Everything posted by ords
DQ200 clutch disengage when pressing brake.
You have stop/start turned off?
Help needed with updating the Sat-Nav maps on Columbus system
Are using a Mac or PC? A Mac can add other files which have to removed according to some posters on this topic.
Skoda Octavia stop start not working and high battery charging
That's interesting to know. Mine was bought as an ex demo at 6 months old from a Skoda dealer and came with a Varta battery which is still fitted. Would it have been changed within the 1st 6 months?
Has s/s ever worked since you bought the car?
When the battery is disconnected, what's the voltage then?
Fuses behind glove box
https://www.youtube.com/watch?v=FIMi9isDrX0
Skoda service
- Compatible prop shafts with MK3 Scout
There are quite a few threads on the Haldex with different problems. Until you get yours connected you won't know what if any faults there maybe.- A few issues... Mk3 vRS
Can you get it scanned for fault codes?- Loss of all brake fluid….
I'm sure you would have got a low level warning light.- Glowplug failure and Ticking noise from the engine
I think you mean 1.6?- Engine temperature does not go above 55
- Cruise control stopped working
Could be dirty contacts. Maybe worth taking the stalk off and checking.- 1.4TSI (CHPA) 2013 DM KEITH QUOTE
Have they scanned for fault codes to see why the engine check light is coming on? Is this light also called an EML?- Eco mode / coasting in gear DSG
For me with a DSG, eco & D have the same shifting characteristics but in sports mode it holds onto the gears far too long for my liking- Replacing Electric Windows Master Switch
- 2013 dsg skoda octavia
Can you get it scanned for codes?- Amundsen mib1
Interesting to know.- Amundsen mib1
No it's not and as far as I know there is no option to turn the clock display on or off.- Eco mode / coasting in gear DSG
Exactly what I've done. In eco coasting mode you are using fuel as it basically shifts into neutral but the engine is still running at idle speed. In D you get the benefit of engine braking and no fuel is being used.- Sat Nav Update
- Amunsen MIB1 Firmware
Read this thread. Towards the end there is a work around which give you a map update to I think 2023. I did this with mine.- Amunsen MIB1 Firmware
I didn't notice any difference with the update. Bit of an anti climax.- Amunsen MIB1 Firmware
Read this thread. Towards the end there is a work around which give you a map update to I think 2023. I did this with mine.- MIB1 Map Updates Stopped ??
Official updates discontinued. Read through this thread for a work around. I did it successfully. - Compatible prop shafts with MK3 Scout
