Everything posted by Tell
Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
Use the first link on MartiniBs page This file: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P350_N60S5MIBH3_EU.7z The Skoda one seems to stick on that % as reported by others on the German Skoda board. You can use the Audi mib2 high file only although you might have issues getting it off the mega server https://mega.nz/file/D7gRnTQS#bs1ghZILdz3-DOJ2Vafc9aePn_l9SDbRTJ8jyPslBO4 The Skoda and VW files should be common latest release 350, 330 was the June release. Skoda just made a mistake. There is nothing special about one rather than the other accept the Audi release is only for mib2 highs whilst the Skoda / VW one's cover mib1 high as well as mib2 high. It's the Audi one I'm using. Works fine. It came out by accident or whatever about 6 weeks ago.
As posted on the other thread I can confirm the two downloads are different. The Skoda one still has an issue from reports. They have managed to get the byte size identical but the contents are different when you run a check. That's not supposed to happen. VW file is the way to go.
Columbus Map Update 2024 (MIB1/2 HIGH)
I did do the SHA256 check on the groups of files, and they are different 🙄. Basically the byte size is identical but the contents are different between Skoda and VW. What I get on the VW one using the 7zip CRC check. Scholars of this process you use It's like a constructed finger print of the files.... they are different. Probably Skoda has yet to fix the issue ?. Interesting page on the German Skoda board,,, failing at 82% on the Skoda file is common... pull out and push the SD card back in :). I'd stick to the VW link. The fun.
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
Feels like a duff SD card or the infotainment system playing up. I aways do the update on the backend SWDL menu that you have to enable with VCDS / Obdeleven etc. It does show you what it's doing. Exfat should be the format for over 32gb. Fat for the 32gb cards. On the Skoda German board with the Skoda zip issue they ended up loosing the maps. I'd try the Audi 350 file on a 32gb card. Mibsolution.one had that linked up but taken down now whilst you have MartiniB's mega link of that. Just a question of getting that downloaded. Booboo, Pcbbc and I, I reckon have been using that one without issues for 6 weeks or so. Or MartiniBs solution above.
Did you use a Mac.... although I don't reckon it's that since it would fail the signature check early on if there was random characters in the file unless the integrity is checked as it's progressing. Suppose to use CleanMyDrive if using a Mac that gets rid of the random characters that Mac's put on. You run that against the SD files once copied. You got the VW link to try and the Audi one. The Audi one because Mib1 files are stripped out is smaller so less fiddling with big downloads. The 64gb SD card can be in exFat as it came pre-formatted. No advantage in NTFS. I'm sticking with the Audi one.
Here's my unscientific quick and dirty comparison between the Skoda and VW files: Unzipped the file size is the same which suggests it's the same file. You then have to workout the SLA1 check....
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
Unzipped without errors here using 7zip https://www.7-zip.org/download.html Windows 64 bit. The built-in Windows 11 7 unzip function turned into a disaster, said it was going to take a day. Reverted to trusty 7zip which you are supposed to use based on VW recommendations. MartiniB I think you once had a transmission error that caused you difficulties in the past 🙄.
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
The first one is trundling away at 30+MB/sec.... the second VW link think there is an issue with it. ok VW portal: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P350_N60S5MIBH3_EU.7z not ok at the minute VW portal: https://navigation-maps.volkswagen.com/vw-maps/P350_N60S5MIBH3_EU.7z
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
Mib3 map update
It probably emulates the over the air update, assuming you got the off line usb plugged in. If its true the car has to be static and perhaps ignition on / entertainment running. Probably for over the air they want a quality signal so may follow the same process. Assume 23.6 will be Skodas latest if you didn't take it from VW ?.
They have fixed the un zip error now on the Skoda link Opening up without an unzip error now MIB2 High: https://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P350_EU_202345.zip Feel free to check it. I'm not going to re-install the same maps - I'm happy with the Audi ones.
- 142 replies
- 1
- columbus
- discover pro
- maps
- mib
Tagged with:
Opening up without an unzip error now MIB2 High: https://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P350_EU_202345.zip Might be fixed.
Amundsen Mib2 Map Updates 2024
The VW one any time soon. All eyes on MartiniB. I've been checking the German Skoda board, they have not found the file link yet. Unless there is a delay it should be arriving in the next week or so.
- 98 replies
- 3
- amundsen
- discover media
- maps
- mib
Tagged with:
Well if VW don't slip their schedule backwards you should see it any time soon. In the past they leave from work on a Friday early (a German thing) and the maps just appear on the servers but not linked to the webpage yet. Might be this Friday or next, you never know. Often the weekend is the period when they get spotted. MartiniB I'm sure is running his sniffer code as others. The VW release is the gold standard. Skoda and Seat have historic releases sometimes that VW don't have / markets that VW don't operate in. Whilst Audi keep theirs under wrap, VIN protected via a login with the mapcare three year imposed just to get in knowing what the user has purchased. That's why we see Audi drivers on Skoda boards they are running long life FeCs and are outside of the imposition Audi apply via the website (all in one custom firmware with long life navigation FeCs / mib 2 high tool box adjusted FeCs). You learn something almost every day. Was nice to see the November 350 released by the back door from Audi. That's perfectly good to use at this time. I wont be updating to the VW / Skoda one this year November since I've got it already. They are common releases across platforms so one is equivalent to the other except in this case Audi have their own mib 2 high only one, mib 1 high only ones splitting out the combined release. Probably done to keep within the 32gb card limit. Audi are indeed the brains of the Vag group. Well if we discover the Audi release is significantly different to the VW / Skoda / Seat release would it be worth re-installing it again. Hence a comparison file check when we see it.
