Carlston
Everything posted by Carlston
  1. The skoda-parts dot com front shock aborbers are listed against both 5Q0413031LH and 5Q0413031FP. Bilstein B4 22-230539 is also listed against 5Q0413031FP and about 30 other OEM part numbers, so that's another possibility. The genuine Skoda part should be near enough an exact match to what the car left the factory with. Aftermarket shock aborbers won't often be close to an exact match to the factory fitted shock absorbers because of the large number of OEM part numbers that they are sold to replace.
  2. One option to give a slightly firmer ride is to go up one in the hierarchy from 5Q0411105GM front springs and 3Q0511115AL rear springs to 5Q0411105GN front springs and 3Q0511115M rear springs. As you can see below, this will increase the wire diameter of the front and rear springs by 0.25mm...which should give about a 5% increase in stiffness. Build codes G04+L07 = 5Q0411105GM front springs 1JP+0YE = 3Q0511115AL rear springs Wire diameter of front springs 5Q0411105GM 12.25mm 5Q0411105GN 12.50mm Wire diameter of rear springs 3Q0511115AL 12.50mm 3Q0511115M 12.75mm Bilstein 37-293123 front springs (matches 5Q0411105GN) https://www.autodoc.co.uk/car-parts/oem/5q0411105gn?supplier%5B%5D=16 Bilstein 36-301959 rear springs (matches 3Q0511115M) https://www.autodoc.co.uk/car-parts/oem/3q0511115m?supplier%5B%5D=16
  3. If the Superb MK3 2.0TSI 272PS/280PS hatchback has standard ride height (not lowered ride height or increased ride height) then the OEM part number for the rear springs might be 3Q0511115AL. Checking the car's build codes is one way to check what rear springs were fitted in the factory. Kilen and Lesjofors are the biggest aftermarket manufacturer of car springs in Europe and are made in a modern factory in Sweden. These two brands are the same spring. Kilen tends to be more widely marketed in the UK whereas Lesjofors tends to be more widely marketed in some European countries such as Germany. Kilen rear springs (matches 3Q0511115AL) https://www.ebay.co.uk/itm/277418047619
  4. Dropping 1" in rim diameter to the 235/50R18 7Jx18 ET43 wheels would have improved the ride a lot. The difference in ride between the other sizes is incremental. Often with VAG cars, going for the most extreme wheel option can cause the ride quality to drop off a cliff. Tiguan MK1 wheels 215/65R16 6.5Jx16 ET33 215/60R17 6.5Jx17 ET33 235/55R17 7Jx17 ET43 235/50R18 7Jx18 ET43 255/40R19 9Jx19 ET33
  5. Like the Yeti, the Karoq FWD uses 215/60R16 for its 16" tyre size. However, the Karoq FWD uses 215/55R17 for its 17" tyre size instead of the Yeti's 225/50R17. Interestingly, both the Karoq FWD and Yeti use the same 17" rim specification, ie. 7Jx17 ET45. So one possibility for a better ride is to fit 215/55R17 instead of 225/50R17...if the insurance company doesn't mind. 215/55R17 has the same load index as 225/50R17...so the same tyre pressures can be used. Example of good 215/55R17 all-season tyre https://www.camskill.co.uk/m140b0s8825p220589/Continental_Tyres_All_Season_Car_Continental_Conti_All_Season_Contact_2_215_55_R17_94V_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB As you can see in the chart below, the 215/55R17 is the second most comfortable tyre size out of the four standard Karoq FWD tyre sizes. The ride comfort of 225/50R17 is similar to 215/50R18...and it would be easy to feel the improvement of 215/55R17 compared to either of these two tyre sizes. When it comes to ride comfort, the 225/40R19 is a truly dreadful tyre...and is by far the worst out of the four tyre sizes shown in the chart below. Karoq FWD tyre sizes 215/60R16 215/55R17 215/50R18 225/40R19
  6. The Superb MK2 needs 5/112 57.1 rims. Are these new rims 6.5Jx17 ET39 5/100 57.1? If so, 5/100 is incorrect and won't fit because you won't physically be able to insert the wheel bolts...due to the holes in the rims being in the wrong place. Do the 205/50R17 tyres have a load index of 89(580kg) or 93(650kg)? If only 89(580kg) they probably won't be able to support the maximum axle weight of the Superb MK2. The Superb MK2 usually needs tyres with a load index of at least 91(615kg) or 92(630kg)...depending on model. The Superb MK2 normally uses rims with an offset between ET45 and ET50...so ET39 is 6mm outside of this range. 205/55R16 is a much cheaper (and more comfortable) tyre size than 205/50R17, so it might be better to look at this tyre size (with suitable rims) instead of 205/50R17. The Superb MK2 3.6 V6 needs at least 17" rims to clear the front brake calipers, but all other models can use 16" rims.
