Bap33
Everything posted by Bap33
  1. If you're car is 10 years old, it can't be a Mk3 but it's a Mk2. Most fault codes will probably be similar, but some of them might be specific to Mk2.
  2. Checked if my Mk3 is concerned by this Takata airbags story. Fortunately, it isn't! Maybe a useful link for all those who'd like to check too: https://recallactions.skoda-auto.com Take care.
  3. Another sleeper 😃, possibly a 'supercar-killer' (not all of them, but an interesting part 😄). I remember another Superb Mk3 owner who also went to stage 3 and reached 560HP : While looking for this video, I alos found this one up to 600Hp:
  4. Hi, If not changed from non FL : Pull the ACC stalk = +1 MPH / Km/h Press "Set" at the end of the stalk = -1 MPH / Km/h
  5. Mud flaps are accessories. They're not delivered in first mount, even as an option.
  6. Yes, it works much better on a PC (easier to read and ´surf’). Forget the phone…
  7. @KR15PY As far as I understand the fuzzy 2nd screen shot, You don’t go far enough Try this path: Welcome > Free services > CarProg2 Then select what is relevant in the different drop down menus (brand, model, model year, components group)
  8. Errr... I've been using this site for almost 20 years. I'm a Skoda owner since 2012, always found OEM Skoda P/N on this website when needed. Maybe a mistyping?
  9. ifinterface.com looks quite reliable and up to date. For instance, Superb Mk4, seems to be already in their database.
  10. Hi, My Skoda Superb was working fine these last days. Only fault known fault code was about AirQuality Sensor , which I changed in dec. 2023. I'm in touch with the Aftersales of the web site to have it replaced under warranty. Here is my problem description. Originally, I have 4 or 5 functions with tick boxes: - Lane Assist - Blind Spot - Rear Traffic Alert - Front Assist - Side Assist (Not sure for this one) But when I wanted to tick the Lane Assist, the menu had changed to - Lane Assist - Side Assist - Side Assist I've made a first autoscan: Code: Thursday,23,May,2024,23:45:56:04899 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 24.5.0.0 (x64) Data version: 20240429 DS355.0 www.Ross-Tech.com VIN: TMBLJ9NP0J-------- License Plate: Mileage: 116994km-72696mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type NP-SK48 (3Q0) Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 47 4B 52 5F 69 6C 6D 75 A5 BB BC CA VIN: TMBLJ9NP0J7533009 Mileage: 116994km-72696miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: OK 0000 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: Cannot be reached 0100 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 47-Sound System -- Status: OK 0000 4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 75-Telematics -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE ------------------------------------------------------------------------------- Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb Part No SW: 04L 906 026 MT HW: 04L 907 309 M Component: R4 2.0l TDI H25 3076 Revision: B4H25--- CVN: EFDCC7EBD45710C1 Coding: 011D0012047605083000 Shop #: WSC 33361 790 00109 ASAM Dataset: EV_ECM20TDI01104L906026MT 004001 ROD: EV_ECM20TDI01104L906026FN_004.rod VCID: 08317829B32018D60B-805C VINID: 91D49C6897A001A1C50C300024DAFE9304 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb Part No SW: 0D9 300 014 T HW: 02E 927 770 AS Component: DQ250-6A MQB H54 5202 Revision: 06454104 Serial number: TFK01708021627 CVN: 00001B0D Coding: 0014 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_TCMDQ250021 001001 ROD: EV_TCMDQ250021.rod VCID: 29771DAD48EA01DE34-807C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH Component: ESC H62 0743 Revision: 00000000 Serial number: 62577000002069 Coding: 1E076A9C34230B6F4777070040CC4978562CD0E2E0029275386150F8C2A9420000000012121212B835351919323200 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010 ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod VCID: 79D70DEDF8CA715E04-802C 1 Fault Found: 8364 - Databus U1122 00 [00001001] - Implausible Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 29 Reset counter: 123 Mileage: 116570 km Date: 2024.05.17 Time: 07:55:39 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G Component: VWKESSYMQB 037 0906 Revision: 00037000 Serial number: 0455510043 Dataset Number: V03935254SK 0001 Coding: 032C0C070F Shop #: WSC 33361 790 00140 ASAM Dataset: EV_KessyHellaMQBAB 004041 ROD: EV_KessyHellaMQBAB.rod VCID: 3E5DDEF1A164966671-806A Rear lid opener control module: 1 Fault Found: 65794 - Function Restricted due to Insufficient Voltage U1400 00 [00001000] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 143 Mileage: 116280 km Date: 2024.05.10 Time: 11:00:51 Terminal_15_Kessy_specified_value: On Terminal_15_Kessy_actual_value: On Terminal_15_central electric_actual_value: On Terminal_15red_Kessy_specified_value: On Terminal_15red_Kessy_actual_value: On Terminal_S_Kessy_specified_value: On Terminal_S_Kessy_actual_value: On Terminal_S_central electric_actual_value: On Terminal_50_Kessy_specified_value: OFF Terminal_50_Kessy_actual_value: OFF ZAT_pressed: OFF Park selector lever position: Engaged and locked Request active: Condition not met Enabling Steering Column Lock: Condition not met Enabling immobilizer: Condition met No active error mode: Condition met Key signature validity: Condition met Control Module Voltage: 8.653 