Everything posted by AGFalco
Oil again
Exactly what I do with three of mine with the same oil. Thanks. AG Falco
Battery replacement? Confusing...
Is it the original battery? Has it been tested? What mileage/use is the car getting? Have you charged the battery? Perhaps a little low. Is there not a button on the RHS dash, above the light switch, where you can turn the stop/start off? Is the battery you have in the garage an EFB type? To many questions I think. ๐ฅบ Thanks. AG Falco
66 Reg Citigo Monte Carlo: instrument lights?
Yes. One of mine has the Scandinavian DRL set up so parking/sidelights are even more redundant. Thanks. AG Falco
Karoq Tyres
Yes always. I try and ask question before they even come in. They did swap to summers. Thanks. AG Falco
Rubbing noise from front
Please tell us the result after your visit. It can help others. Thanks AG Falco
CV boot can make this noise if you are moving on full lock? To check you can turn the steering wheel full lock, jack a road wheel up and try spinning the road wheel and listen / look. Thanks. AG Falco
Activate electric water pump when car is off - electric engine heater Fabia 1.0tsi
Don't forget that the engine also has an oil temperature sensor as well that might influence engine starting/running. Cold coolant water but hot oil signals at the same time? Thanks. AG Falco
Toolkit/jack
If the car does NOT have a spare wheel then you don't get the jack and wheel brace as you have no use for them? ๐ฎ Not my theory. Thanks. AG Falco
USB A socket in front console replacement
on the N-S-F bottom of the windscreen and is easy to see. Might be hidden under the wiper though. Thanks. AG Falco
Can you use the engine heater that uses the sump plug entry method? https://www.google.com/search?sca_esv=597300995&rlz=1C1CHBF_en-GBGB917GB917&sxsrf=ACQVn0-BHkfO_lmk1wAj81retTQ0_lGFkw:1704919082625&q=car+engine+heater+to+sump+plug&spell=1&sa=X&ved=2ahUKEwjGl6nC1tODAxXUZ0EAHaR-BEsQBSgAegQICBAC&biw=1536&bih=730&dpr=1.25 https://uk.vicedeal.com/products/car-diesel-engine-12v24v-oil-sump-heating-the-o-engine-oil-m12-preheating-plug-tank-m14-electric-heating-rod-m10?variant=UHJvZHVjdFZhcmlhbnQ6MTQ5MTc4NzMx&gad_source=1&gclid=Cj0KCQiAnfmsBhDfARIsAM7MKi0IGYziTsba7R0HigmZXsR9UJIldzFQHNL0xt9xC6K2CV1m76rh2OUaAjoWEALw_wcB Thanks. AG Falco
Looking at Mk3 fabia estates probably monte carlo
You can get heated seats in a Fabia III. I have them in mine, it was part of the winter pack. Still on the original normal sized 027EFB battery after over seven years and 78K miles. Thanks. AG Falco
Not if it is properly insulated underneath so all the heat only goes up on to the sump/oil? Could be correct. The engine has a split coolant circuit and the electric pump is mainly there to cool the turbo down after the engine stops. It also pumps hot water to the cabin to keep the cabin warm when the stop/start system stops the engine . There is also a second main water pump driven by the camshaft and two thermostats that open at different temperatures to contend with. HTH Thanks. AG Falco
Karoq Tyres
Only yesterday had a customer who ordered 2 all season CAR tyres to fit on his VAN, with summers all round on at the minute. Thanks. AG Falco
Karoq Tyres
How many have you ordered? Thanks. AG Falco
Citigo Rattling Noise during Acceleration
? So post two was a good guess then? Thanks for the update. this can help the next one. ๐ Thanks. AG Falco
Yes, but I didn't hear that noise in the clip you posted above. Have you opened the bonnet and looked / listened at the engine while it is being put under load? Thanks. AG Falco
Exhaust heat shield? These can get bent after driving through water / puddle and they end up near the exhaust. Thanks. AG Falco
LED Headlights - wiring red to black and it works - but why?
LED bulbs only work one way, so if the bulbs were fitted the wrong way round???? Thanks. AG Falco
Tyre compressor included with vehicle
Yes. ๐ But the pressure gauges are often not very accurate. If you have a puncture try the compressor only first. If you cannot hear the air coming out you might be able to drive somewhere and have it fixed without using the gunk/sealant. Always put too much air in the tyre at this point in time. Having a tyre that has been gunked will have consequences:- Often the tyre has already been driven on soft and the tyre is already damaged. Some times you can't find the puncture because the sealant has worked. This is normally only on very small holes. This is where just using the compressor only might have worked. Quit often with a big hole / side wall damage, the sealant wont work anyway. When you remove the tyre there is a load of sticky sealant that needs cleaning out. This is where you might want to offer the fitter a sweetener beforehand, unless you are going to volunteer. ๐ฅบ Most modern sealants are water based these days. Be warned that the sealant bottles have a use by date on them. ๐ฎ I am not a fan of this set up. All four of my cars have a full size wheel and tyre that is exactly the same as the other four on the car. Thanks. AG Falco
- Tyre compressor included with vehicle
If you removed it the tyre has a bigger hole and will go flat quicker. Sometimes the gunk/sealant will temporarily fix a puncture if you leave the screw / nail / foreign object in the tyre. This enables you to drive somewhere. If you have the puncture repair kit you don't normally have a spare wheel/tyre and tools. Thanks. AG Falco
ERROR Visit workshop, leave vehicle in P
The first three characters in a VW part number indicate what car platform it fits. So you might have the same part that fits on different car platforms. EG '1S0' indicate the Skoda Citigo, VW UP and Seat MI platform. HTH Thanks. AG Falco
Karoq Tyres
Most car tyres have a maximum pressure of about 3.5 Bar. or 50 psi irrespective of XL or normal load. It is on the side wall of the tyre. On my 185 60 15 88H XL tyres it is 3.4 Bar. On my 175 70 13 82T normal load tyres it is 3.5 Bar. Thanks. AG Falco
Accidentally locked in the car๐
Just info:- If anybody is locked in a car and need to get out by breaking a window they can try this. Remove a headrest and use one of the metal legs to break the glass. Don't forget if you can not get a front one out ( electric adjustment but no power ) us a rear one. HTH Thanks. AG Falco
- Clicking sound by wheel