  7. 235/35R20 might not be able to support the maximum axle weight of the Superb MK3 because the load index of this tyre size is only 92(630kg) in XL (eXtra Load) form. The Superb MK3 usually uses at least a 94 (670kg) load index. 245/35R20 would have been better because that has a load index of 95(690kg) in XL form.
  8. According to Jurid/Ferodo/Valeo on autodoc, the Superb MK3 1.4TSI iV 160kW/218PS has 312x25mm front brake discs and 300x12mm rear brake discs. All Superb MK3 models use the 312x25mm front and 300x12mm rear brake disc combination except for the powerful 2.0TSI 272/280PS 4x4 models which use the bigger 340x30mm front and 310x22mm rear brake disc combination. The 312x25mm front brake discs could be upgraded to 314x30mm from the Kodiaq. The Kodiaq uses these 314x30mm front brakes discs in combination with the 300x12mm rear brake discs. The 314x30mm front brake discs use the same front brake calipers as the 340x30mm front brake discs. 314x30mm front brake discs enable the use of 16" wheels, whereas the bigger 340x30mm front brake discs need at least 17" wheels to clear the front brake calipers. One owner reported that the 310x22mm rear brakes also need at least 17" wheels to clear the rear brake calipers. The increase in piston diameter of the front brake calipers when going from 312x25mm front brake calipers to 314x30mm/340x30mm front brake calipers will increase the pressure applied to the front brake pads by 10.8%, ie. (60/57)x(60/57)=1.108033241 The increase in the surface area of the front brake pads when going from 312x25mm front brake calipers to 314x30mm/340x30mm front brake calipers is about 18.2% (estimate only as based on outside lengths and outside heights of front brake pads), ie. (175.2/160.2)x(69.7/64.5)=1.1818018175 314x30mm/340x30mm front brake discs have more effective cooling than 312x25mm front brake discs. The performance of the 314x30mm front brakes is probably closer to the 340x30mm front brakes than the 312x25mm front brakes. On the Superb MK3, all the master cylinders use a 23.8mm (15/16"=23.8mm) bore for both the 312x25mm/300x12mm and 340x30mm/310x22mm brake disc combinations. Piston diameter 312x25mm front brake caliper 57mm 314x30mm/340x30mm front brake caliper 60mm 314x30mm front brake discs (Kodiaq build code 1LW) (TRW brake calipers) Left caliper 3C0615123 Right caliper 3C0615124 Left carrier 7N0615125 Right carrier 7N0615126 Disc 1K0615301AJ Brake pads 8V0698151C https://www.lllparts.co.uk/catalogs/skoda/CZ/KOD/804/6/615/615010 312x25mm front brake discs 8.6kg 314x30mm front brake discs 9.4kg 340x30mm front brake discs 10.8kg Front brake pads for 312x25mm front brake discs Front brake pads for 314x30mm/340x30mm front brake discs
