pab567
FREEDOMTech
Everything posted by pab567
  1. All check your PM
  2. There is no newer firmawar for your unit :(
  3. @varaderoguy is right. Just some comments from my side: 1. in regular conditions it's NOT POSSIBLE to upgrade from one SOP to another. SOP is firmware version family - SOP1 means FW 01xx, SOP2 means FW 02xx, SOP3 means FW 03xx, SOP4 means FW 04xx. I hope this is clear 2. Hacking makes it POSSIBLE to update from one SOP to another, e.g. from SOP2 (e.g. 0253) to SOP4 (e.g. 0478). Both unit and SW update must be hacked. Pls don't ask me for more details. 3. SOP1 units can NOT be upgraded to SOP2 or higher. eMMC is partitioned differently and although this can be changed but after such rework unit hangs when entering Android Auto or Apple CarPlay - probably there either some HW difference or additional piece of SW that is not updated. I spent multiple hours on it and I finally gave up. So whoever has SOP1 unit: sorry guys, you must have your unit replaced to get SmartLink. 4. SOP1 units support ONLY MirrorLink. 5. If your SmartLink or Voice Control is inactive then NONE SW update will made it enabled - you must either visit your local Skoda dealer or have the unit hacked. 6. Bolero versions 5Q0035819x and 5Q0035820x (x means letter A/B/C, no letter for SOP1 versions) are simplified versions, with only 1 processor, without SmartLink support and without Rear View Camera support. It's NOT possible to have SmartLink enabled for them. All check your PMs
  4. Sure they can...you have to make adaptation channels map from both old and new unit and wherever possible adjust channels in new to match old.
  5. Not valid anymore. This is how it ends when you publish links to documents that break the law.
  6. @SashaGrace is probably right. For sure you will need to adjust coding and adaptations - VCDS will do the job. But it MAY also require new ASAM/ODX file to be loaded and unfortunately this cannot be done with VCDS - but VCP (Vag Can Pro) will make it.
  7. This is MIB3, not MIB2.5. No CD/DVD drive, no SD card reader, no SIM...
  8. Sorry for not answering earlier... Pls be so kind in the future to use @pab567 tag to draw my attention. All check your PMs. Happy New Year
  9. Not possible. HDD stores only music files, navigation maps and POI - none part of operating system is stored there. You must have your drive replaced. You ca ntry to use CD-R insted of DVD for updating.
  10. Last one is MST2_EU_SK_ZR_P0253T. All check your PM.
  11. This is not MIB2, this is MIB1 Columbus. Any particular reasons for requesting an update?
  12. Model number and SW version of your unit?
  13. Nope - I only deal with MIB2 units and yours is MIB3. Sorry...
  14. Yes. But to fit it in your car you also need extra harness. If you want want to use SmartLink then unit must be hacked too.
  15. No, maps for Amundsen are different to Columbus ones. You can find latest maps at Volkswagen Maps & Software Update website - for Amundsen maps pls select Beetle then Discover Media and then download file for required region. No VIN is needed
  16. @bmbmdmb pls be so kind to remove link from your message. there is some intention why I am not publishing links in threads but sending them via PM. Thx for your understadning.
  17. @Txdriver - use any SD card, not USB pendrive @golf2 - don't be lazy, you can download maps from official Skoda Update portal, just google to find it SW download link sent by PM @sree_hari82 - what you have is the most recent SW I know for your unit
  18. Just use search, it has been described few times...
