Bap33
Everything posted by Bap33
  1. Hi Graham, Good news! And.. Sorry for my ignorance, but what does this mean? (maybe just something I can't translate properly): 🤷‍♂️ And what is this ? I've never heard about this feature... 🤔
  2. Just have in mind that roughly 10000 aircrafts fly everyday with digidashes and some of these A/C have more than 20 y.o. This technology appeared in the 80's... For sure digidashes in cars are not dual-channel ones as in aircrafts to improve reliability and safety, but I think one can easily say, that's now a proven technology. 🙂 The first digidashes appeared in Superb Mk3 in 2018 for instance. They have now cumulated enough lessons learnt thru all VAG models to improve their reliability, I guess ;).
  3. Maybe my English was not good enough. But I don't see why your Superb would not work correctly. BTW, I did have to replace both front shock absorbers on my ex-Mk3 too... I just wanted to say that the comfort offered by a Superb Mk3 is high standard one. Thus don't be surprised if the Kodiaq is firmer. It's a SUV, it's not a 'mile-eater' as the Superb is... Otherwise, this Kodiaq seems to be well equipped and matches many of your search criteria, doesn't it?
  4. Hi, 3 news codings tested and confirmed: Display the fuel top-up quantity on the dashboard 17 – Instruments Coding – 07 / Long coding assistant codage long Byte 10 – Tick Bit 4 : Volume to be replenished, Yes Save Display the G-metre 17 – Instruments Coding – 07 / Long coding assistant codage long Byte 10- Tick Bit 2 : Display Acceleration Save Change the corner lights cut-off speed 09 – Central electrics. Security Access – 16 : 31347 / Adaptation – 10 Select "(16B) – Stationary cornering lamp -Upper speed threshold" Default value = 40.0 km/h Set new value = XX (60.0 km/h maximum To Be Confirmed) Save
  5. Be prepared to find the Kodiaq firmer. I had DCC on my ex-Superb Mk3 and have it on my current Kodiaq Mk1 too. There is a significant difference between both cars, whatever 'normal' and 'comfort' mode. The Superb was a 'magic carpet' on long trips. It absorbs all small road imperfections and bumps. You could hear them in the tires, but barely felt them. On some speed bumps in the neighborhood, I barely needed to brake. On the contrary, you can both hear and feel them in the Kodiaq. And on those same speed bumps, now it's better to brake, otherwise, you can get a bit juddered around. Nevertheless, it doesn't mean the Kodiaq isn't comfortable. The Superb is simply smooth where the Kodiaq is a bit firm. A test drive sounds a kind of GO / NO GO for you.
  6. Hi, Few new VCDS modifications tonight. But I didn't took time to check that they're working: - Display of the fuel tank top-up quantity on the VC - Display of the G-meter (very useful for my TDI 🤣) - Changed the corner lights cut-off speed (40 --> 60 km/h) I still have 3 more in mind, plus a 4th that seems stubborn (the coding is accepted, but nothing's happening 😬, I keep searching). Truth test tomorrow for today's 3... If they're OK, I'll update the dedicated post with VCDS mods. ;)
  7. If that's the point, then you should focus on FL version. Led headlights were not available on non-FL. BTW, I think AFS was available with Xenon, but once they introduced LEDs, the moved to matrix LED which replaces both AFS and Smart Light Assist. AFAIK FL version started in late 2021 or early 2022. I ain't no boy racer either, but as I wanted a 4x4 from 2022, TDI200 was the only solution for me. TDI150 4x4 was not proposed in FL version (at least in France). Thus, looking for a TDI150 4x4 with matix headlights may sound like looking for a unicorn 🙃. I fear you have to choose between Non FL TDI150 4x4 with Xenon headlights and AFS and FL TDI190 / TDI200 4x4 with Matrix LED headlights. Hope it helps refining your search criteria! Glad to see you soon in the Kodiaq Mk1 forum 😉 !
  8. A 500km trip today. I can confirm my "blue bear" behaves much better, when I need to rev up on lower gears. No more "groaning". It sounds like it has been "freed" a bit 😄. I guess this SW update has reset the DSG to factory settings and erased the self learning from the previous owner... Very pleased with that! 😃
  9. Hi, How old is the battery?
  10. Hi Graham, Also moving to the Kodiaq side? 😉😄 Do you really mean Mk2 or only FL version of Mk1? Mine is a MY2022, and thus a FL one. And it IS in L&K trim. I have to say I was lucky enough to find one with many options and very well equipped and therefore I fully understand you're hesitating to go from a L&K Superb Mk3 to a stripped down car... you'd regret your Superb... Otherwise nothing to add to recommendations above. Just one thing, what diesel engine had the one you've missed? Was it a TDI150, TDI190 or TDI200?
  11. Hi, Had the engine oil and oil filter changed today by my local dealer since my 'blue bear' has now 45000km on the clock. I had also asked for a Haldex oil change with Haldex pump strainer cleaning but there was a misunderstanding and they forgot to stock the Haldex pump o-rings and screws kit. This is thus postponed by the end of August. Not so bad... They also made an ECU recall action to update the SW. I'll pay more attention on next drives, but I feel like engine is less 'groaning' when I accelerate in lower gears. It's like it can accelerates more frankly, it's less linear. Since I've got it, I had sometimes the impression, that the handbrake was on (to some extent) when starting off at stop signs or traffic lights. As I also had trubbles with DriveGreen menu, I asked them if I was doing something wrong, since I had succeeded in activating the menu, but it didn't display anything. They told me it's normal, because the DriveGreen menu is not available anymore on Kodiaq Mk1 FL. The menu can be activated, but the SW code lines may have been removed. It doesn't display any score value anymore. No histogramms waving depending on foot pressure on the throttle. Neverminds...