  9. On the Superb MK3, non-standard 225/50R18 7Jx18 ET43 5/112 57.1 wheels could be used with 10mm spacers. This will change the effective offset of the rims from ET43 to ET33. Make sure the spacers are hubcentric, so that the wheel is centred on the hub. With 10mm spacers, the wheel bolts need to be 10mm longer. Perhaps look at Eibach spacers and wheel bolts. The standard WHT001812 wheel bolts have a specification of M14x1.5x27 Eibach M14x1.5x27 wheel bolt S1-6-14-50-27-17 (standard length) https://www.autodoc.co.uk/eibach/1931742 Eibach M14x1.5x37 wheel bolt S1-6-14-50-37-17 (10mm longer than standard length) https://www.autodoc.co.uk/eibach/15258679?search=EIBACH+Wheel+Bolt+%28S1-6-14-50-37-17%29 Eibach 10mm wheel spacers S90-2-10-027 (5/112 57.1) https://www.autodoc.co.uk/eibach/1931843?search=EIBACH+Wheel+spacer+%28S90-2-10-027%29
  10. The below Bilstein B4 shock absorbers for the Superb MK2 are for standard ride height, ie. not lowered ride height or increased ride height. Front shock absorbers (standard ride height) (2014 Superb MK2 estate 4x4) 3C0413031AQ G02 3AA413031M G07 3C0413031AT G07 3C0413031AS G15 3C0413031AB G52 Rear shock absorbers (standard ride height) (2014 Superb MK2 estate 4x4) 3C0513049AR 1JA+1X1 Bilstein B4 22-151056 front shock absorbers (standard ride height) (sold to replace 3C0413031AQ, 3AA413031M, 3C0413031AT, 3C0413031AS, 3C0413031AB) https://www.autodoc.co.uk/bilstein/632208 Bilstein B4 19-151069 rear shock absorbers (standard ride height) (sold to replace 3C0513049AR) https://www.autodoc.co.uk/bilstein/631759 The white label in the boot only has about 40 of the car's build codes, whereas the car might have around 180 build codes. There's a seller on ebay that can supply all of the car's build codes for 3 Euros (about £2.61). Search "skoda vin decoder" on ebay to find a seller that can supply the car's build codes https://www.ebay.co.uk/itm/226517872578 VW Code Decoder 1JA=standard ride height 1X1=4x4 https://igorweb.org/equidec.aspx
  11. The below information is extracted from the Superb MK3 and Superb MK4 owners' manuals. The offset ranges of -2mm to +2mm that wheel-size.com show on their website appear to be arbitrary numbers plucked out of thin air, so probably best ignored. Some countries in Europe (such as Germany) don't allow you to use a wheel size that's not in the car's CoC (Certificate of Conformity). However, if legalities and insurance allow you might want to also look at the winter wheel sizes (ie. suitable for snow chains) that the Superb MK3 lists in its owner's manual...ie. 215/60R16 6.5Jx16 ET41 and 215/55R17 6.5Jx17 ET41. Bear in mind, that the Superb MK4 does use an ET41 offset with its 215/55R17 7.5Jx17 ET41 wheel size. Technical data and specifications (Superb MK3) Permitted rim and tyre combinations for mounting snow chains: Rim dimensions Tyre dimensions 6,5Jx16 ET41 215/60 R16 6,5Jx17 ET41 215/55 R17 Only use snow chains with links no larger than 13 mm, including locks. Technical data and specifications (Superb MK4) Permitted rim and tyre combinations for mounting snow chains: Rim dimensions Tyre dimensions 7J×16 ET43 215/60 R16 7J×17 ET43 215/55 R17 Only use snow chains with links no larger than 13 mm, including locks.
  12. Maybe it has a 205/55R16 6Jx16 ET40 spare wheel. 205/55R16 has a 1" smaller outside diameter compared to 205/55R17, which is 3.9% smaller. To keep the car's electronics happy, such as ABS, traction control, cruise control, etc. it might be best to keep the difference to less than 1.5%.
