Warrior193
  1. It is very strongly advised that adaptation (coding) should always be done when replacing the battery - the reason being to ensure any recorded defects in the BCM by the old battery, that may be limiting the alternator output, are cleared. If the new battery specs and type are exactly the same as original, simply changing the final digit of the original battery serial number will do this.
  2. Just be aware that you will likely be fobbed-off the first time you visit Dealer for this, at the very least. Good to go with some ammo backing any claim.
  3. OBD should be able to show alternator output. Another very handy tool for the kit is a reasonable quality digital multi meter - doesn't have to be an expensive Fluke - 4000 to 6000 count DMM like a AstroAI is inexpensive and will give quick, accurate readings.
  4. If your use of the vehicle is intermittent and/or used for regular short trips, you will very likely encounter frequent issues with automatic idle stop due to insufficient charging from the alternator.
  5. The AE blank key will not unlock the vehicles immobiliser, unless you manage to remove and swap the chip from the original key - AFAIK, coding the new key will be a Dealership job.
  6. Hello, welcome to the forum. At 87K, your cambelt is not yet due for a change by mileage. It is probably due for a DSG service though. Likely to be a DQ200 box.
  7. Did that confirmation come from an independent scan? Do all the warning indicators light up correctly on pre-start check? Were they possibly historic? I'd suggest simply clearing the current DTCs and see if they return.
  8. Calling @Tonyduncan please can you answer some of the above questions?
  9. Given that Skoda chose to fit the 6-speed into the 110PS TSI - with the 95PS TSI only getting the 5-speed, I'm not convinced that what you propose is particularly practical. Extra gears usually serve to allow closer ratios between gears - not necessarily to give a taller final gear ratio. AFAIK, even 5th in a 5-speed box gives you a small overdrive ratio. (less than 1-1)
  10. Are you able to post a picture of it? As Steve says, likely to be an indication of CellPhone battery status.
  11. Does this mean that 'SWWBN' has to be especially nice to you for a while? 😁
  12. Don't tell him your name Pike! 😆
  13. @Tonyduncan could help himself by answering some of the pertinent questions already asked.
  14. Possibly not a good assumption to make that a one year old alternator or battery in unlikely to be faulty - My Octavia had both replaced at less than a year because they had failed.
  15. The messages that @Stonekeeper is referring to are in the vehicle status display (in the infotainment system) - not on the instrument cluster.
  16. You seem to be saying that you think the alternator is not charging the battery correctly - even though the alternator indicator is extinguishing while the engine is running - is that correct??? - If so, as I posted earlier, you need to check the battery terminal voltage while the engine is running.
  17. I'd say that sounds highly suspicious - if your independent check proves the faults are not present, please report the incident to Carwow as attempted fraud.
  18. OP says battery was charged - not changed.
  19. Sorry - what is the question? Do you think the battery is not being charged correctly by the vehicles alternator - even though the alternator symbol is extinguishing after the engine is started? Do you have a meter you can use to measure the battery terminal voltage while the engine is running?
  20. Hello, welcome to the forum. As you, I'd be a little suspicious - I think either of those faults, if genuine issues, would give some indication. I'd think the P003300 (Turbo bypass valve) would light up the EPC indicator - and possibly force limp mode, and P001600 (Crank or Camshaft position sensor) would cause difficult starting at least. Did you actually see him lift those DTCs? I'd suggest getting your vehicle scanned independently.
  21. With you previous low annual mileage, it could well be that the EGR valve needs a removal and clean.
  22. Possibly turbo boost control. Does the engine go into limp mode? Scan for DTC then clear and see if everything goes back to normal.
  23. I've not particularly noticed it on our Mk3 Octavia or Fabia - but I believe there is a 'kickdown' switch at the lower part of travel for the throttle pedal.
  24. Hello, welcome to the forum. Is that from the headlight washer? Has the washer cover or bumper been damaged?
  25. Welcome to the forum. Probably what has happened is that the catch has moved slightly from rebound with the 'extra' force shutting - take a look at both parts of the catch, they will probably have slotted mounting holes to allow for adjustment.