V Driver information key position copy workshop: not active Driver information: roll warning: not active Driver information: emergency shutdown: not active Internal_key_position: no_message Driver information comfort switching: not active Vehicle speed: 0.0 km/h Engine RPM: 111.5 /min Status of vehicle locking: Vehicle unlocked Approach to the inside: not active Actuation to the inside: not active Approach to the outside: not active Actuation to the outside: not active Pulling actuation: outside door handle: not active Coding information: coded Approach to the inside: not active Actuation to the inside: not active Approach to the outside: not active Actuation to the outside: not active Pulling actuation: outside door handle: not active Coding information: coded Approach to the inside: not active Actuation to the inside: not active Approach to the outside: not active Actuation to the outside: not active Pulling actuation: outside door handle: not active Coding information: Not coded Approach to the inside: not active Actuation to the inside: not active Approach to the outside: not active Actuation to the outside: not active Pulling actuation: outside door handle: not active Coding information: Not coded Driver door: closed Front Passenger Door: closed Left rear door: closed Right rear door: closed Active_LF_scans: Init ID-sensor 1 authentication: status: No response ID-sensor 2 authentication: status: No response ID-sensor 3 authentication: status: No response ID-sensor 4 authentication: status: No response SPN_Byte 0: 00 SPN_Byte 1: 00 SPN_Byte 2: 00 ------------------------------------------------------------------------------- Address 08: Auto HVAC Cannot be reached ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG Component: BCM MQBAB H H36 0253 Serial number: 01001726400631 Dataset Number: V03935261XB 0001 Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_BCMMQB 018001 ROD: EV_BCMBOSCH_018.rod VCID: 09377D2DA82A61DE14-805C Wiper motor control module: Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB Component: 48x LL 170728 032 0121 Serial number: 00000001707240308713 Coding: 1E4DFD Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB Component: RLHS 047 0105 Serial number: S3Y17M09D20H23M56S04 Coding: 0088DF Blower 1 for left front backrest: Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0297558 Blower 1 for left front seat cushion: Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0297476 Blower 1 for right front backrest: Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0339294 Blower 1 for right front seat cushion: Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0339646 1 Fault Found: 204290 - Remote key 1 B1479 18 [00001001] - Current Too Low Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 103 Mileage: 116285 km Date: 2024.05.10 Time: 15:59:42 Terminal 15 status: OFF Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: operated Position lamps: Not operated Automatic high beam assist: Not operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: no cause for fault protection Voltage: 12.4 V Outside temperature: 24.5 ∞C ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb Part No SW: 5QA 919 294 B HW: 5QA 919 294 Component: PDC 8 KanalH07 0044 Serial number: 000308418617265 Dataset Number: V03935262KV 0001 Coding: 0471155951 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_EPHVA18AU3700000 009035 ROD: EV_EPHVA18AU3700000_009_AU37.rod VCID: 4BBB8725E2D633CEE6-801E 1 Fault Found: 13688835 - Databus U1123 00 [00001001] - Received Error Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 111 Mileage: 116570 km Date: 2024.05.17 Time: 07:55:40 ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C Component: ACC BOSCH MQB H04 0195 Dataset Number: V03935249LS 0001 Coding: 320067CA55FFC428949C8045 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_ACCBOSCHVW48X 001009 ROD: EV_ACCBOSCHVW48X.rod VCID: 354FC1DD9452553EA0-8060 No fault code found. ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A Component: DAEMPFUNGS-SG H17 0121 Serial number: 23081741350119 Dataset Number: V03935252TY 0001 ASAM Dataset: EV_DRCONTITEMIC 001019 ROD: EV_DRCONTITEMIC_VW37.rod VCID: 3851C8E98340A856BB-806C No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 5Q0 959 655 BK HW: 5Q0 959 655 BK Component: AirbagVW21 005 0336 Serial number: 003VXR38H597 Dataset Number: V03935255BD 0001 Coding: 98FCC0C0000000005C5400CF004800000065 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_AirbaVW20SMEVW37X 002158 ROD: EV_AirbaVW20SMEVW37X_VW37.rod VCID: 0A354221AD2C6AC61D-805E Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 480 001 709 17 Component: SideSensor_Df 001 0887 Serial number: 35700000000176FCF72. Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 480 001 709 17 Component: SideSensor_Pf 001 0887 Serial number: 3580000000029261D72F Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 480 402 009 17 Component: SideSensor_Dr 000 6149 Serial number: 3510001AB2644260F59+ Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 480 401 409 17 Component: SideSensor_Pr 000 6149 Serial number: 3520001C325187C123C- Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 480 401 309 17 Component: FrontSensor_D 000 6149 Serial number: 3550001AB270BC54866A Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 521 GE HW: 5Q0 953 569 A Component: Lenks.Modul 075 0235 Revision: FF035035 Serial number: 20170917500107 Dataset Number: V03935265ZH 0001 Coding: 6414 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_SMLSVALEOMQB 001015 ROD: EV_SMLSVALEOMQB.rod VCID: 7BDB17E5F2F6434E16-802E No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 3V0 920 711 B HW: 3V0 920 711 B Component: KOMBI 301 0310 Coding: 07A5081AFF840008018B7B0B5001000800000000 Shop #: WSC 73430 031 00140 ASAM Dataset: EV_DashBoardVDDMQBAB 009060 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 2F43F3B5760E6FEEEA-807A 2 Faults Found: 16777008 - Function Restricted due to Interrupted Communications U1110 00 [00001001] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 111 Mileage: 116570 km Date: 2024.05.17 Time: 07:55:44 16776982 - Databus U1121 00 [00001001] - Missing Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 111 Mileage: 116570 km Date: 2024.05.17 Time: 07:55:39 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C Component: GW MQB High 518 5304 Serial number: 17091710520284 Dataset Number: V03935258RY 0001 Coding: 030100345F087300EB0002DA9C0F00010001070000000000000000000000 Shop #: WSC 33361 790 00160 GVL: 01D63C0008000600C0DC80008002CC0010000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013023 ROD: EV_GatewNF_VW37.rod VCID: 334BFFC59A264B0E8E-8066 Generator: Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B Component: E221__MFL-PR6 H02 0160 Serial number: 000000000B0915010917 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K Component: J367-BDMHella H10 9070 Serial number: 1649925204 2 Faults Found: 131662 - Lane change assistant control module U1045 00 [00001001] - No communication [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 51 Reset counter: 123 Mileage: 116570 km Date: 2024.05.17 Time: 07:55:42 Terminal 30 power supply: 12.1 V Terminal 15: On 8531970 - Quiescent Current U1406 00 [00001000] - Too High [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 7 Fault Frequency: 22 Reset counter: 162 Mileage: 116280 km Date: 2024.05.09 Time: 00:51:44 Terminal 30 power supply: 12.1 V Terminal 15: OFF ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb Part No SW: 0CQ 907 554 J HW: 0CQ 525 130 Component: Haldex4Motion H52 7084 Serial number: HA1-00021.07.17 Dataset Number: v1260x015G0 0000 Coding: 0301 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_AllWheelContrHA1VW37X 004013 ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod VCID: 4CB98439E7D834F6EF-8018 No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb Part No SW: 3Q0 905 861 HW: 3Q0 905 861 Component: ELV-MQBB H05 0032 Serial number: 17000247550008 Coding: 0800000000000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_ELVMarquMQBB 001007 ROD: EV_ELVMarquMQBB_VW41.rod VCID: 71C735CDA0BA391EBC-8024 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J810) Labels:* None Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B Component: Sitzmemory H08 0022 Serial number: Y0006QIE10314 Coding: 001000020000050001C280808080000000008181000000D400 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_SeatMemorDriveSide 002021 ROD: EV_SeatMemorDriveSide_002_VW48.rod VCID: 3C59D4F9B77884765F-8068 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C Component: HRE_Master H12 0080 Serial number: 0454107103 Dataset Number: V03935251FB 0001 Coding: 00000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_HREntryHella 001028 ROD: EV_HREntryHella_SK48.rod VCID: 3D5FD9FDAC628D7E68-8068 Lane change assistance control module 2: Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C Component: HRE_Slave H12 0080 Serial number: 0453826901 Coding: 000000 3 Faults Found: 266752 - Control module not coded U1013 00 [00001001] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 267520 - invalid data record B2005 00 [00001001] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 51 267776 - Data Set Implausible B2012 00 [00001000] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B Component: TSG FS 011 0032 Serial number: 0000279145654 Dataset Number: V03935256LS 0001 Coding: 001D0920DE00040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod VCID: 47B3BB15FEBED7AEC2-8012 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E Component: MQB_PP_APA 204 2051 Revision: 00000000 Serial number: 0002000025 Dataset Number: V03935255ZZ 0001 Coding: 01000011004001 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_SteerAssisVWBSMQBA 009129 ROD: EV_SteerAssisVWBSMQBA_009_SK48.rod VCID: 40A1A009DB90E09603-8014 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:| 81A-035-466.clb Part No SW: 81A 035 223 HW: 81A 035 223 Component: MIB2_amp_P_SK H10 0410 Revision: 00000001 Serial number: SKZ8Z1HJE02T7CC Dataset Number: V03935263JW 0001 Coding: 0384020000AA002FAA0000000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001 ROD: EV_AMPMst16C5Gen2ALPI.rod VCID: 59976D6D580A515E64-800C No fault code found. ------------------------------------------------------------------------------- Address 4B: Multifunc. Module Interface not compatible. Please upgrade to a current Ross-Tech interface. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B Component: TSG BFS 011 0032 Serial number: 0000279001333 Dataset Number: V03935256LW 0001 Coding: 001D0320DE00040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod VCID: 46ADB611F9B4CEA639-8012 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb Part No SW: 565 035 043 A HW: 565 035 043 Component: MU-H-N-EU H54 1163 Serial number: A856E0HB011659 Dataset Number: V03935270DB 0001 Coding: 03840201000000005111000200080A002F0103E4012085009E Shop #: WSC 33361 790 00140 ASAM Dataset: EV_MUHig4CGen2HBAS 001001 ROD: EV_MUHig4CGen2HBAS_AU37.rod VCID: 10015049CB705016D3-8044 Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 3V0 919 606 D HW: 3V0 919 606 D Component: ABT_High-2 H52 9130 Serial number: SKZ6ZHV3001064 Data carrier: Subsystem 2 - Part No SW: V03 959 820 JK HW: ----------- Component: ECE 2023/2024 --- 0330 Serial number: -------------------- Compact disc data bank: Subsystem 3 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1016 Serial number: -------------------- 1 Fault Found: 7194 - Function Restricted due to Missing Message(s) U1111 00 [00001001] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 111 Mileage: 116570 km Date: 2024.05.17 Time: 07:55:59 Voltage terminal 30: 14.6 V BAP-BAP_Function_ID: 02 ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb Part No SW: 5Q0 907 383 M HW: 5Q0 907 383 M Component: Anhaenger H27 0260 Revision: 8B001004 Serial number: 0453918798 Dataset Number: V03935247XH 0001 Coding: 0100000202000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_TrailFunctGener2Hella 001008 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 41A7A50DD09AE99E0C-8014 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B Component: RVC Compact H12 0231 Dataset Number: V03935246QD 0001 Coding: 04840201A3002017000040 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009 ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod VCID: 3957CDEDB84AB15E44-806C No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J Component: HDSG-Modul H13 0261 Revision: -------- Serial number: 31544363000000 Dataset Number: V03935263DB 0001 Coding: 0D88 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DeckLidCONTIAU736 001014 ROD: EV_DeckLidCONTIAU736_VW37.rod VCID: 41A7A50DD09AE99E0C-8014 No fault code found. ------------------------------------------------------------------------------- Address 75: Telematics (J949) Labels:| 5QE-035-285.clb Part No SW: 5NA 035 284 B HW: 5NA 035 284 B Component: OCULowMQBLGE H17 0717 Revision: -------- Dataset Number: V03935265GS 0001 Coding: 03840201EA423A0D3B1C9E020045400382E608 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_OCULowMQBLGE 004044 ROD: EV_OCULowMQBLGE_004_VW32.rod VCID: 3C59D4F9B77884765F-8068 No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3QD 980 654 HW: 3Q0 980 654 A Component: MQB_B_MFK H08 1272 Serial number: 21081741P10043 Dataset Number: V03935268CJ 0001 Coding: 0204080200000401002623558150A90098000E100040 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_MFKBoschMQBB 001001 ROD: EV_MFKBoschMQBB_001_VW36.rod VCID: 08317829B32018D60B-805C 2 Faults Found: 1122649 - Databus U1121 00 [00001001] - Missing Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 123 Mileage: 116570 km Date: 2024.05.17 Time: 07:55:41 Control Module temperature: 15 ∞C Outside temperature: 11.5 ∞C Vehicle speed: 0.00 km/h System run time: 3.3 s Voltage terminal 15: 11.7 V mid: 02 0B Status of camera: operational Engine_Running_Info: 1 Software_Info_4: 2 Software_Info_3: 7 Software_Info_2: 2 Software_Info_1: 1 1275 - Front Sensors for Driver Assist B182E F0 [00001000] - Function Restriction due to Environmental Influences Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 120 Mileage: 116915 km Date: 2024.05.22 Time: 20:37:48 Control Module temperature: 36 ∞C Outside temperature: 18.5 ∞C Vehicle speed: 27.06 km/h System run time: 1115.4 s Voltage terminal 15: 13.8 V mid: 01 63 Status of camera: operational Engine_Running_Info: 1 Software_Info_4: 2 Software_Info_3: 7 Software_Info_2: 2 Software_Info_1: 1 ------------------------------------------------------------------------------- Address BB: Door Rear Drv (J388) Labels:* None Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B Component: TSG HFS 012 0032 Serial number: 0000278699949 Dataset Number: V03935256ME 0001 Coding: 001C01208000040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCURearDriveMAXCONT 006001 ROD: EV_DCURearDriveMAXKLO.rod VCID: 47B3BB15FEBED7AEC2-8012 No fault code found. ------------------------------------------------------------------------------- Address BC: Door Rear Pass (J389) Labels:* None Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B Component: TSG HBFS 012 0032 Serial number: 0000277609186 Dataset Number: V03935256MK 0001 Coding: 001C01208000040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCURearPasseMAXCONT 006001 ROD: EV_DCURearPasseMAXKLO.rod VCID: 47B3BB15FEBED7AEC2-8012 No fault code found. ------------------------------------------------------------------------------- Address CA: Sunroof Interface not compatible. Please upgrade to a current Ross-Tech interface. End-------------------------(Elapsed Time: 06:05)-------------------------- I then noticed the 3C - Lane change module was not coded anymore. I then put the original code 02012103, which I copied from a former error-free AutoScan. 4 functions came back: - Lane Assist - Blind Spot - Rear Traffic Alert - Front Assist But Side Assist function disappeared from the list, surprisingly... I then erased all fault codes to see which ones were remaining. I then got the following Autoscan: Code: Friday,24,May,2024,00:12:28:04899 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 24.5.0.0 (x64) Data version: 20240429 DS355.0 www.Ross-Tech.com VIN: TMBLJ9NP0J------- License Plate: Chassis Type NP-SK48 (3Q0) Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 47 4B 52 5F 69 6C 6D 75 A5 BB BC CA VIN: TMBLJ9NP0J7533009 Mileage: 116994km-72696miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: OK 0000 14-Susp. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 47-Sound System -- Status: OK 0000 4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 75-Telematics -- Status: OK 0000 A5-Frt Sens. Drv. Assist -- Status: OK 0000 BB-Door Rear Drv -- Status: OK 0000 BC-Door Rear Pass -- Status: OK 0000 CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE ------------------------------------------------------------------------------- Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb Part No SW: 04L 906 026 MT HW: 04L 907 309 M Component: R4 2.0l TDI H25 3076 Revision: B4H25--- CVN: EFDCC7EBD45710C1 Coding: 011D0012047605083000 Shop #: WSC 33361 790 00109 ASAM Dataset: EV_ECM20TDI01104L906026MT 004001 ROD: EV_ECM20TDI01104L906026FN_004.rod VCID: 08317829B32018D60B-805C VINID: 91D49C6897A001A1C50C300024DAFE9304 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb Part No SW: 0D9 300 014 T HW: 02E 927 770 AS Component: DQ250-6A MQB H54 5202 Revision: 06454104 Serial number: TFK01708021627 CVN: 00001B0D Coding: 0014 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_TCMDQ250021 001001 ROD: EV_TCMDQ250021.rod VCID: 29771DAD48EA01DE34-807C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH Component: ESC H62 0743 Revision: 00000000 Serial number: 62577000002069 Coding: 1E076A9C34230B6F4777070040CC4978562CD0E2E0029275386150F8C2A9420000000012121212B835351919323200 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010 ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod VCID: 79D70DEDF8CA715E04-802C 1 Fault Found: 8364 - Databus U1122 00 [00001001] - Implausible Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 2 Reset counter: 123 Mileage: 116994 km Date: 2024.05.23 Time: 23:51:21 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G Component: VWKESSYMQB 037 0906 Revision: 00037000 Serial number: 0455510043 Dataset Number: V03935254SK 0001 Coding: 032C0C070F Shop #: WSC 33361 790 00140 ASAM Dataset: EV_KessyHellaMQBAB 004041 ROD: EV_KessyHellaMQBAB.rod VCID: 3E5DDEF1A164966671-806A Rear lid opener control module: No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb Part No SW: 3V0 907 044 CP HW: 3V0 907 044 CP Component: AC Automat H34 4402 Revision: 20K10000 Serial number: 00000B00659263 Dataset Number: 0000 Coding: 1201010400041001100510410010112A Shop #: WSC 33361 790 00140 ASAM Dataset: EV_ACClimaPrehVW37X 002025 ROD: EV_ACClimaPrehVW37X_002_VW37.rod VCID: 04296C198F083CB667-8050 Humidity sensor: exterior: Rear air conditioning block 1: H02 0101 1 Fault Found: 263427 - Air Quality Sensor B10AF 29 [00001001] - Signal Implausible Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 2 Reset counter: 123 Mileage: 116994 km Date: 2024.05.23 Time: 23:49:32 Outside temperature: 20.0 ∞C Voltage terminal 30: 12.1 V System run time-Engine running time: 0 s System run time-Terminal 15 on: 253 s Air quality status: Clean air System run time-Engine running time: 0 s System run time-Terminal 15 on: 253 s ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG Component: BCM MQBAB H H36 0253 Serial number: 01001726400631 Dataset Number: V03935261XB 0001 Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_BCMMQB 018001 ROD: EV_BCMBOSCH_018.rod VCID: 09377D2DA82A61DE14-805C Wiper motor control module: Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB Component: 48x LL 170728 032 0121 Serial number: 00000001707240308713 Coding: 1E4DFD Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB Component: RLHS 047 0105 Serial number: S3Y17M09D20H23M56S04 Coding: 0088DF Blower 1 for left front backrest: Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0297558 Blower 1 for left front seat cushion: Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0297476 Blower 1 for right front backrest: Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0339294 Blower 1 for right front seat cushion: Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345 Component: SysNameFanLin 014 0101 Serial number: ESE0339646 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb Part No SW: 5QA 919 294 B HW: 5QA 919 294 Component: PDC 8 KanalH07 0044 Serial number: 000308418617265 Dataset Number: V03935262KV 0001 Coding: 0471155951 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_EPHVA18AU3700000 009035 ROD: EV_EPHVA18AU3700000_009_AU37.rod VCID: 4BBB8725E2D633CEE6-801E 1 Fault Found: 13688835 - Databus U1123 00 [00001001] - Received Error Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 2 Reset counter: 123 Mileage: 116994 km Date: 2024.05.23 Time: 23:51:02 ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C Component: ACC BOSCH MQB H04 0195 Dataset Number: V03935249LS 0001 Coding: 320067CA55FFC428949C8045 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_ACCBOSCHVW48X 001009 ROD: EV_ACCBOSCHVW48X.rod VCID: 354FC1DD9452553EA0-8060 No fault code found. ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A Component: DAEMPFUNGS-SG H17 0121 Serial number: 23081741350119 Dataset Number: V03935252TY 0001 ASAM Dataset: EV_DRCONTITEMIC 001019 ROD: EV_DRCONTITEMIC_VW37.rod VCID: 3851C8E98340A856BB-806C No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 5Q0 959 655 BK HW: 5Q0 959 655 BK Component: AirbagVW21 005 0336 Serial number: 003VXR38H597 Dataset Number: V03935255BD 0001 Coding: 98FCC0C0000000005C5400CF004800000065 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_AirbaVW20SMEVW37X 002158 ROD: EV_AirbaVW20SMEVW37X_VW37.rod VCID: 0A354221AD2C6AC61D-805E Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 480 001 709 17 Component: SideSensor_Df 001 0887 Serial number: 35700000000176FCF72. Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 480 001 709 17 Component: SideSensor_Pf 001 0887 Serial number: 3580000000029261D72F Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 480 402 009 17 Component: SideSensor_Dr 000 6149 Serial number: 3510001AB2644260F59+ Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 480 401 409 17 Component: SideSensor_Pr 000 6149 Serial number: 3520001C325187C123C- Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 480 401 309 17 Component: FrontSensor_D 000 6149 Serial number: 3550001AB270BC54866A Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 521 GE HW: 5Q0 953 569 A Component: Lenks.Modul 075 0235 Revision: FF035035 Serial number: 20170917500107 Dataset Number: V03935265ZH 0001 Coding: 6414 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_SMLSVALEOMQB 001015 ROD: EV_SMLSVALEOMQB.rod VCID: 7BDB17E5F2F6434E16-802E No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 3V0 920 711 B HW: 3V0 920 711 B Component: KOMBI 301 0310 Coding: 07A5081AFF840008018B7B0B5001000800000000 Shop #: WSC 73430 031 00140 ASAM Dataset: EV_DashBoardVDDMQBAB 009060 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 2F43F3B5760E6FEEEA-807A 2 Faults Found: 16777008 - Function Restricted due to Interrupted Communications U1110 00 [00001000] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 163 Mileage: 116994 km Date: 2024.05.23 Time: 23:54:08 16776982 - Databus U1121 00 [00001000] - Missing Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 163 Mileage: 116994 km Date: 2024.05.23 Time: 23:54:05 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C Component: GW MQB High 518 5304 Serial number: 17091710520284 Dataset Number: V03935258RY 0001 Coding: 030100345F087300EB0002DA9C0F00010001070000000000000000000000 Shop #: WSC 33361 790 00160 GVL: 01D63C0008000600C0DC80008002CC0010000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013023 ROD: EV_GatewNF_VW37.rod VCID: 334BFFC59A264B0E8E-8066 Generator: Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B Component: E221__MFL-PR6 H02 0160 Serial number: 000000000B0915010917 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K Component: J367-BDMHella H10 9070 Serial number: 1649925204 1 Fault Found: 131662 - Lane change assistant control module U1045 00 [00001000] - No communication [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 163 Mileage: 116994 km Date: 2024.05.23 Time: 23:55:02 Terminal 30 power supply: 12.2 V Terminal 15: On ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb Part No SW: 0CQ 907 554 J HW: 0CQ 525 130 Component: Haldex4Motion H52 7084 Serial number: HA1-00021.07.17 Dataset Number: v1260x015G0 0000 Coding: 0301 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_AllWheelContrHA1VW37X 004013 ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod VCID: 4CB98439E7D834F6EF-8018 No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb Part No SW: 3Q0 905 861 HW: 3Q0 905 861 Component: ELV-MQBB H05 0032 Serial number: 17000247550008 Coding: 0800000000000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_ELVMarquMQBB 001007 ROD: EV_ELVMarquMQBB_VW41.rod VCID: 71C735CDA0BA391EBC-8024 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J810) Labels:* None Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B Component: Sitzmemory H08 0022 Serial number: Y0006QIE10314 Coding: 001000020000050001C280808080000000008181000000D400 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_SeatMemorDriveSide 002021 ROD: EV_SeatMemorDriveSide_002_VW48.rod VCID: 3C59D4F9B77884765F-8068 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C Component: HRE_Master H12 0080 Serial number: 0454107103 Dataset Number: V03935251FB 0001 Coding: 02012103 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_HREntryHella 001028 ROD: EV_HREntryHella_SK48.rod VCID: 3D5FD9FDAC628D7E68-8068 Lane change assistance control module 2: Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C Component: HRE_Slave H12 0080 Serial number: 0453826901 Coding: 020121 3 Faults Found: 267520 - invalid data record B2005 00 [00001001] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 Reset counter: 123 Mileage: 116994 km Date: 2024.05.23 Time: 23:58:42 267776 - Data Set Implausible B2012 00 [00001000] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 Reset counter: 163 Mileage: 116994 km Date: 2024.05.23 Time: 23:58:42 338032 - Databus U1123 00 [00001001] - Received Error Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 123 Mileage: 116994 km Date: 2024.05.23 Time: 23:58:42 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B Component: TSG FS 011 0032 Serial number: 0000279145654 Dataset Number: V03935256LS 0001 Coding: 001D0920DE00040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod VCID: 47B3BB15FEBED7AEC2-8012 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E Component: MQB_PP_APA 204 2051 Revision: 00000000 Serial number: 0002000025 Dataset Number: V03935255ZZ 0001 Coding: 01000011004001 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_SteerAssisVWBSMQBA 009129 ROD: EV_SteerAssisVWBSMQBA_009_SK48.rod VCID: 40A1A009DB90E09603-8014 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:| 81A-035-466.clb Part No SW: 81A 035 223 HW: 81A 035 223 Component: MIB2_amp_P_SK H10 0410 Revision: 00000001 Serial number: SKZ8Z1HJE02T7CC Dataset Number: V03935263JW 0001 Coding: 0384020000AA002FAA0000000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001 ROD: EV_AMPMst16C5Gen2ALPI.rod VCID: 59976D6D580A515E64-800C No fault code found. ------------------------------------------------------------------------------- Address 4B: Multifunc. Module Interface not compatible. Please upgrade to a current Ross-Tech interface. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B Component: TSG BFS 011 0032 Serial number: 0000279001333 Dataset Number: V03935256LW 0001 Coding: 001D0320DE00040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod VCID: 46ADB611F9B4CEA639-8012 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb Part No SW: 565 035 043 A HW: 565 035 043 Component: MU-H-N-EU H54 1163 Serial number: A856E0HB011659 Dataset Number: V03935270DB 0001 Coding: 03840201000000005111000200080A002F0103E4012085009E Shop #: WSC 33361 790 00140 ASAM Dataset: EV_MUHig4CGen2HBAS 001001 ROD: EV_MUHig4CGen2HBAS_AU37.rod VCID: 10015049CB705016D3-8044 Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 3V0 919 606 D HW: 3V0 919 606 D Component: ABT_High-2 H52 9130 Serial number: SKZ6ZHV3001064 Data carrier: Subsystem 2 - Part No SW: V03 959 820 JK HW: ----------- Component: ECE 2023/2024 --- 0330 Serial number: -------------------- Compact disc data bank: Subsystem 3 - Part No SW: V03 959 800 EG HW: ----------- Component: Gracenote2 --- 1016 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb Part No SW: 5Q0 907 383 M HW: 5Q0 907 383 M Component: Anhaenger H27 0260 Revision: 8B001004 Serial number: 0453918798 Dataset Number: V03935247XH 0001 Coding: 0100000202000000 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_TrailFunctGener2Hella 001008 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 41A7A50DD09AE99E0C-8014 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B Component: RVC Compact H12 0231 Dataset Number: V03935246QD 0001 Coding: 04840201A3002017000040 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009 ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod VCID: 3957CDEDB84AB15E44-806C No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J Component: HDSG-Modul H13 0261 Revision: -------- Serial number: 31544363000000 Dataset Number: V03935263DB 0001 Coding: 0D88 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DeckLidCONTIAU736 001014 ROD: EV_DeckLidCONTIAU736_VW37.rod VCID: 41A7A50DD09AE99E0C-8014 No fault code found. ------------------------------------------------------------------------------- Address 75: Telematics (J949) Labels:| 5QE-035-285.clb Part No SW: 5NA 035 284 B HW: 5NA 035 284 B Component: OCULowMQBLGE H17 0717 Revision: -------- Dataset Number: V03935265GS 0001 Coding: 03840201EA423A0D3B1C9E020045400382E608 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_OCULowMQBLGE 004044 ROD: EV_OCULowMQBLGE_004_VW32.rod VCID: 3C59D4F9B77884765F-8068 No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3QD 980 654 HW: 3Q0 980 654 A Component: MQB_B_MFK H08 1272 Serial number: 21081741P10043 Dataset Number: V03935268CJ 0001 Coding: 0204080200000401002623558150A90098000E100040 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_MFKBoschMQBB 001001 ROD: EV_MFKBoschMQBB_001_VW36.rod VCID: 08317829B32018D60B-805C No fault code found. ------------------------------------------------------------------------------- Address BB: Door Rear Drv (J388) Labels:* None Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B Component: TSG HFS 012 0032 Serial number: 0000278699949 Dataset Number: V03935256ME 0001 Coding: 001C01208000040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCURearDriveMAXCONT 006001 ROD: EV_DCURearDriveMAXKLO.rod VCID: 47B3BB15FEBED7AEC2-8012 No fault code found. ------------------------------------------------------------------------------- Address BC: Door Rear Pass (J389) Labels:* None Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B Component: TSG HBFS 012 0032 Serial number: 0000277609186 Dataset Number: V03935256MK 0001 Coding: 001C01208000040000001100 Shop #: WSC 33361 790 00140 ASAM Dataset: EV_DCURearPasseMAXCONT 006001 ROD: EV_DCURearPasseMAXKLO.rod VCID: 47B3BB15FEBED7AEC2-8012 No fault code found. ------------------------------------------------------------------------------- Address CA: Sunroof Interface not compatible. Please upgrade to a current Ross-Tech interface. End-------------------------(Elapsed Time: 05:51)-------------------------- After that both Blind Spot and Rear Traffic Alert functions can't be ticked anymore. Functions are said to be unavailable on the dashboard screen. Here is my first understanding and analyses. 