Everything posted by D402
- Lcc not working
I do too, they have a weird side effect that the electrics don't shut down properly when you switch the ignition off if any of the other interior lights are turned on!
Glove box lock/latch replacement
There's a screw underneath the button assembly that might be what holds it in. I bet you have to remove the whole glovebox assembly to get at some clips though. Did you say "I don't belieeeve it!" when the button popped out?
Sounds like the small spring in the actuator part has escaped. I think you could replace this with the spring from a pen, it fits in a recess in the bottom of the part if I remember rightly. The main button and big spring should push into the round hole and latch in. Looks like there might be something stuck in there (the broken off end of the button?) that you'll need to extract first.
1.6 TDi Greenline glow plug replacement
Agree with using the penetrating oil but, when the time comes, use a T-bar wrench so that you apply a pure torque, this minimises the risk of snapping the glowplug. 🤞for you!
How can i tell what fuel filter i need?
This one worked for me, same engine and year as yours, engine code CRLB: https://ebay.io/m/OO378P
Front park assist retrofit help required!
That's for manoeuvre braking
About to embark on Skoda ownership, Superb L&K Estate
Perfect timing posting that, thank you! I thought the 45 degree jet was caused by a partial blockage and this afternoon's job was going to be to clean it out!
Started getting a loud noise at high revs recently, sounds like a resonating heat shield . Had a poke around under the bonnet and found that the engine cover wasn't fully clipped down. Sorting this out seems to have cured it 😀 Also tightened a loose bolt on my motorcycle which I hope fixes a noise on that too, a good day!
Extended crank when cold 2.0tsi GPF
Great diagnosis, did the dashboard temperature gauge behave normally despite the faulty sensor?
Full Matrix Led headlights on motorway
I applaud your efforts! If you still don't get a satisfactory response, you could try https://www.gov.uk/vehicle-recalls-and-faults/report-a-serious-safety-defect
ABS Sensor Issues
That's not a part number, it's the material specification - Polyamide 66 with 25 % glass fibre. Genuine only for these parts it seems.
I have a moth in mine, and a huge caterpillar crawled out of the headlining on the first warm day after I got the car. No amount of shaking the tail lamp would shift the moth, the caterpillar made its own way out. I wonder if they were related...
Climate control issue
The evaporator could be freezing up and blocking the air flow. When you switch the A/C off, it melts and drains away so the system works again for a while. AI tells me this can be: blocked cabin filter so there's not enough warm air coming in to keep the evaporator clear blocked A/C drain - check there is a puddle of water under the car when you park up on a hot day low refrigerant pressure so the evaporator has to get below freezing to achieve low enough air temperatures or many possible A/C system component failures
Air Care won't activate
Do you have the oh-so-reliable air quality sensor under the scuttle panel?
Dead battery, EFB vs AGM replacement (and self code?)
@PJGallagher Have you changed any bulbs to LEDs? This can have weird side-effects including the car not powering down properly and draining the battery.
Wheel alignment and radar
You're absolutely right and there's nothing special about the Superb, the problem is that most garages can't be bothered to adjust both tie rods so that the steering wheel is straight. To be fair, it's not that easy to judge the straight-ahead position of the steering wheel when you're not driving. I corrected my own in the end! I have had to have the radar re-calibrated after replacing the front shocks, but never after alignments or new tyres.
Where can I find a keyless entry sensor?
Sketchy for sure, but it worked for a couple of people!
Looks like it can be done with an extension cable from one of the car's antennae, see the reply from Kajetanski. Good luck!
Fuel flap won't open 2018 super 2.0 tdi estate
This might help:
P25AB00 Piston Cooling Oil Control Circuit High - Superb
I suspect that the short drives and cold starts don't create the conditions where the solenoid is actuated so the ECU clears the fault after three cycles without the fault being detected. You said that the replacing the solenoid did not resolve the fault. This suggests that there was never a fault with the solenoid so the technician moved on to check the wiring, found a fault and bypassed it which initially solved the problem. Next step is definitely to check the wiring again as this was found to be faulty before.
First thing I'd check is the recently installed wiring bypass.
DSG stalling in reverse
That's it, it's usually fine if I can pull away and continue to accelerate but if I have to back off at the critical moment with a cold engine it will stall occasionally. I tend to release the park brake manually to move off as slowly as possible because visibility from my driveway is poor in one direction, the stalling still occurs then so I don't think it's related to the brakes. I long ago enabled Audi mode too, no change to the stalling.
Mine (2017 2.0 Tdi 150hp with DQ250, 84k miles) has done this in first and reverse from new. Normal servicing, DSG oil changes and brake maintenance don't make any difference and it hasn't got any worse over time. Longer warm up before moving off helps. I'll try switching the Autohold off too.
Central locking fault
I have similar tailgate lights which cause similar problems but only if any of the interior lights are switched on! It's been suggested to me that the light type needs to be coded. This thread suggests changing all the interior lights to LEDs might cure the problem:
