bigjohn
Everything posted by bigjohn
  1. Welcome to the "S" club. On my S model Superb S I've found an Amazon Echo Auto combined with my Pixel 4a (Android) phone works really well where I can ask Alexa for my Music (be it Amazon Prime, Spotify etc) and then ask Alex for next track etc. Or sometimes I ask Alexa for a radio station - eg Scala radio etc. I also can control Google Maps etc. The Brodit clip setup is your friend as well. The basic car Bluetooth is limited re control and I always configure the device on the Superb for "hands free" - if you select "Premium" it takes over your connectivity (Sim) that does strange things that breaks phone connectivity to t'internet.
  2. You normally get over revving in higher gears first eg 5th & 6th
  3. I have no personal experience re Terraclean as the 1.4tsi EA111 direct injection engine as fitted to my 2014 Skoda Superb is still running like it was was when I bought it nearly new. Now about 105,000 miles. Still did 48mpg on a journey from Manchester to Cheltenham. It may have carbon in there but clearly not as yet affecting it's performance so I'll leave alone! However a friend of mine that bought a Jag XK8 that was not a happy runner had the Terraclean treatment and it rather did the trick. Said same car then went on to give a few years high mileage service. Probably not direct injection though.
  4. Can you check first principles when it's not starting. Pull a plug lead off and attach to a spark plug(spare?) and clamp against a metal surface on the engine - does it spark when turning over? When not starting after turning over for a while can you smell petrol at the exhaust pipe - or on an extracted plug? I think this engine also has a wasted spark coil pack that is known for partially failing and are cheapish and quite easy to change - doesn't always trigger a code. Also the previously mentioned crank sensor - although I would have though that would throw a code.
  5. First comment - if you've just bought it from a trader - take it back! You have rights - https://www.theaa.com/car-buying/legal-rights Engine revving up but car not gaining extra speed could be bad clutch slip - more noticeable in higher gears. However engine revs as somehow you have selected a wrong gear by mis aligned gear shift - could be why it showed it was in 1st or 2nd? Either way I think you have just bought someone's previous problem.
  6. I had Bluetooth issues with an earlier phone (One plus 3) disconnecting occasionally and I tried all sorts of thing to fix with no luck until the phone bricked on me and I ended up doing a factory reset and restoring a backup - Bluetooth was perfect thereafter. This wasn't AA of course but something was interrupting phone basic functions - hopefully nothing nasty! Could it be worth factory resetting the A52?
  7. Any codes logged? Crankshaft sensor could be a possibility but diagnosis by substitution can get expensive.
  8. What engine does your car have? On my old mk I Octavia 1.4 petrol you always heard the fuel pump whirring as you unlocked/ opened the door - could this pump be on the way out? You mention that the battery is brand new - it's also worth re checking battery cables as they will have been disturbed - not just at the battery end but also where they terminate (eg body earth).
  9. I'm a fan of Owatrol oil. Pull out the lights and blather the stuff inside and out (underneath). I've done this on my Superb II as a precautionary measure as others have mentioned this issue - as yet it's perfect. It's a fantastic rust inhibitor and sets to a kind of clearish resin finish - can be painted over (if needed!!) or even added to paint! It's resistant to being washed off. PS it's really good at preserving subframes (eg engine subframe) and suspension components. I've also used on rusting seams on mrs BJ's 06 Fiat Panda - they have held up well for a few years after treatment.
  10. Sounds like it's had the usual dreaded pollen filter chamber/ plenum water leak 🤕
  11. To me sounds like the wrong clock spring was fitted 3 years ago.
  12. But that's a sign you are probably having earth issues. A dodgy earth can do strange things - you can sometimes get smaller bulbs to sort of illuminate as they find a sort of a route to earth through larger filament bulbs depending on the wiring layout/ relay positions etc.
  13. I use a PCT Automotive Split Charge Relay ZR1220 plugged into the boot socket - disconnects output when engine off / not charging. In my case it feeds two inline sockets 1) for a dash cam and 2) for a coolbox. The latter would soon flatten the battery without it! [EDIT - link:-] https://www.amazon.co.uk/PCT-Automotive-Split-Charge-ZR1220/dp/B07KJTNG7V/ref=asc_df_B07KJTNG7V/?tag=googshopuk-21&linkCode=df0&hvadid=310869310714&hvpos=&hvnetw=g&hvrand=2369054140752903766&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006514&hvtargid=pla-761793639295&psc=1 However doesn't your car have Bluetooth anyway? Even on my poverty spec I can connect everything with Bluetooth - I have an Amazon Echo Auto controlling my phone which is connected to the car all reliably via Bluetooth. Or is that the bit that's temperamental? How about the aux socket instead - a previous phone had temperamental bluetooth so I used that for a while.
  14. Audi A4 of the time had similar oily bits. My neighbour's 2003 A4 Avant is mechanically the same as my previous 2003 Superb mkI. https://www.ebay.co.uk/itm/224962568847?hash=item3460d0628f:g:akEAAOSwsIRia6uy For a car with the same engine?
  15. Take it back:- https://www.theaa.com/car-buying/legal-rights
  16. Welcome I did the A1079 commute to York for 28 years - fortunately no longer!
  17. I think the water pump belt is supposed to be fit for life!! However the water pump seals are known to fail so it's probably a good idea to replace whole pump /belt assembly anyway. My son has just had the cambelt replaced on his 1.2tsi - maybe time to do the water pump as well!
  18. If it's the small cc petrol EA211 engine (1.0, 1.2, 1.4, 1.5) the water pump and belt is at the rear of the engine so it's a totally different job.
  19. Perfik - great engine
  20. Is this a bigger issue - I thought "Radio Data Systems Traffic Message Channel" was transmitted over Classic FM in the UK? I can't tell with my car as I use Tomtom technology - which was working fine today - saved me from a big problem today as the A66 was closed due to a big accident! Saying that I was listening to Classic FM ok today?
  21. On my petrol the onboard computer is surprisingly accurate. With my previous diesel it was pure fiction.
  22. Best I've ever done was about 64mpg on a journey of about 10 miles was just after filling up so already warmed up etc doing lowish speeds but negotiating a couple of roundabouts and a couple of set of traffic lights. My usual average is about 46mpg but over 50mpg is achievable on long runs - but mine drinks from the green unleaded pump.
  23. On my Superb mkII 1.4 fitted with a 16v version of the EA111 engine I use the Haynes 5633 VW Golf "2009 to 2012 (58 to 62 reg) Petrol & Diesel" manual. Describes alternator removal/replacement/ inspection/brush replacement. Hope this helps.
  24. How many mile have you done? I'd start by checking all joints / bushes first to see if anything worn. I had a similar problem with an Octavia mkI a few years ago at about 130k miles - replacement bottom arms fixed the issue.
