Everything posted by AGFalco
Škoda Fabia mk3 spare wheel size help
What size tyres/wheels have you got? I have a Steel 15'' spare wheel with a 185 60 15 tyre on it from my Fabia III. Are you anywhere near N Dorset? Thanks. AG Falco
Intermittent Headlamp main beam/flasher.
Perhaps the light switch and/or the stalk? Thanks. AG Falco
Upgrade Standard Radio to factory Bluetooth...
Ask @pab567 Thanks. AG Falco
Stupid question:- Is there power getting to the bulb connector? Have you taken the bulbs out and checked that both filaments work in each bulb? Thanks. AG Falco
Components not working
Is it the relay then! Can you swap it for a known good one? Thanks. AG Falco
- 2018 Citigo - what fits into this adjustable dash mounted cradle?
Have you tried using a short headphone jack ( if the Iphone has one ) to plug in the the jack plug in the front of the Swing Radio? You want a male to male 3.5 mm one like this? https://www.amazon.co.uk/dp/B00E0IPUTE Charge the Iphone from the 12 volt power outlet by the gearlever? No. Thanks. AG Falco
Weird sound in passenger footwell
Part of the heating ventilation system. Under the bonnet is the intake. To the right of the glovebox is the fan/flaps. Possibly a fan or flap moving, or trying to move. Is the recycle mode button on? Thanks AG Falco
Locking fuel cap
https://www.skoda.co.uk/discover/contact-us [email protected] Is there not a drain hole? Thanks. AG Falco
iPod use
If the car has Smartlink and Carplay installed you can use an iphone with a charging/data cable in to the USB socket. This will work using the steering wheel buttons. Info here: - https://www.skoda-auto.com/connectivity/connect With an ipod it should connect and play using the AUX input plug. ( looks like a headphone socket ) Don't think the steering wheel buttons will work though. There should also be an SD card socket ( hidden ) in the glove box which will work. HTH Thanks. AG Falco
iPod use
What year is your Fabia III? The very early one's might not work. My 2016 will though. Thanks. AG Falco
how
On my Fabia and VW UP the mirrors will heat up independently of the rear demister. But yes anywhere between L and R will put the heated mirrors on. Be warned they don't appear to turn off automatically and there is no warning light. On a Peugeot I had they would automatically heat when you put the rear demister on. And they would automatically all turn off after a short while. But was no way to turn them on independently. Thanks. AG Falco
how
There are no arrows on the switch. You need to push the switch / joy stick in the direction of the arrow ( in the handbook ) that corresponds with the direction you want the mirror to move. So pull down/back to lower the mirror. This is with the dot on the end of the switch / joy stick lined up with the mirror you want to adjust. L for Left, & R for Right mirror. You need the ignition on for this to work. HTH Thanks. AG Falco
- What can I do for performance modifications for a 1.0 MPI engine
Help fog lamps
From inside the wheel arch, behind the fog lamp unit. The hole is for adjusting the beam direction. Thanks. AG Falco
Appalling Customer Service
Come across this regularly. Ask them ( the Dealer ) if they will change the seal , you will change the review! Thanks. AG Falco https://forums.moneysavingexpert.com/discussion/6584893/trust-pilot-can-they-be-trusted
Front light lens replacement
Above £400.00. Note this is for the front right unit : - https://www.skoda-parts.com/spare-part/6v2941016b-front-right-headlamp-h7-led-skoda-51097.html Thanks. AG Falco
1.0 mpi 6 speed transmission conversion
Change to a taller tyre would do this! But this would give you slower acceleration! My TSI 5 Speed is at 130 KMH at 3000 RPM. Thanks. AG Falco
What speed is the car doing at 2000 & 3000 rpm in 5th gear? The TSI engines are better on fuel economy than the MPI. They have much higher torque and at lower revs than the MPI ones. Thanks. AG Falco
Missing Tyre Pressure Sticker - 2015 1.2 TSI 90hp hatch
Yes, quite normal. Get the beam direction checked after a new unit is fitted. Fabia III's can have different lens types. Do you have the Projector or the Reflector type unit? Thanks. AG Falco
Oil volume and specs for 2016 Fabia SE 1.4 TDI – sanity check!
Have you managed to reset both the Service and Inspection warning messages? Thanks. AG Falco
