Everything posted by Gabbo
MIB1 Map Updates Stopped ??
Does anyone know if the MIB1 (columbus) map updates have been stopped? (End of life or just "problems" with the download at the moment?) Online the last I can find are ECE2024 from CW25... There should have been another update in November 2024 usually.
Temperature Gauge - DPF Regen
Assuming its not "new" new as you've posted in the Mk3 forum. What mileage is it at & when was it built? This issue sounds exactly like the common TDi water pump problem. When the problem first begins, the temperature will increase towards the red (but not reach red & does not trigger any limphome). If you continue for 30s-1minute the temperature will decrease again. The problem is during warmup, the water pump has a electronically controlled sleave to warmup the engine quickly & then open to allow water from the radiator/tank to flow through the system once its at temperature. The sleeve is "sticky" on the old parts (due to different temperature/expansion properties of the materials) & can take time to "pop" open once the temperature of the materials matches. I used to "dip" the clutch and wait a few seconds until the temperature needle started to decrease again. It will do it once per driving cycle & will be fine for the rest of the journey. I would call the garage immediately to inform them & ask when/if the water pump (and timing belt) was changed. In the past Skoda/VAG was offering 50-60% of the cost of this because it was a common problem. As your car is new it should come with at least a 1 year warranty so I would be insisting that the water pump (and timing belt) are replaced free of charge. The timing belt is not normally part of the water pump change, however, it must be removed to change the pump so you might as well change it at the same time. If the garage says no, I would offer to pay for a new part as it will save you several hundred pounds in the future to change it when its due.
Change Units in virtual dash
Can you revert the changes you've made back to how they were delivered from the factory? "Units" must be available on all European cars & especially a car sold in the UK.. On my car is in the same place Leolite: Home->Vehicle->Settings->Units
Replacement EFB stop / start battery for Superb 3V 1.4TSi 150PS
Yes its normal, even when the ignition is "off" many electronic modules are still powered & removing the battery will trigger faults relating to the "power supply".... If you just ignition-off afterwards & let the car shutdown on its own they should all become "historic/passive" codes at the next ignition cycle (or you can clear them with your OBD reader). After something like 40 driving cycles pending codes are automatically cleared so they would normally disappear on their own anyway.
If the car is unlocked before you open the engine bay & you disconnect the battery there should be no alarm.
Just change the battery no need to do anything special... 🤪
Rear wiper blade for L & K estate
Some more digging & there seems a completely new part number for the post Q1 2023 wiper arm. Car Parts Catalog - LLLParts So it would seem 5JJ955707A would be the part to go for which would take the Bosch A403H (also ties in with the dates for the blade part number change posted by ApertureS)
P0401 fault code keeps coming up.
Would the car pass an MOT in the UK if the DPF has been removed/bypassed? A missing DPF could contribute/cause that kind of air path/exhaust fault. Do you know how they've bypassed it? just removed the brick from DPF can or replaced the can with a straight pipe? Is there any kind of orifice to give a similar backpressure to the original DPF?
Glow plug light starts flashing, stops if engine restarted, no OBD error code
There are many cheaper & more modern options to VCDS. OBD11 being the main contender but also Carista provides similar features.. They do however have annual subscription costs which make them more expensive in the long run but you don't need to continue paying once an issue is solved. I took a Carista Bluetooth adapter (without subscription) for €15 and use an app called Car Scanner (free) which will read and clear fault codes, show live data & everything I've needed recently. I'm not really sure what "special codes" vcds can read over an OBD2 device? I would continue to monitor the situation now the battery has been changed. If it occurs again, find someone with a code reader or look at the map of friendly vcds users in your area to try to scan for fault codes. It's the only way to help pin point the cause of problem area. As many users have pointed out there are lots of different reasons the glow plug light or check engine light can be illuminated.
Its strange that there still isnt an aftermarket part for this. The same arm seems to be used on the Superb Mk3 >2023, Superb Mk4, Octavia Mk4 & some other newer models? Skoda-Parts reference the rear wiper arm as: 5JJ 955 707 A or 5JJ 955 707 but you cannot choose which one. I assume the A in part number will be for the "new blade" mounting & the one without the suffix will be the old part. Wiper Arm Škoda 5JJ955707A I've emailed them to ask if its possible to have the pre-2023 part, will see what they say. @Millster its a while since you posted but do you have any pictures of the new fixing versus the A403H ? Is it something that can be disassembled from the blade to fix to another? Usually aftermarket blades come with several clips in the box to attached them to different models/manufacturers. Gabbo
Using Superb iV without external charging?
