Everything posted by D402
Steering wheel not centred, what next?
The problem is that most garages only adjust one tie-rod end to get the wheels aligned and this leaves the steering wheel off-centre. They should then make equal adjustments on both tie-rods to centralise the steering wheel. It is difficult to judge the centre position of the steering wheel when you're not actually driving so a road test is needed to check it's right. @netman82 What happens when you drive along a straight, flat road with your hands off the wheel? Does the car go straight with the steering wheel off-centre, or pull to one side or the other?
Map updates
Then it must be Columbus and you can use any SD card to update it. Sorry to add to the confusion.
Map updates
We need to make sure, OP's SD card is for Amundsen. @Hamster59 Does your satnav only work with your Skoda SD card plugged into the car?
Map updates
I think that's an Amundsen unit which means you have to use a Skoda SD card.
2023 Superb vs 2016 Superb
Here's some bargain mats for you! https://www.kopacek.com/skoda/superb-iii/superb-iii-original-skoda-interior-floor-mats-prestige-grey-line-rhd/3v2061404a
Cold air breeze in OBD socket area
The glovebox ventilation is always cold. Could it be that the heater output for the right-hand drive glovebox isn't blanked off in your left-hand drive car?
Is this off my Skoda Superb?
Thanks for the better pictures! The hex bolts, blobby welds and plastic coating leave me pretty confident this isn't part of a modern Skoda.
Don't recognise it myself but it looks aftermarket to me, clamp for a mudflap or part of a towbar perhaps. Google Lens comes up with a few suggestions, including a Volvo oil cooler. How big is it? Are the bolts welded to the plate? A better lit photo on a white background would help.
Replacement (failed) damper recommendations
Sachs is a brand name of ZF who are one of the original equipment suppliers so they should be fine.
Showing MAF sensor fault
Best get it back to whoever deleted the DPF and get them to fix it then. Good luck at MOT time...
Smoke and lost power suggests an air leak between the turbo and engine inlet manifold. MAF fault occurs because less airflow is measured than the ECU expects. Smoke shouldn't be getting past the DPF though so there may other issues.
Android Auto stopped working after phone reset
Clearing data and cache worked perfectly, thanks both.
I've just got my Google Pixel 4a phone back from having its battery replaced during which it was factory reset and restored from backup. Now Android Auto no longer works, I get the message "Check the setting on the mobile device and the connection." on the car screen when I connect the phone. I have already set "Start Android Auto automatically" to "Always" and "Use USB for" to "File transfer/Android Auto". I guess there's another setting that I need to change, any ideas?
Tyre check indicator
I've had similar with one odd tyre fitted, repeated resets eventually stopped the false warnings.
Mk3 cornering lights mounting
Good luck, in my case, the impact of the pheasant ejected the grille! You might be able to push the grille out from behind with less risk of it breaking. Don't waste your money on aftermarket grilles, very poor fit and flaky chrome.
The black honeycomb pattern grille pulls out leaving the light behind and revealing the screws. There should be a wire tool with a hook on the end in the boot for this purpose.
You have to get the grille off, the foglight is held by four screws screwed in from the front.
Skoda superb workshop manual
Have a look here, foglight: https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/9/941/941041 bumper: https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/8/807/807010 wheel arch liner: https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/8/821/821015 Looks like you have to pull the grille off which will reveal four screws holding the foglight.
- I think, something is wrong with my new rear brake pads, help, please...
Plastic covers for steel rims
I had similar problems with my wife's Peugeot - it was returned from a garage with poorly fitted wheel trims. There's a stiff wire hoop clipped to the back of the plastic trim and they'd managed to get one or two of the clips outside the hoop instead of inside.
SKODA SUPERB 2016 TPMS FAULT
I've had the same after having to change one tyre while the rest are part worn. Keep doing the resets, eventually it will sort itself out.
Light assist
Auto-dipping and xenons were definitely not standard on SE Business spec but it might have been added by the first owner and there were a few early cars with some bonus features included. Do you have the triangular camera aperture on the windscreen?
Speedometer consistently reads 5 mph lower than actual speed
Another thing to check would be the speedo readings against a GPS device - I find the both analogue and digital speedos read a consistent 3 mph higher than the GPS speed in Waze. Perhaps the digital display is reading high!
That would affect both the analogue and digital speedo though. My first thought is that the analogue needle is sticking sometimes.
Intermittent fault with parking sensor (?)
Those were the first warnings I got when the battery was failing but then the warnings were only at start up.