You won't get it to install it's protected with those signatures. @Pcbbc alluded to a way of making small changes. I've seen talk before. You are reverse engineering the like that GCHQ do. More here when I went to the experts https://reverseengineering.stackexchange.com/questions/15992/defeat-rsa-hash-verification-qnx-working-example Basically the public key is published and known. It's on that thread, it's in the mib2 boxes. It's the private key that isn't or might be. It's the same public and private key across the firmware and map releases. I checked using that code fragment and downloads for maps and firmware. The whole subject came up when people were trying to modify the firmware in these boxes. Then it came to pass there was a backdoor left open via the POI import method. Anything placed after the signature got imported in. Like running behind someone at a turn stile tube gate. How the all in one software works found on enthusiasts sites. More tricky with map imports @pcbbcsays. I'd notice they had more security in them having played about with the mib2 high map files before. In 2018 discovering it was the navigation FeCs that needed to be changed and worked out the Seat ones after a unscrupulous retrofitter was selling navigation FeCs for life that turned out to be for one year. Getting pricey. Only payed once and got them to correct their scam least for me they were peddling. Four night away from home on that one visiting said retrofitter miles away. The tool boxes you see and the modded firmware all use the POI import fragment of code at the start. You can visually check this software since the firmware isn't signed at the end. No bank of four signature lines. This is how you know the Audi 350 map isn't hacked. That's signed unless like the Sony film studio someone got in and nicked the crown jewels. Suspect they guard the private key well but you never know. Brute force can be used and you need Cray computers a few years back. This is where they upped the industrial standard of sla1. 256 to 1024 or something. There were published papers saying the industry better use longer keys since computer power was catching up on brute force hacks. Bread and butter stuff of GCHQ but you wouldn't want hobbyists doing it. Interesting subject.
Octavia alarm keeps sounding at random times, suggestions appreciated...
I had a Citreon alarm that was always doing it. The battery voltage dropping can also do that. You might want to check the quality of the battery. They are designed to pick up voltage loss which means the car is being messed about with. Fours years old, out the battery. Stop start can tax them into shorter life. The double click is the best you can do for a temporary solution till it's diagnosed properly.
Skoda knows they messed it up. They removed the Vin to map file lookup to revert back to the June release. If you use the one published by MartiniB to the Skoda servers you get the corrupted one at the minute. Mib2 highs on the import run an SLA1 signature encryption check so it will grind to a halt on the import if one character is wrong.... probably a lot more than one character out with their zipping error. The German Skoda board bless them don't understand this.... was reading their musing today to check whether it had been fixed yet. The integrity of mib2 standard files isn't protected from being messed about with but mib2 high is by that signature you see on the bottom of the meta file. That bank of four lines on the txt file at the in each directory. That seals it from tampering. Crafty way of protecting it but also protects the data from Skoda making a fool of themselves, not. Zip files themselves when unzipped if they complain means it's corrupted. The SLA1 signature is an over kill since the extraction if zipped does that. It's only sole purpose is to stop users hacking it the way they use it. If it was copied unzipped then the corruption check in transmission which it's claimed for would come in but it's use stops tinkering. To be fair it stops rubbish being loaded on to the system. So it does to that 😀. Bottom line, corrupted zip file you won't get the unit to touch it.
Amundsen Mib2 Map Updates 2023/2024
They will call it something else. The same time they lost that six months, they also changed the naming convention. Cue MartiniB. Traditionally, the high version in November was named for the following year. 2024 now. The last June release was the year and next year 23/24 etc. When VAG lost that year on the standard release, when they came back with something that worked, they changed the standard naming convention. I just call the June and November now and VW is best for the source least for the standard maps since they are six months ahead of Skodas.
Yes they have put out the old VW one from six months ago so it's a waste of time if you like to be up front. A few years ago Skoda lost six moths in a hiatus of a technical issues. Think VW just didn't publish but Skoda went onto the six month lags. It's this https://infotainment-cdn.skoda-auto.com/base/maps/STD2_2110_EU_A1_202345.zip which is "old" in our terms but new for Skoda 😁. I got it from here... always interesting to read the German posts... a little green on knowledge. They have hissy fits etc translated to English. https://www.skodacommunity.de/threads/navikarten-update-q1-2022-release-2023-fuer-mib1-mib2.103181/page-192
Dancing on a pin. Reckon 32gb card off ebay is a lot easier. As the maps increase in size as more detail is digitised fiddling to get it to work becomes more tricky with each release. There are tricks you can do to fit RoW maps onto European cards and vice versa for export cars and infotainment units which are a god send for people with these units but other than that. Quite an export market of European cars to North Africa, Middle East. Some to Australia and I've come across a US Golf brought to France.
- 98 replies
- amundsen
- discover media
- maps
- mib
Tagged with:
Mib3 map update
Once the VW release is out in the next period worth trying with that in case there is something defective in that download. You would expect the download that worked with that menu option would still show the drive invitation which you saw when you checked it again after getting home from the dealer to write you piece up earlier. Like for like test.
Reckon best not to use the Skoda ones at this time since you can't till they sort the issue out the zip issue and the Skoda mib3 on the other thread seems to have people having issues with it. That needs more people to look at it to see whether they are just head unit difficulties or a duff file. Feels like Skodas QA on map files has gone a bit off.
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
Sounds good. I'm assuming the file is unzipping fine now since you did the comparison.... eh no just checked.
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
That's Mib2 high only on the Mega link. Works fine.
- 142 replies
- columbus
- discover pro
- maps
- mib
Tagged with:
Mib3 map update
See how that goes. I'd be interested to know whether anybody can find the drive in the engineering menu which you couldn't.
Mib3 map update
Generally, if the file is corrupted during download the zip file won't un zip. That check is on the integrity of the VAG work itself. I did find this one which suggests if you can't get the offline to work see your dealer: I'd be interested to know whether the kickstart method works for other people.
