Weird warning
Hi John, welcome to the forum. Was a symbol displayed at the same time? - Possibly a warning that front assist is unavailable (radar sensor masked by debris, etc)
Engine size on newer cars
Hi Belinda, the 90PS would be ok - but keep an eye out for one with the 1.0 TSI 110PS engine.
Engine Coolant Level Low message when is fine
Hi, yes - have been away from home for far too long. Wellington boy, but moved to Taradale in 1980 because of the horrible winters. OE trip in 1984 - still here!
TSI 1.5 oil specification changes
Hello HMS, welcome to the forum. The low level light will come on with around one litre of oil used - contents of engine oil sump is around 4 to 4.5 litres, so around 25% used - do you not check oil level more than once a year?
How's life on the Sunshine Coast?
Tena Koe Bazza, there was an update to the coolant level expansion tank sensor in the past three years, where the sensor probes were changed - I believe this change was made exactly for the reason you describe. A search in the topics section should show you the difference. It might be possible to carefully clean the probes using an old tooth brush, but the cost of a new, updated tank shouldn't be that much anyway. Does your existing tank still have the 'Mit Silicat' teabag in it? - get rid!
Spare Tyre well has screw in body work that punctured the tyre
Is there anything attached to the underside of that screw? If not, perhaps some scrote thought it was the fuel tank and was trying for a free top up but was disturbed in the act. They'd get really disturbed if I caught them!
Rob's Ur Quattro
Hi Rob, re. dropping off the 15mm fuel line - I did that once while marshalling on the Mobil economy run, (when all NZ motorsport was cancelled in 1974) - I ended up looking and smelling like a monk about to self-imolate!
Baffling rear brake efficiency problem
+1 for point 2 ^^^^^
Looking at used 2018 SE L Exec estate 1.4tsi - thoughts?
Hi, how much inconvenience is it to have to press the remote button on the fob? - not to mention possible security issues and reduced fob battery life. Useful to have the tow bar, even if you only use it for a cycle carrier. How often would you really need the park assist? Seems a fair price for the mileage - this model and engine is really great.
Aerial with panoramic roof
Just checked for the 2020 Kamiq the radio antenna is in the side rear glass. The GPS/GNSS antenna appears to be in the windscreen, near the rain sensor / front camera.
Hi Ben, I can't say for sure for the Kamiq, but it may be incorporated in rear glass.
Rob's Ur Quattro
Hi Rob, that fuel filler pipe does look pretty flat - if not actually "uphill" I recall a Toyota flat deck that had a filler like that, and it was a bas7ard to fill unless it was parked on a slope.
Car supermarket distant selling and all the sales crap.
Is it too late to cancel the deal? especially as they are now moving the goalposts. I rather suspect she will be better off with the old car back.
Rob's Ur Quattro
In polite language - "The Fundament of the World" Your pictures made me feel quite homesick. Was a visit to The Chateau included on your run?
Rob's Ur Quattro
Guess what we used to call Waiouru ATG?
Rob's Ur Quattro
Which, at almost $3.30 a litre, means you have to sponge it up off the deck!
Škoda Favorit / Felicia Moose Test?
2) - really bad idea, the legs just snap off and the carcase comes straight through the windscreen.
That's because it was DAF's design project P900 replacement for the DAF66 - sold reasonably well, especially the 360 with the Volvo B19 engine.
Coolant level fault
Get the thermostat checked, common fault.
Coolant level fault
Hi Tony, welcome to the forum. Very likely to be the thermostat sleeve sticking - can be a common fault on certain models. Try a search for this under cooling problems. What car and engine do you have?
2011Fabia TDI 5 speed manual - Damage to diff housing - What caused this?
I agree, spalling on the 1st picture does suggest something internal letting go.
Help - Identify a leak...DSG?
Is that corrosion on the bottom corner of the cover plate nearest steering-arm ?
MOT history
That is only to keep the MOT anniversary - A new MOT can be done ANY time, reluctance by the dealer to do this is immediate cause for suspicion.
Advice needed on sealing plastic scuttle panel to the bottom of the windscreen
Good morning, how about a strip of double-sided tape? - Gorilla glue would work, but is likely to be very difficult to remove in future.