03-ABS / U1122 Based on the following link U1122, I'd be tempted to ignore it, though dealing with an Audi Q3 3C-Lane change instead of Superb 03-ABS. 08-Auto HVAC / B10AF Already known. Due to Air quality Sensor. Replacement about to be done (see comment above) 10-Park/Steer Assist / U1123 I don't understand, where it can come from. I haven't found anything similar on this forum. Could it be related to loss of Lane Change, Blind Spot and especially Rear Traffic Alert? 17-Instruments / U1110 I assume this one is generated by the loss of Blind spot and Rear trafffic systems But not sure. 17-Instruments / U1121 I assume this is the same as above 19-CAN Gateway / U1045 I assume this one is generated by the loss of Lance change, Blind spot and Rear trafffic systems 19-CAN Gateway / U1406 (not in this scan, but appears sometimes) I've found this thread: https://forums.ross-tech.com/index.php?threads/27719/ which looks similar, because I've installed a dual dashcam (front & rear) in november. I've looked at former scans and it appeared more or less once dashcams wre installed. I'll follow the test to see if they draw too much current. 3C-Lance change / B2005 Could it be because I pasted the original code myself? 3C-Lance change / B2012 Same as above? 3C-Lance change / U1123 Could it be related to loss of Lane Change, Blind Spot and especially Rear Traffic Alert? I've posted the same thread on ross-tech forum. I've got the folowing answers from there: "3C - Lane Change has "invalid data record" and "Data Set Implausible". No coding is going to fix that. Having a dealer SVM the thing should get it the correct parameterization." Regarding other fault codes being a consequence of these B2005 and B2012 codes, they answered: "I can't be sure (in part compounded by the fat that you're using a legacy interface on a car which it isn't fully compatible with) but I think the majority of those should resolve once the 3C-Lane Change module is happy again." Sorry for this looooong post, thank you for reading until the end. All advises are welcomed. I don't really know how to go further, except going to my local dealer... I assume it can be fixed in less than an hour if it's just a SW issue and should not cost that much... But I don't know whether this could be a HW issue too. All tips much appreciated. Thanks in advance.
  11. Thanks. I discovered this 1 or 2 years after I switched to my Mk3. I don't know if this is allowed in France. Anyway, time has passed by and I currently have only 1 Group 2/3 in my car. So this is not an issue anymore for me...
  12. I also had the opportunity to sit in a Mk4 on Tuesday by my local dealer. Here a MHEV 1.5 TSI L&K spec: Outside looks more massive than Mk3, especially the bonnet. Front grill is more vertical and higher, and bonnet is looks more voluminous Rear also looks more massive Centre screen is big. The 3 knobs on the contre console look OK, but they sound pour quality when you rotate them Engine seems to be pushed backwards and distance between front end and radiator looked very important... New Kodiaq 2 had sole arrived but it was locked... .
  13. Hi, On front brake discs, it seems that you can replace them easily. They're jist fixed with 3 screws (whose torque is 12Nm). On rear brake discs, it looks like you need to remove the hub... But this needs to be confirmed. I'm not a specialist.
  14. It IS indeed. One of the argues to change from Mk2 to Mk3 was the width between armrests for rear passenger. Having 3 children, I knew I would face trouble to install 3 child seats in a row (2 Group 2-3 + 1 Group 1-2-3) in the Mk2, when my youngest was about to switch from Group 0+ to Group 1. There are actually 3-4 more cm in the Mk3, which make "all" the difference. No problem to put all 3 child seats.
  15. A critical point then, unless buying a HEX Net version. But I don't know if it still comply with the £300 budget.
  16. Previous and current cars when the new one had just arrived at home: Mk3 doesn't look much bigger than Mk2...
  17. Hi, A VCDS Hex V2 without any accessories (Box + USB) will be within your budget and will offer full access, including unlimited software updates and support from Ross-Tech.
  18. Unfotunately, it looks like time has pushed Skoda to higher prices standards over years... 😬
  19. Waste reduction, maybe? A subject I'm thinking to consider...
  20. I agree, the VAG recommendation at 90000 km is huge. this why I replace it every 30000km (without dusting it at 15000km). It's not very dirty at 30000km and I think I could simply dust it with my compressor to make it last a bit longer. Mays be dust every 15000 and replace it at 60000km. But I'm lucky enough to face quite fair road and climate conditions on my usual trips. Not very dusty.
  21. Without saying the electrical battery for the PHEV part won't last 17 years IMHO.
  22. I can't too. This could be where the OEM reference is. But those pointed by @skomaz are incredibly similar...
  23. You change the air filter every 15000 km? It sounds a very low mileage. I do it every 30000km, whereas AFAIK Skoda recommends a replacement every 90000 km (on TDIs).
  24. You may think you did write it in your original post, but you didn't... But now we know 😁. I assume you have a 4x4 version if you speak about a DQ381. Otherwise it's a DQ380. But we still don't know engine version, nor MY...
  25. I phoned my (french) local dealer for another subject this evening. He told me (BTW), he had received a new Superb Mk4 and a new Kodiaq Mk2. Maybe I'll get there tomorrow to see both... 😃
