Everything posted by Bap33
Mistyping or definitely a size out of specs? I think 35 is the right side wall height for 255 wide tyres. 🤔
fuel tank capacity
Yes, of course ! Posted too quickly. 😉
fuel tank capacity
Actually, it should affect the fuel tank capacity, since it is located under the rear passengers seats, thus far from the towing system.
- How to remove A-pillar trim panel / How to replace retainer for park tickets on Superb Mk3
Is Columbus trying to kill me?
You’re right! I’ve discovered something missing on my mk3 last week. I had left it at my local dealer to fix a problem of play in the driver's seat slide. They replaced both slides, but they forgot to put back the 4 slide ends covers! 🙄 Since this happened already weeks ago, it’s hard to prove it. Thus I’ll have to buy all 4 for about 20-25€! 🤬
Questions re:2017 superb dsg 190ps combi
Good point if still covered by warranty !
I would have suggested the same. I understand that your wipers experience is nerving you (It would probably nerve me too). But don’t forget that the community is simply trying to help you. Sharp answers are not mandatory. 😉
Hmmm I had thought, it could be caused by a fuel filter starting being clogged. But since the fuel filter change is only recommend at 90000 km. I have to discard this hypothesis... 🤔 Sorry, still no idea. Did you check if there is any fault code with VCDS?
Same configuration, sorry, never faced that. What’s your mileage?
Myskoda App
Back to operation this evening. The only thing is that the Superb picture on the home page doesn’t correspond to my car configuration anymore as it used to be until last week 🤔 Strange.
Myskoda App
Have been trying to launch the app for 2 days, but I don’t get anything else than the Skoda logo on a black background... 🙄
I think you may need to break 2 or 3 centering pins from the emblem back before sticking it onto the bodywork. To be confirmed...
VCDS options on Superb III
@Ivan8192 I like the idea. Will probably do that.
@langers2k No worry. Just good to know... My wife intends to replace her Audi Q3 Mk1. If she gets another VAG vehicle, I will upgrade my current cable to a HEX version...
Skoda Superb Estate Mk3 4x4
Interesting. And what was the braking efficiency in such conditions?
Oh Thanks !!! Unfortunately, if I get it right, it won’t work with my MicroCAN cable... Only possible with HEX versions...
@Hdsn555 & @AlVal Coming to the 30-color VCDS script, how do you upload such a script in the system? I’ve found the list-2 to set colors 11 to 30, but I don’t feel patient enough to modify 60 lines individually... and then modify the 30 lines of the 10 original colors to get something homogenous... Thanks for your explanations.
Though I had spent ~3 years without losing any of them, I noticed that at least 1/4 of them were loose, while cleaning my winter wheels with a pressure washer before switching to summer wheels... 3 of them even suddenly popped out... Probably scared by the pressure washer... I've got bored. I bought the few missing caps and then removed and stored all of them in the spare wheel well... Now, they can't escape!
Intensive cleaning of the intrior this afternon. It has been way too long I didn't do ti. Sprayed the front and back seats with Leather conditioner & cleaner from Chemical Guys. Satisfied with the result, the seats are now correctly moisturized, with a satin looking and a pleasant soft touch. Also tried these 3D Shadow bulbs on the front doors. A gift from a friend owning a Sportline. He thought a needed 4 bulbs for his Sportline, when he discovered, there were no lights on the rear doors.. May be a bit "too much" for my taste. But I would appreciate the same without the Skoda Logo...
Interesting. It seems to be quite a recent change in Skoda sales policy... or may be just a question of country-dependent strategy... I don't think this apply to France... I'm going to check that. Thanks for the tip !
It's kind of expendable. Warranty would not cover it anyway.
Accident Data Recorder
I have this on my MY2017, but good to know ! Especially for those who intend to have their Superb remapped..
MK3 hitch load sensor
I had a look to this menu. But I don't see anything referring to towing load or hitch load (Also a MY2017 with DCC). @J.R. You seem really sure of what you write. May I know, where you get your information from? Not looking for controversy, just curious.
Phoenix vs Trinity alloys
The name was done at the end of 2017 (at least in France). Mine was built in november 2017 and "glossy black Trinity" were mentioned on the PO at this time.
Interesting. I also have a trailer hitch (from factory), but I never had this message on the Maxi DOT. I assume the load on the hitch could be assessed with the pitch angle, which may be measured either by front beams (if Xenon equiped) or by DCC system. The latter one has sensors on both suspension arm. It's used for the control loop of the system. These sensors could assess the hitch load depending on the rear axle height variation. Just guessing... Regarding the trailer load, I'm much more curious on how it could be assessed...