  13. As you can see in the chart below, there are no 65 aspect ratio tyres approved by Skoda for the Kamiq. A spare wheel doesn't need to be approved by Skoda...so you could use 195/65R16 6Jx16 ET35 for a spare wheel. Wheels approved by Skoda are listed in the car's CoC (Certificate of Conformity). For a 16" spare wheel to match a 205/55R17 6.5Jx17 ET40, perhaps consider 205/60R16 6Jx16 ET40. Doofy found that a 205/60R16 6Jx16 ET35 fitted in his Kamiq, so 205/60R16 6Jx16 ET40 should also fit. Bear in mind that 205/60R16 is a cheaper and more common tyre size than both 195/60R16 and 195/65R16. Kamiq wheel sizes (approved by Skoda) 195/60R16 6Jx16 ET35 (winter tyre size, suitable for snow chains) 205/60R16 6Jx16 ET38 205/60R16 6Jx16 ET40 205/55R17 6.5Jx17 ET40 215/45R18 7Jx18 ET39 Skoda alloy rim accessory catalogue https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AKamiq%2B%25282019%252B%2529&text=# Outside diameter of tyres 195/60R16 640.4mm 195/65R16 659.9mm (non-standard) 205/55R16 631.9mm (non-standard) 205/60R16 652.4mm 205/55R17 657.3mm 215/45R18 650.7mm 225/45R18 659.7mm (non-standard) Doofy's Kamiq spare wheel thread https://www.briskoda.net/forums/topic/517749-kamiq-spare-wheel/ Alcar 6664 6Jx16 ET35 5/100 57.1 steel rim (7.44kg) https://www.mytyres.co.uk/rims/details?vehicleId=1077003525243802724&rimCode=ALCAR6664 Alcar 6977 6Jx16 ET40 5/100 57.1 steel rim (7.44kg) https://www.mytyres.co.uk/rims/details?vehicleId=1087670437300671588&rimCode=ALCAR6977
  14. The below lists of increased ride height springs for the Superb MK3 are listed in order of stiffness, ie. the hierarchy. 5Q0411105HR increased ride height front springs might be suitable for a Superb MK3 2.0TSI/2.0TDI, ie. one of the heavier engined cars. 3Q0511115AS increased ride height rear springs might be suitable for a Superb MK3 FWD. 3Q0511115BA increased ride height rear springs might be suitable for a Superb MK3 4x4. The 4x4 uses slightly stiffer rear springs (perhaps two up in the hierarchy) than the FWD car, due to the extra weight of the 4x4 system. Superb MK3 front springs (increased ride height) 5Q0411105HL 5Q0411105HM 5Q0411105HN 5Q0411105HP 5Q0411105HQ 5Q0411105HR 5Q0411105HS 5Q0411105HT https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/4/411/411000 Superb MK3 rear springs (increased ride height) 3Q0511115BG 3Q0511115AN 3Q0511115AP 3Q0511115AQ 3Q0511115AR 3Q0511115AS 3Q0511115AT 3Q0511115BA 3Q0511115BB 3Q0511115BE https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511000 Eibach R14100 front springs (increased ride height) (sold to replace 5Q0411105HR) https://www.autodoc.co.uk/car-parts/oem/5q0411105hr?supplier%5B%5D=112 Eibach R22930 rear springs (increased ride height) (sold to replace 3Q0511115AS) https://www.autodoc.co.uk/car-parts/oem/3q0511115as?supplier%5B%5D=112 Eibach R22931 rear springs (increased ride height) (sold to replace 3Q051115BA) https://www.autodoc.co.uk/car-parts/oem/3q0511115ba?supplier%5B%5D=112 Buffers for front shock absorbers (Superb MK3) 1K0412303B 70mm (standard ride height) 1K0412303F 55mm (lowered ride height) 1K0412303AA 90mm (increased ride height) https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/4/411/411000 Buffers for rear shock absorbers (Superb MK3) 5Q0511357H 127mm (standard ride height, increased ride height) 5Q0511357J 112mm (lowered ride height) https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511000
  15. There's a seller on ebay that can supply the car's build codes for 3 Euros (about £2.60). Search "skoda vin decoder" on ebay to find the listing. skoda vin decoder https://www.ebay.co.uk/itm/226517872578
  16. The Octavia MK3 1.0TSI doesn't use front brake discs bigger than 288x25mm, so 15" rims will fit...including the non-standard 6Jx15 ET47 5/112 57.1 although 6Jx15 ET43 5/112 57.1 is the standard size for the Octavia MK3.
