Everything posted by AGFalco
Head Unit stolen, 8 year old Yeti, what should i do?
Speak to @pab567 Thanks. AG Falco
Oil volume and specs for 2016 Fabia SE 1.4 TDI – sanity check!
put your Reg number in here : - https://www.mpmoil.co.uk/ Thanks. AG Falco
The most comfortable 225/50/17 tyres ?
Dunlop? Thanks. AG Falco
vRS built and sat at Emden - Roughly how long?
Have you tried looking for your car at Emden? You will need to zoom in a bit. 🙂 https://www.google.com/maps/place/Port+of+Emden/@53.3451354,7.1681393,3041m/data=!3m1!1e3!4m6!3m5!1s0x47b6374fcb0136a7:0x529aa28e057a42c9!8m2!3d53.3355556!4d7.1836111!16s%2Fg%2F1229cmsd?entry=ttu&g_ep=EgoyMDI1MDkyNC4wIKXMDSoASAFQAw%3D%3D Thanks. AG Falco
QI6 is Variable servicing. They all come out of the factory with that set. It can be changed to QI4 Fixed servicing easily. It sounds like yours has already been changed. Thanks. AG Falco
Factory fitted arch liners
You need to wash off all the dirt/mud from around the fuel filler pipe, but on the inside of the arch. It rusts from the inside first. Mine was 3 1/2 years old when I bought it. There was just the first signs of of rust on the inside. I have checked since and I have prevented it getting any worst by painting the area. Thanks. AG Falco
Citigo added to the family garage.
Early winter check just done. Rotated tyres. Stripped, cleaned and re greased brakes. Front pads just over half worn. Rear drums good. Charged batteries. Greased door hinges, door locks, boot lock, boot hinges and bonnet hinge and latch. Refitted radiator partial cover. Checked levels, all good. Car still all good. Thanks. AG Falco
See this post:- Thanks. AG Falco
Battery just replaced, unusual voltage reading
Yes, but it shortens the life of the battery. In the UK a shop that fits batteries would be able to code the new battery for you. Thanks. AG Falco
The battery control module records the power going in to and out of the battery. It remembers this and will then charge the battery accordingly. If the car is not programmed when a new battery is fitted it will charge the new battery thinking it is the old battery. If the old battery was at half the capacity of the new one it will charge the new battery to this ( half ) capacity. Does the voltage change from when the engine is running compared to when the engine is NOT running. My Fabia battery is 9 Years old and the car has done 90K miles. Had the car from new. Are you anywhere near N Dorset? Thanks. AG Falco
Best practice IS to update the car. Thanks. AG Falco.
Have you programmed the car to tell it that a new battery has been installed? Thanks. AG Falco
Not fitted to the facelift 2018 one I have. But I did fit them after I bought it. Thanks. AG Falco
Service intervals
To make up for the cam belt changes they are now not doing? 😉 Thanks. AG Falco
Sudden problem with air vents. Making a really loud noise.
Correct. I am also on the UP forum as I have both an UP and a Citigo. Thanks. AG Falco
Hello, Scooter.😉 Thanks. AG Falco
- Roof bars for 2022 reg Fabia Estate
fan speed on 1 ot working
AC works all the time, but if it is in the off position it is only working at about 6%. Yes you can sometimes notice this. Thanks. AG Falco
Timing belt replacement.
Check at 165,000 miles and then every 20,000 miles. VW removed the advise to replace the timing belt a few years ago. Spark Plugs? I have a 2016 1.2 TSI at 90000 miles and car is still good. Thanks. AG Falco
Disabling Car Alarm by Disconnecting the Battery?
There is another way: Open the car. Open the boot. Get in the car and shut all the doors but not the boot. Push the car door lock button on the dash. Get out of the car via the boot. Close the boot. This locks the car, but wont turn the alarm on. Thanks. AG Falco
- Fabia III Blues radio upgrade
If you push the anti alarm button on the B post, does the alarm still go off? Thanks. AG Falco
Early 2016 Rapid Smartlink issues
speak to @pab567 Thanks. AG Falco
A TSB from Skoda on cold start behaviour with 1.2 TSI's. Something that Dealership Employees should be able to explain to customers.
To me it is temperature related. Thanks. AG Falco
- Battery coding help needed
