Bap33
Everything posted by Bap33
  1. @Duggerchopz MTEC Superwhite are probably what you’re looking for. πŸ˜‰ Have a look here :
  2. I had this done by my dealer last week. But no iimprovement. The open / close buttons on my smartphone are hidden by the lock status display... Very strange. πŸ€”
  3. Retrofitting the right Scout suspension with correct height is a good point. But IMHO going without the specific plastics kits on wings would lead to a very strange look. Too high on its Β« legs Β».
  4. I know it would take time to scroll them all, but it may appear somewhere in the VCDS thread pinned on the 1st page.
  5. I assume he means something like β€˜US’ mode... May be possible with VCDS, but no idea with OBDelen πŸ€”
  6. Oups sorry for the confusion about A5 camera... I should have mixed with some other spec.... There are a lots of OEM spare parts website. Otherwise your local dealer is the best solution.
  7. OK. thanks for the feedback !
  8. One important equipment required for ACC is the A5 front camera. If you don’t have, it is possible, but a big job if you want to get at the OEM integration level. If you have TSR, you already have A5 camera. It will be then much easier to retrofit ACC. You have made the right list if needed things for this case.
  9. @andymurray88 Did you have a look to "colorlock" products? They are often used for detailing to recover "brand new" aspect. Should be much cheaper than new spare parts.
  10. @bubib5 Does it look like this on your Mk3? Here on an Octy3 Though in german, one can understand what's going on...
  11. Did you pull inadvertently on the lever so that the gearbox is in S mode, though DCC in Eco mode ? May be worth to check. Gears will appear in S1, S2, S3... on the center display or VC, if this is true.
  12. Why didn't you tick the 2nd Byte? - Byte 9 / Bit 6 (supposed to be 'Easy entry front over MMI'). May be a reason of this 'malfuncton'?πŸ€” Additionally, there's another adaptation to do: 5F - Information-electric > 10 Adaptation. Select channel: 'ENG 122227_ENG 117556 Car Function adaptation - Gen2 Menu_display_seat_configuration' and chose 'Active'. This should allow to enable/disable this 'Easy Entry' function directly from the Columbus.
  13. What do you mean by third service?
  14. I would make the same suggestion on MY2020. Problem = Back to the dealer to fix it under warranty.
  15. That's the main driver to define which one it is, indeed !
  16. For those who want see, what the MTEC SuperWhite look is... Here are 2 pics to compare the Front Fog lights upgrade with standard Beams. Sorry, the car is dirty these days... @Acrab I hope, this answers your request.
  17. Do you have any picture to share? I'm curious to see how it looks like.
  18. Gret tot read you again! I cross fingers too, so that they sort it out.
  19. I'd like to, but there is not single box to tick! And 'going blind' is not my cup of tea...
  20. Hi, I'm struggling with enabling Easy Entry function. On controle module "36- Seat-..." I need to modify the "Long Coding". In "07-Coding" menu, whatever the Byte is, there's no single description on all bits. There's no box to tick. Is there any reason I don't have any description? (I'm using VCDS w. SW 21.9 version) Thanks for your help. Apparently, I need to tick: - Byte 3 - Bit 1 (supposed to be 'Easy entry') ; and - Byte 9 / Bit 6 (supposed to be 'Easy entry front over MMI'). Does anyone have enabed this function? Could you confirm the boxes to tick? Thanks!
  21. I think it was in 2018. But it needs to be confirmed.
  22. What do you call 'whiskers'? Sorry, still not a native english speaker. ^^
  23. @pwb Oh yes, sometimes, this website is capricious. Just try using another web browser or... try later.
  24. @J.R. Thanks. I'll send you a list of french to translate into English. @Danoid. There will be pics, for sure, but sometime, it's better to write explanations to go with the pics.
  25. You can download all workshops manuals for free on cardiagn.com.
