Everything posted by pab567
- Columbus RNS 510 stuck in bootloop - help needed
Fitting reverse camera
Your unit 5Q0035842A support RVC, despite mechanical installation you have to adjust coding in infotainment (5F) and parking distance control (10) units.
2016 Fabia Radio Update
You're welcome
What sun visor clip do I need
Share VIN in PM and I will check part number
When upgrading: enter service menu (requires developer mode enabled in adaptations) select manual SWDL select all unmark cpu/emergencu and main/emergnecy start
@oabraldes sent in PM
Sorry, I was away, has just returned home, too late to drive to workshop now, will send you tomorrow.
ok
OK, I knnow wher ethe problem is but I am not able to help you, pls drop me reminder in PM in the evening (9 PM CET).
RequiredVersionOfDM must be modified as well
Yes, you go directly from 253T to 480T now. Just keep in mind metainfo2.txt from 480T must be modified to (check for "RequiredVersion" tags and change non-zero values to 0.
Use tools menu to patch SWDL
All you need is MIB STD2 Toolbox and google
Skoda Swing Firmware Update - MU 8755
@Vladimir2708 I'm sorrry but I don't know the solution to patch your unit.
@oabraldes what is part number of your infotainment unit?
Columbus Infotainment System
sent in PM
I need Bolero Update :-)
Sure, I sent you request to share VIN in PM
Fabia carplay
I sent you download link for MEN2_EU_SKGPx_P0080L_8755 in PM.
- 2018 Fabia CarPlay crackling - needs update?
It's possible but it requires unit to be patched first, also the metainfo2.txt file must be modified. Is it worth? There are no new features, just new skins.
I can see I sent you link to SEAT version instead of SKODA, sorry. have just resent the right one MST2_EU_SK_ZR_P0253T. Of course you can upgrade to , you entered your train incorrectly (MST2_EU_SK_ZRP0245T, the right one is MST2_EU_SK_ZR_P0245T):
1800? There is no such firmware, for sure not for your unit. I sent you link to download MST2_EU_SE_ZR_P0253T which is thsn't help pls let me know.e most recent firmware for your unit, if it doe
- CarPlay crackling issue, software update fix?
