Warrior193
  1. One easy way to confirm if it's the MIL indicator or not - the cruise control will not work if it is activated.
  2. Hopefully the fault will just be failing plugs or coil pack/s. Allow them an attempt to rectify the fault, then see how it is. Insist they give you full details of the cause of the fault and what was done to rectify it.
  3. Even in the unlikely event that the doors are different, you could simply sell on the Vrs door.
  4. Ignoring extras such as ambient lighting, etc, I'd take a guess that the doors would be an exact match.
  5. Very odd shaped symbol if MIL!
  6. Image is a little blurry - below the symbol, there appear to be two parallel lines - are these arrows pointing left/right?
  7. For the amount of work involved, including materials, I think your answer must be yes.
  8. I believe those bolts are TTY type.
  9. Hello, welcome to the forum. Does your vehicle have heated seats?
  10. Not necessary unless previous oil changes have been badly neglected, or the oil has been contaminated with coolant - I think most engine manufacturers state that flushing oil should not be used. In the case where flushing is thought to be required, use regular lube oil, then dump.
  11. I believe that some versions of the 1.4 also had ACT - but not used in Skoda's.
  12. Get the battery properly tested first, a rough test you can do yourself is to check the voltage at the the battery terminals (pref. with DMM) while the engine is being cranked. This test should ideally be done with the battery fully charged. The battery voltage should not drop below approx. 10.0 volts during the test, any reading significantly below this indicates the battery is failing. Adapting the battery (if replacing) is important and consists of entering the new battery capacity rating (Ahrs) confirming correct battery type, and changing the existing battery serial number - this informs the vehicles BCM of the replacement and should delete any registered battery defects that may be limiting the alternator charging rate.
  13. A question, a review I was reading referred to the return of the 1.4TSI for the 2017 FL - was the 1.5 dropped then?
  14. Hello, welcome to the forum. 2020 registration would definitely be a FL - I think the change from Mk3 to 3.5 was 2017.
  15. Hello, welcome to the forum. Are you able to source a diagram for the fuel transfer pump? I'd check to see what controls there are in the pump circuit. Failing that, I'd take another good look at the pressure sensor.
  16. Warrior193 replied to pinkpanther's topic in Skoda Karoq
    I thought there was a reference to a DIY raised trunk floor in the Projects thread a few years back.
  17. TSI on annual servicing - Mannol VW 504-507, previously used Fuchs, same standard.
  18. The only way is to have the DTCs scanned, there are so many faults that can trigger the MIL indicator.
  19. A pair of them is useful.
  20. Hello, welcome to the forum. Have the battery tested first (as suggested by Tilt) - If that tests out OK, check the ABS sensors as suggested by Berisford.
  21. Does the Mk2 Fabia use throttle by wire? Are you able to look at live data for throttle response?
  22. Hello, welcome to the forum. Have you checked the throttle body for possible sticky response?
  23. I still love my manual 2015 1.4, wouldn't change anything apart from wishing I had specced ACC and possibly, heated windscreen.
  24. Are they more the sort who prefer their designer labels to be on the outside by any chance?
