Alasdair1
Joined
Last visited
Currently
Viewing Topic: Auto Start-Stop not functioning
Electric window dropped
Same happened to me . Cable came loose and wrapped itself around motor drive mechanism. Bit of a hassle to remove but managed eventually. I got a repair kit from ebay and fitted it. It was one that didn't come with the steel door card. Not too bad a job but my steel door panel was riveted so had to drill them out. You need special rivets which are pretty heavy duty tto attach the metal plate to the door From memory they are 6.4 x 10 and have circular cut outs along the rivets. Normal are I think 6.2 and dont give a decent hold. I had to get a heavy duty double handed pop rivet gun to do the job as my lazzy riveter didnt have the larger end nozzle. Some of the early ones had bolts but mine was riveted. Sorry cant access ebay at moment to send you any links. Alasdair
A car thats only done 1000 miles in 4/5 yrs due to owner being ill
As long as the rear brakes work and are even then it usually passes MOT with an advise on discs. Mine were like that and I did replace them anyway. I have had 3 coil springs go on cars that have been sitting for months. Mechanic mate said they find it happens a lot. Maybe the springs get brittle over time when not being used. Not sure if its a timing belt or chain. If its a belt get it changed plus waterpump when your at it. If its a chain check the replacement interval. I normaly do my belt every 50000 or every 5 years depending which comes soonest. My 08 1.9tdi is bad with rust on the subframe and sills but so far its just been an advise. Check bushes in rear swing arms as well as mine are failing and causing rear tyre wear. I just replaced the tyres on my sons fabia for exactly the same reason. Had a flat and the tyre service I use policy is they wont fix tyres that show cracking or over a certain age. 4 new tyres is a lot cheaper than having a blow out and if there really bad lots of points if you get caught Alasdair
Sudden loss of all gears. Car just revs in all gears with no drive.
UPDATE. Got the car finally into workshop on a flat level concrete floor. It will move forward in first very very slowly. The drive is so weak you could stop it with one finger at mid revs and also same in reverse but still no drive. Wont move at all in 2nd -5th Bled clutch and today took slave cylinder out and it seems ok. I can push it in without restriction so rod not seized in out position. (going to replace it as the rubber internal gaitor is split). I can also push lever that operates clutch with a lot of force and it springs back so clutch spring is still good. Still to check drive shafts which seem solid and rotate when pushing car back and forward. but reckon its either Diff or clutch so first planning to check shafts etc. and make sure there still connected and not broken or damaged and if there ok its gearbox out time unless I am missing something. Never had a problem like this. Normally when a clutch fails it slips before hand or totals the bell housing/flywheel and weird thing there was no noise before it happened. If anyone has any ideas what else I could check I would very grateful. Alasdair
Gearbox code fabia 1.2 htp 2006
Many thanks. I was getting confused and not having PR sticker doesnt help. Not sure which has gone. All gears failed yesterday changing down. Still trying to work out whats gone. wrong. No sounds from box or previous slipping. Its as though the clutch just didn't disengage. Pedal feels fine and bled system today but nothing. Very slight rumble when in gear and very slight amount of clutch when in 1st or reverse but not enough to move car?? Looks like its a gearbox out to see whats wrong. Cars done 70000 Thanks again
Thanks for the reply VIN is TMBPY46Y064548528 Reg is GL55KJE Alasdair
Hi there looking for the gearbox code for a 1.2 fabia HTP 2006 hatchback. Think the engine is BME but PR sticker is missing from boot. Is it stamped on the gearbox itself and if so where about? I either need a new gearbox or new clutch but need to find code. So far narowed clutch down be either a 190mm or 200mm clutch depending on VIN Thanks Alasdair
Pressure bled clutch and fluid was not good. Almost green/brown in colour. Kept bleeding till I got nice clean fluid through but still no joy or any air. Pedal goes to the floor and comes back ok. Could it be the slave actuator being stuck in the out position and not fully returning ? Don't think the clutch is adjustable.
Another point. Was trying to change gear with and without out clutch depressed and seems to engage. Grinding noise without clutch depressed when going into reverse so gear box seems ok and its actually shifting into gear but no drive so looks like a clutch related problem? Will try and bleed cluch system to see if that helps.
Hi there, Quick update. Car is on level ground now and if in first gear is just trying to move forward very very slightly (about 1-2cm) when revving and slight noise from I assume clutch area . Slight rumble but no major noises The higher the gear the less it moves Nothing in 5th . Rocked it back and forward and drive shafts moving but no resistance in any gear. Could this be a completely failed clutch pressure plate or something jammed to stop the clutch disengaging? Not sure how to check Alasdair
I just replaced front wheel bearing and didn't touch the drive shaft/gearbox end. As said cars been fine f0r 10 days. Theres no noise when idling and the pedal hasn't dropped or changed pressure. The gear linkage seems to be operating and the gearstick is smooth into all gears but car feels like its in neutral. There have been no CV noises etc either and no sign of clutch slipping before loss of gears. Reckon it might be the gear selector shaft inside the gearbox.
No don't think so. Its been on the road for about 10 days plus an MOT since I did it and everything looks in place. Just wondering if the gear selector shaft is broken internally? or the clutch is completely non existant.(Never had a clutch fail like this before slipping or any warning but who knows) Going to get it moved undercover tomorrow and have a proper look. Will try and see if its actually in gear but no clutch or if its stuck in neutral even though the selector seems to work. Alasdair
Did think of that. Had an old landrover 110 that snapped a drive shaft and wouldn't move. I Replaced front wheel bearing last week for MOT but everything seems in place and drive shafts seem solid. It did feel like it was trying to move very slightly when reving but could have been imagination as it was on a hill which would point to complete clutch failure but no sudden noises or bangs just before it stopped driving and no burning smell either and no previous signs of a slipping clutch. Will have a closer look tomorrow in daylight. I am thinking its either a gear selector shaft problem or the clutch pressure plate/ release bearing has failed sudddenly or master/slave stuck which isn't impossible but very unusual. I will jack both sides up and see if I can turn wheels when in gear. I assume turning one should make the other turn if the gears are engaged. It just feels as though its either in Neutral or there is no friction on the clutch. No oil or fluid leaks either. Got me stumped Alasdair
Thanks for the reply. Gearbox selector shaft is still connected to selector mechanism on top of gearbox and moves up down etc when selecting gears so I assume it may be an internal problem. Either that or the clutch has not re engaged but not sure how that could happen . Pedal feels fine and doesn't sink to the floor. If I manually move the selector mechanism cables on top of gear box it moves the selector shaft up and down etc but still no drive at all just revs. Alasdair
Hi have a Skoda fabia MK1 1.2 and the gears have all gone. Gear selector seems to be working as the cables to gearbox are moving. Clutch feels normal but car just revs when in any gear including reverse. No previous signs of clutch slipping and no hydraulic leaks. Its done 70000. Son was driving and said he changed from 5th to third as slowed down to pull into our drive. Said it felt difficult to get into third then no drive at all. Any help most welcome or where to start looking. Just got it through the MOT and was hoping not to have to do anything else to it for a while Alasdair
Need help with diagnosing strange hum on startup of Fabia 1.9 SDi - possible alternator bearings
Try a length of garden hose. One end to your ear and move the other around the engine compartment. You should be able to isolate where the noise is coming from or at least the general area. It could be power steering pump? If the fluid is old it and has too much moisture in it it can sound like a groan or hum till it warms up. Its normally worse when cold weather or start up.
- 1 reply
- 1.9 sdi
- alternator
- fabia combi
- noise
Tagged with:
Wheel Bearing change but which brand!!!
If I remember correctly loosen hub nut 1/4 turn then raise car. When fitting new bearing don't lower car until hub nut is tight. Get someone to put foot on brakes and tighten to correct torque then I think its 90 degrees more? If the Hub nut is tightened with weight on the bearing it can cause damage.
Alarm siren replaced. Battery drain issue persists
Not sure if its any help but had similar problem on old Volvo940. Replaced siren and had the same problem. Finally found out that theres a back up battery for the siren in case anyone decides to remove the battery terminals to stop the alarm. Not sure if Skoda is the same. It was cooked and taking the charge from the battery. I only discovered it when it nearly went on fire and noticed an acrid smoke smell. It was in a box that was riveted to the chassis in the most unaccessible place. As the car was old and I reckon no one would steal it so I just removed it and had no alarm. As for the hazards operating when parked up My old octavia 08 used to randomly set off the alarm. Theres a sensor I think near the interior light cluster that gets dusty and triggers phantom alarms. I hoovered it out and since then no probs. Alasdair
Strange DPF problem ?
My son in law has a caddy van which the DPF would do exactlty as you mentioned. Starts regeneerating then gives up.DPF light on plus a few others It was due to the intercooler leaking. I assume it wasnt getting up to pressure. He replaced the intercooler and did a forced regen. Been ok since then.
I agree the gear change selector is plastic and if seized or stiff snaps. I got a cheap replacement from Autodoc.
I just replaced mine. Mechanic friend said go for Febi,NKor Apec or blueprint and avoid the unknown or cheaper brands. Their garage stopped fitting a lot of the cheaper brands due to the fact they don't last. Been using company Parts in Motion. A lot cheaper than Eurocarparts and my local motorfactors and so far have had next day delivery. I had to buy a set of triple sqare splined sockets to do the job and also a new ABS sensor as I managed to snap mine. https://www.partsinmotion.co.uk/search?keyword=wheel+bearing&virtuemart_category_id=0 . Need to do my sons fabia as well but its a push out and press fit so waiting for the tool off amazon. The bearings were half the price from Parts in motion. On my old 08 octavia there are two options. One with 3 bolts and one with 4. Check before ordering Alasdair
Help needed to diagnose odd wobble when accelerating?
Many thanks. I checked the rear suspension and all seems ok but its difficult to tell if the bushes are worn as I don't have a ramp. May have to chuck it into a local garage but problem is I do all my own work and most aren't happy to diagnose but not get the job. Have a mate who works in an MOT centre with vibrating lifts etc so might ask him a favour. Hes an ex mechanic from the garage I used to use before his dad retired so might be able to help. I had a similar problem with a Seat altea. It was one of the tyres that had deformed slightly and you felt it through the seats but it was noticeable at all speeds. When I took the tyre to the tyre service the guy said probably a Michelin and he was spot on. He said that most tyres that they get like that are older Michelin. The rear swwing arms have concentric bolts that adjust the rear camber angle. When the bushes go the tyres tend to wear on the inside. Not sure of the 4x4 but my old 1.9tdi had that problem. When it gets really bad it sounds as if a rear wheel bearing is failing.
Drum brake wheel cylinder question, which way do the pistons face, D shape behind or in front of the shoes?
Hi there working on my sons Fabia mk1. Mot fail on rear brake imbalance due to leaking wheel cylinder and a front flexi plus an advise on a track rod end so not bad at all for 2006 car. Got new ones and quick question there are D shaped lip on the end of the pistons. Not sure if they are supposed to be behind the shoes or in front of them.The old ones had a groove that the shoe sits in. Hope this makes sense Alasdair
DMF or Solid flywheel MK2 1.6tdi
Many thanks, Looks like it might be on its way out. either that or a bad drive shaft joint? Had a word with an old mechanic friend and its got him stumped as well. Theres no vibration when taking off etc but a definite wobble when accelerating and worse when around 30-40mph. If I replace it I reckon go for a solid conversion kit. Alasdair
Hi there just wondering if anyone on here can help. Need to know if my Octavia MK2 2012 plate has a DMF or solid flywheel or how to check? Got a weird wobble and its the last thing I reckon it might be. Its a 12plate Ocatavia elegance tdi CR estate registred may 2012. Thanks Alasdair
Had thought of that but theres no judder etc when taking off and no noticeable odd noises. It could though be as the car has done 108,000. Hope not as I don't need to do a new clutch at the moment. Its a weird one as it varies. Sometimes its bad sometimes its not really noticeable. This is on the same strecth of road and at the same speeds. Seems better on newly surfaced roads so was thinking hopefully a shock absorber problem. Theres no sign of oil leakage etc.
