pab567
FREEDOMTech
Everything posted by pab567
  1. I'm sorry but this is not a kind of knowledge I can share. Let me know your location on PM so I could guide you to someone who can install it in your unit.
  2. For navigation units - yes, but unfortunately not for non-navigation ones.
  3. The most recent maps are 4 years old and there are no and will never be new maps, no matter if you have Amundsen or Columbus.
  4. Yes, HW problem - dry joints in powert amplifier ICs, in 95% it's enough to have them both resoldered.
  5. 5Q0035864x, 5Q0035874x, 565035864, 565035874, 3V0035020x, 3V0035021x, 3V0035043x, 3V0035044x where x is any letter (A, B, C etc.) Just pls note 3V0919606 is for Superb, not for Octavia
  6. Yes, you can enable green menu via adjusting adaptation channel with work "developer"
  7. It can be patched to remove CP and activate all the functions but it requires soldering and knowledge of QNX. If you are interested pls contact me on PM.
  8. I'm sorry I'm not able to help you remotely... you either must find locally someone experienced or send the unit to me for repair.
  9. I have done it several times since 2016, using Amundsen and Bolero MIB STD2 PQ units from facelifted Yeti.
  10. TRy to get in touch with user @Rustynuts as I'm quite far away from you (Poland), I beleive he should be able to help you locally
  11. Not in this one - must be replaced, e.g. to 3C8035730D or 3C8035730E
  12. You burn an image using ISO file. Pls use search, it has been described multiple times.
  13. It's NOT possible to update SW from SD. I will send you link via PM.
  14. Yes - press SETUP for couple of seconds and then System Information (assuming it is listed - in old SW versions it is not). Nope, only from CD-R / DVD-R (CD-R recommended).
  15. I believe SW update / refresh issomething might help. Do you know what SW version you have now? If not, pls post here a picture of the lable located on the top housing.
  16. Model number and SW version of your infotainment unit?
  17. Nope, all they need is just a glove box unit.
  18. There are two power amplifier ICs, they will find them easily, no worries
  19. I don't know such link... if you are familiar with soldering you should have no issues with disassembling, re=soldering and re-assembling the unit.
  20. Typical issue of dry joints in power amplifier chips.
