Everything posted by pab567
Colombus unit - are there different versions?
And in Settings menu in Maxi_Dot?
Without WLAN in BT module you will NOT have access to Internet when you are connected in RSAP mode. Try to find in MaxiDot, in Phone section, Bluetooth settings, some switch to enable / disable "Premium" mode.
Nope, 3C8035730D/E. See picture below - black font means this is installed in your car, grey ones are the other options. As you can see, your module (5N0035730D) was later replaced with 3C8035730B then C3C8035730C, 3C8035730D and finally 3C8035730E (which is not listed here bue believe me, it was). Check in your mobile what are the Bluetooth profiles active between mobile and Skoda BT module. Both your mobile and Skoda BT module support both RSAP (Remote SIM Access Profile) and HFP (Hands Free Profile). See List of Bluetooth profiles. Advantage of 3C8035730D/E is that in RSAP mode (and this is what you probably use as you have to enter PIN when connected to Skoda BT module) they can create WiFi Access Point so you can access on your phone data based services.
I've checked Telephone Retrofitting page and it looks I was wrong - your module supports Bluetooth. What is the phone you use?
Looks that you have BT module 5N0035730D which, if I remember correctly, does not support audio streaming - so the best solution IMHO is to have it replaced, e.g. with 5C0035730D or 5C0035730E.
Amundsen MIB2 Firmware Update
Check your PM for download link. BTW: Your unit must be 5Q0035874C, not 5Q003587AC
Yes, if you are interested pls contact me on PM.
This is not a kind of knowledge to be shared, especially here.
Infotainment
You unit is SWING, unfortunately I don;t have any firmware for it 😞
Bolero Head Unit Update
@Floreien you will not be able to have CarPlay enabled officially, new unit (Bolero 5Q0035842C or Amundsen 5Q0035874C) must be patched. Pls contact me on PM if you are interested.
Head unit difference between Canton and normal stereo?
Yes, but this is peanuts...
Changing CANTON is not a big deal - just add harness from glove box unit to the new amplifier (plus the power for amplifier). You have to make sure your amplifier is capable of driving 10 individual speakers or you have to use additional crossover to combine individual such-channels.
Pls post a picture of your infotainment unit and VIN of your Superb.
- Infotainment
- Amundsen MIB2 Firmware Update
1. yes, stay with 0480. 2. any 3. well, it can be any but you will not have Skoda HMI 4. possible 5. the question is on your budget and must have features 6. yes 7. to make it official - yes, however the unit can be patched and then ODIS is not required- Amundsen MIB2 Firmware Update
SOP4- Amundsen MIB2 Firmware Update
There can be several reasons: - make sure your SD card is formatted under FAT32. (use 4096 bytes for cluster size when formatting, it helps sometimes) - unit is NOT SOP4 (originally installed firmware was 02xx or 03xx, SOP4 firmware, i.e. 04xx, can be pushed only to SOP4 units), in such case use eith SOP2 (02xx) or SOP3 (03xx) firmware, depending what SOP the unit is - EMMC is broken - memory controller built in iMX6 is faulty- Columbus Infotainment System
Sent- Columbus Infotainment System
I suggest to use 5274, not 5270, as 5270 (as well as 5269) are kind of buggy- Columbus Infotainment System
It's looking for CD with SW upgrade. Take the unit out and post a picture of upper case label.- Amundsen MIB2 Firmware Update
You already have th elatest SW version 😞- Infotainment screen connection issue?
Your VIN pls?- Infotainment screen connection issue?
Just 2 removal key at the bottomand then simply push it out, at the top there are smply some kind of snaps. Display and touch panel are two separate parts, just connected one over another, that's why touch works OK - IMHO display is faulty. If your unit is in warranty pls claim it with Skoda otherwise just buy the same unit and jest replace the front panel.