  17. The Fabia MK4 has two different sized front brakes. The Fabia MK3 also has two different sized front brakes. The small brakes on the Fabia MK3 are fitted to models with an engine power below 100BHP. Anything above 100BHP is fitted with big front brakes. The OP may not have realised that these 94BHP and 109BHP engines might be fitted with different sized front brakes...like they were on the Fabia MK3. It's easy to check what size front brakes are fitted to the Fabia MK4 if you have the car's build codes, as shown in the chart below. Build codes for front brakes (Fabia MK4) 1ZG 256x22mm (small front brakes) 1ZE 276x24mm (big front brakes)
  18. If the the 1.0TSI 110PS/116PS has 276x24mm front disc brakes and 228x42mm rear drum brakes and the 1.0TSI 95PS has 256x22mm front disc brakes and 203x38mm rear drum brakes...then that is quite a big upgrade in braking performance...perhaps more important than the upgrade from 5 to 6 speed manual gearbox that you get when going from 1.0TSI 95PS to 1.0TSI 110PS/116PS. However, check the build codes to be sure what brakes are fitted.
  19. Fabia MK4 brakes You might find that the 1.0TSI 70kW/95PS version has the smaller 256x22mm (build code 1ZG) front disc brakes and 203x38mm (build code 1KG) or 228x42mm (build code 1KA) rear drum brakes. You might find that the 1.0TSI 81kW/110PS and 1.0TSI 85kW/116PS versions have the bigger 276x24mm (build code 1ZE) front disc brakes and 230x9mm (build code 1KV) rear disc brakes. 256x22mm front disc brakes need at least 14" wheels to clear the front brake calipers. 276x24mm front disc brakes need at least 15" wheels to clear the front brake calipers...so you wouldn't be able to use the Fabia MK4's 185/70R14 5Jx14 ET38 5/100 57.1 wheels.
  20. 16" alloy rims (Polo MK4) 6Q0601025C Z31 SAN MARINO 6.5Jx16 ET43 5/100 57.1 6Q0601025D Z31 BARCELONA 6.5Jx16 ET43 5/100 57.1 6Q0601025S 8Z8 VARANO 6.5Jx16 ET43 5/100 57.1 6Q0601025T 8Z8 MONTREAL II 6.5Jx16 ET43 5/100 57.1 6Q0601025AA 8Z8 GTI 6.5Jx16 ET43 5/100 57.1 6Q0601025AD 8Z8 GTI 6.5Jx16 ET38 5/100 57.1 https://www.lllparts.co.uk/catalogs/vw/RDW/PO/461/6/601/601060
  21. As the Octavia MK1 is based on the Golf MK4, 6Jx15 ET38 5/100 57.1 rims and 6.5Jx16 ET42 5/100 57.1 rims are also used on this car. As well as a 205/45R16 6.5Jx16 ET43 5/100 57.1 Fabia MK2 wheel being very prone to kerbing damage it's also very prone to pothole damage. Fortunately, the Skoda parts catalogue for the Octavia MK1 lists a 6.5Jx15 ET43 5/100 57.1 alloy rim that could be used on the Fabia MK2 with a 205/50R15 tyre size (providing it doesn't invalidate the insurance). This would provide kerbing protection, pothole protection, and elegance...as well as a more comfortable ride than a 205/45R16. The Octavia MK1 uses a 205/60R15 tyre size with this rim, which has an outside diameter that is too big for the Fabia MK2. Skoda parts catalogue (Octavia MK1) 17 1U0601025A Aluminium rim 6.5Jx15 ET43 4 "ELEGANT" 1U0601025A 7ZS chrome coloured metallic 18 1U0601149A Hub cap only for: 1U0601025A 7ZS 4 1U0601149A MHB black/bright chrome https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/252/6/601/601050 6.5Jx15 ET43 5/100 57.1 alloy rim ELEGANT 1U0601025A 7ZS (from Octavia MK1)