  12. I've found it but not tested myself. I can MP it to you so you can check and confirm, if you want.
  13. Surprising that ACC might not be installed. AFAIK safety systems such Lane Assist, Front assist and ACC should be mandatory on brand new vehicles. Am I wrong... Or is it only applicable in EU? 🤔
  14. So am I... Curious that it grinds with all new...
  15. IMHO fear it's a bit more than "minor details" In the Superb MK3 forum (also MQB) there are 2 distincts threads for Non-FL and FL versions. I had noticed that some mods on FL aren't doable on non-FL. 🤷‍♂️
  16. As far as I understand your Kodiaq is a pre-FL, isn't it? Then if you intend to share your codings (which would be great 😃!), I suggest creating a dedicated thread, since codings may be different between Non-FL and FL versions. This has been done this way in the Superb Mk3 forum. I think it makes sense to find the right coding more easily and quickly. ;) TIA
  17. Hi, The 'new' one seems to be an older version compared to your original one: 11S vs. 12S on yours, as well as QFSD504B vs. QFSD504D. It may work, but you'll probably need to make SW update to get at least same performances as your original one. Note: I'm not an expert. Just guessing...
  18. Hi, Here are some modifications I've made with a genuine VCDS Hex-V2 on my MY2022 Kodiaq. /!\ DISCLAIMER /!\ I've made these mods alone. Some may be irrelevant for your Kodiaq (depending on MY, control unit HW or SW version, equipment, etc.). Don't attempt to duplicate them on your car if you don't know what you're doing. I'm not responsible for any damage on your car. If you're not sure, don't do it. Any changes are done entirely at your own risk Always save the original settings before attempting any mod! Enable 'Tear drops' wiping on front wipers: 09 – Central electrics. Security Access – 16 : 31347 / Adaptation – 10 Select "6B-Front_wiper – Traenenwischen Front Status" channel Old value = Not active New value = Active Save. 09 – Central electrics. Coding – 07 Select 2nd line in the drop down menu: "1-565 995119B – J400FRWISCH" Byte 0 – Tick Bit 3 “Adaptative Post/tear Wiping Active” Byte 2 – Tick Bit 5 “Post/tear Wiping Active” Old value = 104D0D New value = 184D2D Sauver Enable 'Tear drops' wiping on rear wiper: 09 – Central electrics. Security Access – 16 : 31347 / Adaptation – 10 Select "88-Rear_Window_Wiper – Traenenwischen Heck" Old value = Not active New value = Active Save. 09 – Central electrics. Coding – 07 Select 2nd line in the drop down menu: "1-565 995119B – J400FRWISCH" Byte 0 – Tick Bit 3 “Adaptative Post/tear Wiping Active” Byte 2 – Tick Bit 5 “Post/tear Wiping Active” Old value = 104D0D New value = 184D2D Sauver Enable Fan Level display on Climatronic 'Auto': 08 – Air Conditioning Coding – 07 / Long coding assistant Byte 11 – Tick Bit 6 : Blower Status Display in Auto-Mode active Sauver Old value = 16010104000410011105100D00109136 New value = 16010104000410011105104D00109136 Disable DRL when parking brake is ON: 09 – Central electrics. Security Access – 16 : 31347 / Adaptation – 10 Select "Außenlicht_Front - Tagfahrlicht Dauerfahrlich bei Handbremse abschalten" Old value = Not active New value = Active Save. Enable warning lights upon emergency braking: 09 – Central electrics. Security Access – 16 : 31347 / Adaptation – 10 Select "Aussenlicht_Blinker – Emergency alert blinken" Old value = Not active New value = Active Save. Enable Brake flashing lights upon emergency braking: 09 – Central electrics. Security Access – 16 : 31347 / Adaptation – 10 Select "Aussenlicht_Heck-Notbremsanzeige NBA" Old value = Not active New value = Active Save. Enable Heart-Beat light effect on Start Engine Button for Keyless: 05 – Access/Start Authorisation Security Access – 16 : 20103 / Adaptation – 10 Select "ZAT_illumination_concept_mybeat_clamp58xt » Old value = Not activated New value = Activated Save. Select "ZAT_illumination_modus_mybeat_clamp58xt" Old value = Not activated New value = Activated Save. Check number of Launch control on DSG gearbox: 02 Auto Trans Adv. Measures Type “Launch” in the search bar Tick "Anzahl Launch Control Anfahrt" Note the displayed value I have some more to test, but not done yet. Share your owns if you want.
  19. Hi, Take a look to the maintenance manual or Brake system manual. The way to measure brake pads thickness is described. You can buy required tools on Aliexpress for few quids. Additionally minimum thickness is given too of course. For instance, it was 2mm without the backing plate for my former Superb Mk3.
  20. With 2 bikes facing forward and 2 bikes facing backwards, removing the pedals may also help saving the very last centimeters. 😉
