komoornik
Everything posted by komoornik
  1. Lol, my 0324 just started doing the same. But it was running fine since I updated it manually for quite some time. Sounds like maybe one of the OTA updates broke something.
  2. You can update software yourself. Newest one is currently 0324. Some tips:
  3. It doesn't work on newer cars. Not sure since when exactly, but I can confirm the same with MY21.
  4. It can be cleared with any diagnostics tool capable of doing that. I'm not 100% sure but it might be the reason.
  5. It might be due to the stored error in the ACC control module.
  6. This is not GPS based for sure. Setting is either there or not. If it's not, like mentioned above perhaps it can be coded.
  7. I have passenger memory seat, will take a look if i will remember to do it ๐Ÿ˜ƒ Are you planning retrofit? Are you aware you would need to replace the whole seat (or all motors)?
  8. There are coasting settings in drive profiles so this can be edited with dataset of gateway.
  9. It's doable - but like mentioned, with a dataset modification ๐Ÿ˜‰ https://www.youtube.com/shorts/A5Ge0qKtHto
  10. And I am totally against it, while on auto hold the brakes are applied thus the brake lights should be on ๐Ÿคจ
  11. There seem to be an adaptation for that. https://forums.ross-tech.com/index.php?threads/5104/#post-50529
  12. That's kind of how Superb is. The seating position is not so low, also the windshield is on the smaller side with a more specific angle - that's how they managed to squeeze so much space inside (back seat, boot) compared to even Passat. Manually adjustable seats seem to go a bit lower then electric ones.
  13. I went from stock 18" to slighly smaller diameter 205/60/16. And i went for eGolf aero rims.
  14. I went from stock 18" to 16", also got a bit lowered tire pressure (2.2 bar) - ride quality is superb. I also get a great fuel economy most likely due to the tires being narrower.
  15. Is the app only available for specific MY? I don't see it on mine MY22.
  16. Mu ugly L&K with my fun car in the background ๐Ÿ˜‰
  17. It has to do with the ignition. Ignition off it's one time press, ignition on you have to press and hold.
  18. Both work nicely. AA in newest MY gets integration with Virtual Cockpit, Carplay doesn't.
  19. Why do you plan to sell it in UK, and not in France? ๐Ÿคจ
  20. Topic is AA vs Carplay, what did you mean by writing Android/Google Maps? That forward slash means to me Android (so Android Auto) is Google Maps. What sense does it make to write about Google Maps if it can be used on both AA and Carplay?
  21. Apple maps does not work with Carplay? I wrote that Google Maps work with Carplay. And also "Android/Google Maps is probably still better at navigation" - compared to what? And why did you write Android/Google Maps if Google Maps work on Carplay? ๐Ÿคจ
  22. Carplay works with Google Maps - so that's not really an argument ๐Ÿ˜‰
  23. It's not really a lot of work. It's quite well documented, you just need the right tools for it. And to be honest it's the thing I just had to do on my car - becauses I hated pressing that mode button each start ๐Ÿ˜€
  2. Tap Permissions โ†’ Notifications.
