Everything posted by nige8021
Retrieving Radio Code
I used to have a VAG serial number decoder that on some radios worked but I've used the ebay services twice now with no problem just send them the serial number engraved into the case and short time later the code was emailed
problem at low revs 1100-1200, 1.9 SDI ASY
The Accelerometer is only there for the side impact detection for the airbag system absolutely nothing to do with the engine
VW Blaupunkt 3T0035456 10Ch Amplifier
Pin 1 Ground Pin 2 +12v Live supply Fuse # 16 30amp Pin 3 RF MID - Pin 4 RF BASS - Pin 5 LF BASS + Pin 6 LF MID + Pin 7 RF Treb - Pin 8 LF Treb + Pin 9 RL BASS + Pn 10 RR BASS - Pin 11 RR Mid/Treb - Pin 12 RR Mid/Treb + Pin 13 RL Mid/Treb + Pin 14 RL Mid/Treb - Pin 15 RF MID + Pin 16 RF BASS + Pin 17 LF BASS - Pin 18 LF MID - Pin 19 RF Treb + Pin 20 LF Treb - Pin 21 RL BASS - Pin 22 RR BASS + Pin 23 CAN L > Radio pIn 10 Pin 24 nc Pin 25 nc Pin 26 nc Pin 27 LR - INPUT Pin 28 RR - INPUT Pin 29 LF - INPUT Pin30 RF - INPUT Pin 31 CAN HI > Radio pin 9 Pin 32 nc Pin 33 nc Pin 34 nc Pin 35 LR + INPUT Pin 36 RR + INPUT Pin 37 LF + INPUT Pin 38 RF + INPUT
VRS rear brake problem
Engine running makes no difference to basic bleeding of the brakes just alters the pedal pressure if doing it the old 2 man way, if a pressure bleeder was used makes no odds as @KenONeill said needs VCDS to put the ABS into service mode to get any air trapped inside out
Passenger front window regulator help!
This tool makes it so easy to remove the connector https://www.ebay.co.uk/itm/194705886234?hash=item2d55600c1a:g:V9AAAOSwZltb8vQ6
Brake pad warning light
My Touareg has sensors on all 4 corners but other VAG have one front one rear on opposite corners
Only a physical inspection will show which sensor has triggered the warning you can't tell with diagnostic kit
Soundproofing My Fabia
I used this https://www.ebay.co.uk/itm/255234238733?hash=item3b6d25690d:g:X8UAAOSwrpRdlG2C on the underside of the plastic engine cover on my MK1 Octy diesel and with the bonnet open it reduced the noise by 6db according to the app on my phone
Non starter
‒ → Set camshaft sprocket to mark -arrow A-. ‒ Set crankshaft to TDC No. 1 cylinder. The ground tooth on the crankshaft toothed belt pulley must align with the marking -2V- on the sealing flange -arrow B-.
part numbers
https://skoda.7zap.com/en/cz/fabia/fabi/2012-706/1/115-115022/#14 oil filter https://skoda.7zap.com/en/cz/fabia/fabi/2012-706/1/129-129015/#2 Air filter (build date important)
Sidelight strangeness - 2009 Fabia
The earth point is common to all the bulbs in the headlight (Pin 6 of the 10 pin connector)
2011Fabia TDI 5 speed manual - Damage to diff housing - What caused this?
Exactly the same damage I had on my Polo gearbox when the rivet's failed on the crownwheel
Rust on my Fabia's underbelly!
Or worse a motorbike/cyclist/horse rider
A few questions about 136 Rapid brakes & Estelle wings.
I've always had great service from them 👍
Try https://www.biggred.co.uk/ for a caliper repair kit
Rocker cover oil leak, bolt pattern
As it's such a low torque figure and there is no specified sequence I don't think it really matters the sequence, just to do diagonally so yes you could use 8-1-4-6 5-3-2-7 ???
Looking at the dealer workshop manual there is no specified pattern for the rocker cover bolts, only the torque of 9Nm so I would just use the normal diagonal clockwise like this 1-8-6-4 3-5-7-2
So, I have KESSY but I have a question about the physical key that is 'hidden' in the remote
The end cap on the drivers door will pop off to reveal a normal key slot
Anyone own a mk2 octavia sport??
There's a couple of covers listed in this https://www.skoda-parts.com/catalog/octavia-2/spare-parts/body/rear-body/rear-bumper-312.html?strana=1&sort=&query=
Front inner brake pipes corroded
I've had a several of orders from them and although not the fastest delivery I did get everything and when one order was notified as being shipped and nothing after 5 days a quick email and it was sorted and got the order 2 days later
Hitting the big seven-oh---
Last week a woman got a 12 month driving ban after she was seen weaving all over the road on an e-scooter, she was breathalysed found to be over the limit, claimed didn't know drink driving also applied to e-scooters
1.6cr white smoke limp mode
Compression readings Pressure New engine 2,5 ... 3.1 MPa (25.0 ... 31.0 bar) Wear limit 1,9 MPa (19,0 bar) Max. permissible difference between the cylinders 0,5 MPa (5,0 bar) @J.R. yes diesel pressures are quite a bit higher
Boot side trim panel screws
#3 ?
https://skoda.7zap.com/en/cz/octavia/oct/2011-663/8/867-867080/ ??
Air Bag Light
This is the Airbag wiring diagram The seat heating and you'll see the two 2 pin & one 4 pin connectors