+1 for the above posts. We had Mercedes GLE hybrid & also charged it only from the 3pin plug. What I will say is that the drivability of the car when the battery was at 0% was quite poor compared to when it was charged. Pull aways and gear changes were jerky etc. Probably not something you'll notice if the car was only petrol but once you get used to the smoothness of the hybrid/petrol combination you noticed it when it wasn't available.
Strange sound from the ventilation
I have this clicking also I'm my 2024 superb. It's having it's 30k service in a few weeks so will ask the dealer but if it needs anything taking apart to fix it, I think I'll live with it
2.0tdi struggles to tow.
I'm thinking maybe a problem with the clutch position sensor/switch? If you sit at idle with clutch fully depressed & slowly release the clutch pedal, the clutch switch should trigger the ECU to increase the idle speed/revs slightly to prepare the Engine for a pull away. Does your car do this? It should happen before the bite point of the clutch. A modern diesel (without the caravan) should happily pull away without any accelerator pedal input just by gently feeding the clutch even on a slope as the idle controller maintains the minimum engine speed.
I guess it is to prevent corrosion between the battery and terminal but I can't see that this is worth £2 or really necessary for a battery unless you live in a very harsh environment Sounds to be like an easy money grab by the garage like when they offer to fill you tyres with argon instead of air...
This is definitely possible because I remember having 10 minutes in the Eurotunnel trying to find this option before arriving in the UK. I'll try to have a fiddle in the morning to see if I can find it again... If I recall there's a while section for units where you can change speed, consumption, temperature, pressure etc
I said exactly the same thing after struggling with slow starts... For ~€100 it can make a huge difference to the car.
Superb 2.0TDi fans running after engine off - possible DPF issue??
I don't think the battery or coding can cause this. I changed my battery 2 years ago & didn't change any coding and it's worked fine since. Assuming your battery was an AGM type before ?? I can confirm that VAG DPF works with a cheap ELM Bluetooth device. I've installed VAG DPF Lite and it works with my Carista ELM device... I have been using Car Scanner which is a free app which can read DTCs, live data & is free... Some fault codes or VAG DPF Data would give you an idea where you start looking..
Unfortunately not... (Facepalm) The factory unit will synchronise the time via GPS but doesn't change between BST/GMT automatically. Each time zone change you need to go to the date/time settings and tick/untick the summer time option..
I think you're over thinking it... Just change the battery, clock will reset the time from GPS... You will have no issues. Providing an additional power supply whilst the battery is disconnected through the OBD or 12v line will only introduce the possibility to cause problem as suggested above with fuses etc
If there was a fault code set it should stay after an ignition cycle but would show as inactive rather than active. I wonder if it was derrating because of the boost air or intercooler temperature, coolant or oil temp? These would not typically show a DTC because it's not a fault rather just a protection of the engine for too environmental conditions. If you have a obd reader you could perhaps try to record some live data of the temperatures to help diagnose the fault?
Drivers Door Window Switch Replacement
What did you do to repair it? Before I took mine out I gave it a blast with an air compressor with small adapter fitting on the end. It's not perfect still but considerably more reliable than before. I guess dust and crumbs over time can work their way into the rocker.
Battery replacement
If you have the tools you can do it. My thinking was, £60-80 for OBD11 or Carista was too much for nothing. you can buy another battery for that price so if it last a year or two less you are no worse off. I didn't change anything, stop start was available on the first drive & I think it was around 2 years ago I changed it, I've had no issues since. I would hope the software in the BCM is able to recognise a new battery based on its behaviour so coding is only really needed if you change the type or significantly change the size.
Nothing will be lost unplugging the battery as far I remember.. +1 for Varta. I replaced my OEM battery with one. (Varta Silver). I didn't do any recoding as it was a like for like swap & all was fine immediately. Just pay attention to whether you have an EFB or AGM now and order the same. But if you have OBD11 anyway you can always code the change.
Battery replacement
As long as you replace the same type of battery (EFB for EFB, AGM for AGM) and the size of the battery is the same you don't really need to do the coding... I change my OEM battery for a Varta of the same type 68Ah to 70Ah without coding & it's worked fine for the last few years without any issues. After replacement there were no DTCs and stop/start was immediately available. If you already have the tools (vcds/Carista/obd eleven et la) then you could do it. But on my side I didn't think it was worth it to sort out another £60 for one of these tools & subscription.
Spare Parts - Where to buy from?
Part arrived & fitted without issues. Another 400CHF saved by DIY so a great start to the year. Fitting details are in anohter thread:
