEDs change is a hardware mod, 22 LEDS must be exchanged, I use OSRAM LG M67K-G1J2-24
  18. Download link sent in PM. Keep in mind you will have to load maps after reflashing.
  19. If properly done then the only disadvantage is that if you don't have CANTON then left and right channels are swapped.
  20. You can paste VIN here. If you have red emergency download screen it's enough just to enter SD with unzipped firmware.
  21. Emergency download? I need at least VIN of your Polo to identify the part number of your infotainment unit and send you link for matching firmware.
  22. Upgrade from 03xx to 04xx is not possible the regular way, patch must be installed, search for MIB STD2 Toolbox
  23. The last map version for Columbus RNS510 family was V17 so I beleive what they offer is scam... When you click the link it changes a lot:
