Everything posted by pab567
Upgrade to 9.2" mib 2.5 from bolero ?
Check this thread if you have Amundsen
Yes, it will. Yes, it can, but to get full features of it you need to replace gateway and MFSW buttons.
VW maps update create account (e-mail only required). Select Golf GTI, from 2017, select radio (Discover Media = Amundsen, Discover Pro = Columbus), select region, download
So now you have Bolero MIB1, with Bluetooth, without DAB, part number 5E0035840A, with USB 5Q0035726B and fortunately you don't have CANTON sound system. You can install one of four different OEM glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D If you woulkd like to use Apple CarPlay then you also have to replace USB port. The question is what is your budget and which of listed below features are "must have": - Video playback from DVD, USB, SD - CD playback - OEM navigation - displaying OEM maps in Virtual Cluster (Active Info Display). All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them: - MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB - MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
Bluetooth (new phone) audio won't connect
Wrong VIN 😞
VIN?
@kfayz Possible, at least both display and glove box unit must be exchanged. Pls share your VIN so I can check the details.
Front suspension part numbers
To determine components used in your car - depending on engine and transmission, different parts are used.
VIN?
Mk3 fabia car play upgrade
VIN?
Amundsen MIB2 Firmware Update
Unfortunately I don't have any (there is 0363). How can I help you?
Help stereo
It will work but the APP button may not work (depening on your car - in MY16 units it will not work, in MY17 it will).
I need Bolero Update :-)
Unfortunately for your unit it's not possible to ugrade firmware to anything else than 01xx to get Android AUto and Apple CarPlay, the only possibility is to replace the infotainment unit. New unit must be patched first to have the new features enabled. If you are interested pls contact me on PM.
Your unit is Amundsen MIB2 without DAB part number 5Q0035864A. It supports Android Auto and Apple Carplay however in your case it didn't work as it was not activated (option 9WC - Without "Multimedia" in vehicle). Do you have any possibility to connect VCDS or any other diagnostics tool (OBD Eleven, ODIS, VC Tool) to check if there is a communication with 5F unit and what are the errors? @Winder9561 google for "MIB STD2 Toolbox".
@Konstant_nos you have link on PM. @Winder9561 pls post part number and SW version of your unit. @ScleptzeR 5E0 919 605 J is just a dsiplay, what probably died is the glove box unit, pls post your VIN so I can help more. @techgenius I have no idea, I use my own solutions, you have to google for it. Answering wireless SmartLink (Android Auto, Apple CarPlay) - in MIB2 / MIB2.5 units it's possible but ONLY with the external third party adapter connected to USB.
Conked Columbus
This is the problem of overfilled NAND. 1) yes, try to reflash it with 5238, you have link on PM (you will need to load maps after reflash) 2) not so much, generally "lowe" letter means older unit
Crazy electrics, warning lights and stereo
Regarding stereo: this might be a typical "self-touch" problem, caused by faulty touch panel (digitizer). Pls share VIN of your Fabia so I can recommend replacement.
@techgenius it ALWAYS requires patching the unit (swdownload must be patched) which in your case (single SD unit) requires soldering (not possible via SD). All others check your PMs
Not possible via SD in single SD units.
Update sent on PM. Wireless Android Auto and Apple CarPlay possible only with third party adapter connected to USB (assuming you have SmartLink activated). Voice Control can be activated either by your SKODA dealer or unit must be hacked - which in this case means it must be open and soldered in order to change some files in EMMC.
- Adding speed limiter to Fabia MK III - possible?
Emergency update on my MIB
@kubalol90 I sent you download link on PM
New unit must be patched (hacked) to have new features activated. MirrorLink is already dead and it worked ONLY with very few Android based phoYes, you already have the latest version MSTD_EU_SK_P6230 (0490)
So now you have Bolero MIB1, with Bluetooth, without DAB, part number 5E0035819A and fortunately you don't have CANTON sound system (as your Bolero has no MOST). You can install one of four different OEM glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D If you woulkd like to use Apple CarPlay then you also have to replace USB port (if you have Media In interface instead of USB then it must be replaced with USB anyway). The question is what is your budget and which of listed below features are "must have": - Video playback from DVD, USB, SD - CD playback - OEM navigation - displaying OEM maps in Virtual Cluster (Active Info Display). All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them: - MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB - MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
