pab567
FREEDOMTech
Everything posted by pab567
  1. You have link to download firmware on your PM. Both ACC and PM require swap codes - ACC in gateway, PM in infotainment. None can be done by SKODA dealer - 5F must be hacked, for ACC you must get a code that will have it enabled and unfortunately I don;t know anyone who can currently have it generated.
  2. 1m long waterproof cables that goed from bumper to the trunk - 000098712A.
  3. To have SIM working you need to add 2 LTE antennas that are factory installed inside rear bumper - 5E0035497 (left) and 5E0035497B (right). Then you need 1m long waterproof cables hat goe from bumper to the trunk and then regular coaxial cables to connect to infotainment unit. I don't remember part numbers now for the waterproof cables but can check it later. Alternatively ypu can get aftermarket antenna from aliexpress which is very cost-effective.
  4. Language list remains the same, no new features are available.
  5. All others pls check your PMs
  6. No, this is the most recent software I know.
  7. Unfortunately I don't have any formware for your Swing :(
  8. Yes, you can get the cheapest version and have it upgraded to the most recent version.
  9. No... 0411 is the lates one. All others pls check your PMs.
  10. Firmware you have is the most recent I know :( so if you have any issues I recommend to raise complaint (as I expect your car is still under warranty). But first try another cable between USB port and your phone.
  11. Unfortunately I don't have firmware update for your unit - although I have seen units with newer version (0363).
  12. If your unit was factory installed then it should not have happened. Or is it retrofitted hacked unit?
  13. Unfortunately there is no newer version for your unit :(
  14. And what is the unit you have now?
  15. Προτείνω επίσης να γράφετε στο Klingon, ο καθένας σίγουρα θα καταλάβει Translation below:
  16. Bolero MIB2. Can be done but NOT remotely. Contact me on PM if you are interested.
  17. @d_olalla detailed list of changes (so called change log) is not available, no new features, just bugfixes - check your PM.
  18. Unfortunately it will not - your unit does NOT support SmartLink, although this is included in the menu items. None SW update will have it sorted. The only solution is to replace unit mounted behind glove box - if you are interested pls contact me on PM.
  19. This is NOT SW version... software version is like 0253... or train like MST2_EU_SK_ZR_P0253T... and model number like 5Q0035819A...
