langers2k
  1. I don't disagree that's what Eibach are offering... I just don't believe that a single spring spec can be the optimal spring for such a range of vehicles. Especially given the number of variants Audi/Seat/Skoda/VW offer for the vehicles on the compatibly list There is both a 1.2 A3 and a 3.6 V6 4x4 Superb estate on that list, surely they have different requirements from a rear spring!?
  2. Have you tried pulling the belt all the way out just to check it's not twisted on the reel?
  3. I believe fuse 18 in the passenger cabin is for the rear camera. The wiring is pretty simple for a lowline camera. It should be similar to the below diagram but there might be some LHD/RHD differences and the colours may vary by year
  4. No MK3 Octavia gets LED reversing lights as stock. They use P21W halogen bulbs If your reversing lights are LED, I'd suggest trying normal halogen bubs just to rule them out creating interference.
  5. That looks like a lowline camera, if I remember correctly, they are triggered from the reversing lights. Are your reversing lights stock or have you replaced them for LEDs?
  6. While I'm sure many of the springs Carlston posted will fit, I don't don't know enough about suspension and how the spring spec will effect the ride/handling to recommend any of them. Given you can get factory lowered suspension designed/tested specifically for each weight range/PR codes, that seems the obvious option to me Not much more I can add so I'll bow out for now
  7. The manual and menus won't be country specific. I expect the map data is missing for Italy which is causing the issue. It might work if you were to drive into France or another country
  8. If you really want to stick to OEM, take a look at the link Carlston posted earlier: http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/511/subcategory/511000/part_id/0/lang/e You'll notice the torsion beam springs are grouped in three sets based on PR-code: - 1JA Rear shock absorption basic design 1 - 1JC Rear shock absorption for sports design - UC7 Rear shock absorption chassis with increased ride height Assuming a car currently has 1JA, then going to the correct 1JC spring should give a suitable drop/stiffness increase. As a random example based on a car with PR 0YC. 1JA option would be 5Q0 511 121 AC: - Wire Diameter 10,50 mm - Length 352 mm - Outer diameter 105 mm - Weight 1,45 kg 1JC option would be 5Q0 511 121 AM: - Wire Diameter 11,00 mm - Length 321 mm - Outer diameter 111 mm - Weight 1,45 kg UC7 option would be 5Q0 511 121 BC: - Wire Diameter 10,75 mm - Length 361 mm - Outer diameter 108 mm - Weight 1,60 kg You can use the same method on the front end, bump stops and shocks to get a properly matched kit that's correct (according to VAG) for the vehicle dynamics/weight That's not to say an aftermarket kit like the B12 wouldn't be better/cheaper.
  9. That doesn't mean the springs are cross-compatible or suitable... From the two links you posted, all the torsion beam springs are 5Q0 511 121 xx and the IRS springs are 5Q0 511 111 xx. If VAG could use identical springs for both (and save money), they would have and the part numbers would match
  10. If you look at the Bilstein online catalogue, it lists different parts for multilink and torsion beam suspension so I'd say they aren't compatible
  11. Looks a bit like this: Although there are plenty of people using a suitably large flat head screwdriver instead
  12. Yup, the mic will still work with A6 removed. Basically some cars have a separate module for the mic. The MK2 Octavia doesn't as the mic is either connected to the BT module or radio. This might also be the reason for the mic open circuit code you have Removing A6 from the installation list should resolve the 'cannot be reached' errors shown in your scan.
  13. Your BCM is already a highline so there should be no need to replace it I would try ticking: - 09 BCM, byte 9, bit 3 It should be 'Multi-Function-Display/Board Computer via Operation and Display Protocol (BAP) active' looking at my notes. While your connected, I'd would also suggest: - 19 CAN gateway, installation list, remove A6 Microphone - Clear all DTC's Hopefully that'll just leave the alarm siren and the radio (DAB, mic, aux in) fault codes present.
  14. Should be fine. The stock headunit should also have four channels, each channel will power two speakers
  15. There are two separate recalls. The first is part of the emissions scandal. Basically VAG were caught emitting more NOx than they were suppose to and produced a software update to reduce the NOx production. To do this, they've changed the fuelling and EGR usage. This has various negatives including but not limited to: - possible increased fuel usage - possible drivability changes - EGR issues due to partially clogged EGR that are now being asked to move more - DPF issues as reducing NOx production increases particulates and mean the DPF needs to regen more often These are some of the reasons that people (including myself) refused the optional software update. It has no effect on the MOT as the NOx levels aren't tested. The second recall is to either update the BCM software or tweak the lighting configuration. I believe the issue is that some LED bulb failures aren't causing a bulb out warning like they should. It would probably be possible to confirm what the second fix does if I had access to the same car before and after the recall action. They should be able to only perform the second update but you'll need to get it in writing so you can hold them to account if they do both.
  16. Can you post an autoscan to see what modules etc your car has?
  17. A MK2 FL Superb should use 5E0919719G if it has a MFSW with DSG paddles Might be worth asking a mod to move this thread to the MK2 section assuming I've not misunderstood what car you have. A MK2 FL should look something like this:
  18. If both steering wheels are from a MK3 Superb and you already have a MFSW, it should work AFAIK. If you're trying to fit a MK3 Superb wheel in a MK2 Superb, the buttons are incompatible.
  19. In which case, the first problem is getting the CAN-gateway to communicate in the car. As you've seen it doesn't take much to talk to the CAN-gateway so I'd try: - checking the twisted pair between the CAN-gateway and OBD port - checking the grounds at both - checking the power is on all the necessary pins At a guess, it'll be a permanent or switched live that's not getting power so the CAN-gateway or HEX-CAN aren't powering up properly.
  20. @seancannon - the Skoda servers can be a bit pants at times. Try this direct link from the VW servers: https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU-AS_1520_V13.7z
  21. @Danoid - the OP seems to be complaining the lights aren't dimming rather than wanting to stop them doing so Anyway, I'd take a look at static AFS light-Abdimmgeschwindigkeit - mine are set to 25.
  22. 289 miles on 39 litres is ~33.7 mpg 330 miles on 39 litres is ~38.5 mpg To put that into context, the worse/best from a single tank in my vRS is 33.0 vs 41.95 mpg so its certainly within single tank variance. Might be worth measuring a few more tanks to confirm the fuel usage Also you should bare in mind that: - A to E rated tyres can change fuel usage by up to 5% (A to G is upto 7.5%) - Used (2mm tread) to new (8mm tread) will effect the odometer by ~2% - Not all 225/45 R17 tyres are even the same size which will effect the odometer The reason I mention the tyre size is because a larger tyre will make the car think it's covered less distance and mess up your calculation by making it appear low. A combination of the above factors can easily cause extra fuel use and also make the reported mileage seem to drop giving a large difference
  23. The dealer/company should be able to confirm the part numbers from the VIN. My best guess would be the part numbers stamped on these: https://www.ebay.co.uk/itm/284064547632
  24. Can you post a VCDS autoscan and an adaption map from 09?