  22. The Skoda accessory catalogue doesn't list standard 16" Fabia MK2 rims, ie. 6.5Jx16 ET43 5/100 57.1 The OP might not have considered 14" and 15" options, and if they are listed in the CoC there shouldn't be any insurance problems. It's also worth pointing out that 205/45R16 tyres provide very little protection from kerbing damage to 6.5J rims because the sidewalls don't bulge out much. 6J rims are too narrow for 205/45R16 tyres, so that's not an option for this tyre size. 6Jx16 ET35/ET38 rims from the Scala/Kamiq could be considered with 185/50R16 or 195/50R16 tyres if the insurance isn't invalidated...but the cost of both the tyres and rims are likely to be considerably more than 15" options. 6Jx15 ET38 5/100 57.1 and 6.5Jx16 ET42 5/100 57.1 from a Golf MK4 could be used (if the slightly different offsets don't invalidate the insurance), but the Golf MK4 tyres can't be used because they have a much bigger outside diameter than Fabia MK2 tyres. 6Jx16 ET35/ET38 5/100 57.1 alloy rims (from Kamiq/Scala) (Skoda accessory catalogue) https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3ApriceAsc%3ArimDiameter%3A16%2522%3AcarType%3AScala%2B%25282019%252B%2529&text=
  23. With an older Fabia, it might not make economic sense to spend about £1,000 on a set of four new alloy rims and tyres. Most Fabia MK2 models, except 1.4TSI 180PS/1.9TDI 105PS/1.6TDI 105PS/1.2TSI 105PS use the smaller 256x22mm front brake discs rather than the bigger 288x25mm front brake discs...so 14" wheels can be used with these smaller front brake disc models, while the bigger front brake disc models need at least 15" wheels to clear the front brake calipers. The Fabia MK2 6Jx14 rims use 185/60R14 as standard...although slightly oversize 185/65R14 or 195/60R14 can be used if it doesn't invalidate the insurance. Alcar 7250 6Jx14 ET37 5/100 57.1 steel rim https://www.mytyres.co.uk/rims/details?vehicleId=183884523652523108&rimCode=ALCAR7250 Sada poklic Tucanus 14" | Oficiá...Sada poklic Tucanus 14Pro rozměr ráfku: 6,0J x 14
  24. The Skoda accessory catalogue lists eight 15" alloy rims for the Fabia MK3...which can be ordered from any VAG parts department by quoting the relevent OEM part number (shown on each listing). These 6Jx15 ET38 rims are similar to the Fabia MK2 6Jx15 ET43 rims, ie. 5mm difference in offset. The ET38 offset means that the rims will be 5mm further out in each wheelarch compared to the ET43 offset...so perhaps a slightly more sporty look. The standard 15" Fabia MK2 tyre size (195/55R15) could be used with these rims, although the Fabia MK3 uses 185/60R15 with these rims. 15" alloy rims for Fabia MK3 (Skoda accessory catalogue) https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3ApriceAsc%3ArimDiameter%3A15%2522%3AcarType%3ARapid%2B%25282012-2020%2529%3AcarType%3AFabia%2BIII%2B%25282014%252B%2529&text=#
  25. Technical specificationProduct code 57A093860C Limitations Only for 4x4 vehicles with basic luggage compartment floor and standard rear seats as standard equipment. Spare wheel (product code) 5E3601011B (3.5Jx18 ET25.5) Sada pro výměnu rezervního kola...Sada pro výměnu rezervního kola 18Určeno pro: Karoq
