Everything posted by pab567
Amundsen MIB2 Firmware Update
You must have not only FEC/SWaP 70400 activated but also xml that manages it uploaded to the unit to get ICC (In-Car Communication) activated. All requesters check your PMs.
Same as for previous request - It's NOT possible to upgrade from 03xx to any other than 03xx using regular update. To achieve it unit must be first hacked and then flashed using firmware with specially modified metainfo.txt. This is definitely NOT a piece of cake and I do not recommend to make it to anyone who is not fluent in QNX and does not understand what is the impact of changes he is doing.
Multimedia upgrade from Swing
... and extra harness to have it all connected
Component protection activated
Visit your local Skoda dealer...
Virtual Cockpit Install?
Columbus MIB2 does NOT support VC :( so either you have to switch to Columbus MIB2.5 and 9.2" screen 5E0919606 or switch to Amundsen MY18 (5Q0035874C / 5Q0035864C) as it supports VC and then you can remaing with current screen.
I need Bolero Update :-)
No updates for Yeti - there are units with newer software but nobody has this software available as update. @mantask check your PM
MIB1 Programming
FEC for Drive Mode Selection is insatlled in gateway. You have it inactive becasue adaptations were not setup properly - look for adaptation channel with word "charisma" and have it enabled.
Check your PM but I really doubt it helps :(
PM
Radio problem!
Bad news. Typical root cause for such behaviour is faulty eMMC. There is a special procedure, called emergency update, that might help - the problem is that I don't hae any frmware for your unit and I kno nobody who has it :(
It's NOT possible to upgrade from 02xx to any other than 02xx using regular update. To achieve it unit must be first hacked and then flashed using firmware with specially modified metainfo.txt. This is definitely NOT a piece of cake and I do not recommend to make it to anyone who is not fluent in QNX and does not understand what is the impact of changes he is doing. Software 04xx for SKODA PQ does NOT exist at all. I have NOWHERE found 03xx software update for SKODA PQ, if anyone has it pls contact me on PM. Everybody is looking for it... or any other 03xx for SKODA PQ
Radio problem!
As there are multiple versions of Bolero pls share exac model number.
AppConnect cannot be unlcoked with SW upgrade - either contact your VW dealer or the unit must be hacked.
Nope, this unit, as well as 820, does not support SmartLink (neither RVC) :(
Skoda bolero
@Bilsaf79 link sent via PM
- Direct Firmware Download needed for Bolero in Octavia III
All check your PMs
Nope, this is the most recent version I am aware of.
Playback from SD Card - MP3's first track missing from album
@marky9074 check PM
Amundsen MIB STD2 infotainment system with Android in Superb II
Then either the unit is broken or misconfigured or your gateway or cluster is too old.
Does your unit turns automatiall on when ypou trun on ignition?
Skpda Bolero Update
1st of all - there are already dedicated threads for firmware update, there is no need to create another. I will report this thread to be closed. Secondly - it has been described couple of times how to make firmware upgrade so just use search,
update of the Columbus program
Infotainment retrofitting
PM
