Carlston
Everything posted by Carlston
  1. Osram H7 bulb on amazon https://www.amazon.co.uk/gp/product/B001D6AJQA/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
  2. 245/45 will fit 7.5J 255/50 will fit 7.5J 265/50 will fit 7.5J 275/50 will fit 7.5J 215/35 will fit 8.5J 215/40 will fit 8.5J 265/45 will fit 8.5J 275/45 will fit 8.5J Search the tyre sizes on toyo as that website shows the rim widths that are approved. The allowable rim widths depend on both the tyre's width and the tyre's aspect ratio. Tyre width and aspect ratio Approved rim width range 205/40 7.0-7.5-8.0 205/45 6.5-7.0-7.5 205/50 5.5-6.5-7.5 205/55 5.5-6.5-7.5 205/60 5.5-6.5-7.5 205/65 5.5-6.5-7.5 205/70 5.0-6.0-7.0 As you can see in the chart above, as the aspect ratio increases for any given tyre width, the range of approved rim widths tends to decrease. https://www.toyo.co.uk/
  3. 225/45R17 tyres can be fitted to rims with a width between 7J and 8.5J. Approved Rim Width Range (inch) 7.0-7.5-8.5 for 225/45R17 https://www.toyo.co.uk/tirefinder/index/width/225/aspect/45/rim/17
  4. First, find out the OEM part number of your standard rear springs. Maybe take a photo of your white build code label that's under the carpet by the spare wheel well. However, these are just some of the build codes that your car left the factory with, so may not include the build codes for the springs. What coloured dots are on the rear springs? What wire diameter are the rear springs? For example, this might be 12.5mm. Both sides should be the same. By reference to a chart, this will tell you the spring's OEM part number. Does your 2005 Octavia MK2 4x4 have standard or increased ride height? You might also want to check the coloured dots on the front springs. What engine does it have, and does it have a manual or automatic gearbox? Or maybe go on erWIN and get a printout of all your car's build codes. This is actually the easiest method to finding out what was fitted to your car when it left the factory. erWIN costs about 7 Euros for one hour's access, which is usually enough to printout the car's build codes. Standard ride height rear springs for Octavia MK2 4x4 https://skoda.7zap.com/en/cz/octavia/oct/2005-419/5/511-511002/ Increased ride height rear springs for Octavia MK2 4x4 (1) 1K0 511 115 CR coil spring 1 paint mark 2 paint marks red green 2 PR-1JB+0YJ (1) 1K0 511 115 CS coil spring 1 paint mark 3 paint marks red green 2 PR-1JB+0YK (1) 1K0 511 115 CT coil spring 1 paint mark 1 paint mark rear red brown 2 PR-1JB+0YL https://skoda.7zap.com/en/cz/octavia/oct/2005-419/5/511-511012/ As you can see from the chart above, if your rear springs have 1 red dot and 2 green dots, you have 1K0511115CR. If this is the case, then a change to 1K0511115CS or 1K0511115CT will solve the sagging rear end problem. 1K0511115CR https://www.autodoc.co.uk/car-parts/oem/1k0511115cr?search=OEN+1K0511115CR&supplier[0]=112&supplier[1]=246&supplier[2]=253 1K0511115CS https://www.autodoc.co.uk/car-parts/oem/1k0511115cs?search=OEN+1K0511115CS&supplier[0]=112&supplier[1]=253&supplier[2]=246 1K0511115CT https://www.autodoc.co.uk/car-parts/oem/1k0511115ct?search=OEN+1K0511115CT&supplier[0]=253&supplier[1]=246&supplier[2]=112
  5. I wouldn't. Just keep an eye on the front tyres to make sure they are wearing evenly, and make sure the steering feels ok...like you would anyway.
  6. If the Superb MK2 had come with 175/80R14, 195/65R15, 205/55R16 tyre options like the Golf MK4 used to, then the 195/65R15 might have been considered a good compromise. Fortunately, the some of the lower powered 105HP diesels come with 288mm front brake discs...which means that 15" rims will fit. As standard, the Superb MK2 was never supplied with rims less than 16".
  7. A 235/40R19 tyre fitted to an 8J rim is about 235mm wide when inflated. 8" equals 203.2mm. However, an 8J rim is 8" where the tyre beads sit, not the outside measurement. So maybe add 6mm each side to account for the thickness of the rim, and that gives you an uninflated tyre width of about 215mm. A 215/60R16 tyre fitted to a 6.5J rim when inflated has an actual width of about 221mm, ie. 6mm more than the nominal tyre width. A 215/55R17 tyre fitted to a 7J rim when inflated has an actual width of about 226mm, ie. 11mm more than the nominal tyre width. Someone did mention that an inflated 215/60R16 tyre fitted to a 6.5J rim when inflated does raise the floor slightly, maybe by several millimetres. Therefore an uninflated 235/40R19 tyre should fit, but not an inflated tyre. Maybe store a 235/40R19 uninflated and carry an electric pump for when you need to use it.
  8. You probably need rear shock absorbers that are sold to replace OEM part number 3C0513049CP Most of the shock absorbers in your list, aren't sold to replace OEM part number 3C0513049CP Here's a list on autodoc that are sold to replace OEM part number 3C0513049CP https://www.autodoc.co.uk/car-parts/oem/3c0513049cp?search=OEN+3C0513049CP However, many of the brands have a one size fits all approach so might not be that close to the original 3C0513049CP rear shock absorbers. Rear shock absorbers 3C0513049CP (7) 3C0 513 049 CP gas shock absorber rear 2 PR-1JA,1JL+ 0YE,0YF,0YG, 0YH,0YJ,0YK, 0YL https://skoda.7zap.com/en/cz/superb/sup/2012-632/5/511-511001/ The TRW shock absorbers are quite a bit cheaper than many of the big brand names such as Bilstein, Sachs, KYB, etc., and seem to be a good match to OEM part number 3C0513049CP. TRW JGT1054T Rear shock absorbers sold to replace OEM part number 3C0513049CP https://www.autodoc.co.uk/trw/7058548
  9. Spare wheel replacement kit Designed for: SUPERB III. https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/3V0093860B 1359CZK is about £46.98, ie. the foam and jack part of the full size spare wheel kit is cheap. If you use the OEM part number 3V0093860B you should be able to order this kit through a local Skoda dealer's parts department. Then you just need a 16" space wheel, such as 205/55R16 fitted to a 6.5Jx16 ET46 5/112 57.1 steel rim.
  10. I would change both sides, as the other might soon go also. It might be better to replace the lower steel wishbones as well, as these can rust through from the inside. This also means that the front and rear bushes are already fitted into the wishbone. You can see in the chart below that item number 2 varies depending whether the Fabia MK2 has build code G01/G07 or not. It probably doesn't as the other build codes are far more numerous, ie. build codes G02/G03/G04/G38/G39/G40/G41. 1 6R0 407 151 track control arm, complete D >> - 28.06.2010 left 1 PR-G02/G03/ G04/G38/G39/ G40/G41 (1) 6R0 407 151 E track control arm, complete D - 29.06.2010>> left 1 PR-G02/G03/ G04/G38/G39/ G40/G41 (1) 6R0 407 152 track control arm, complete D >> - 28.06.2010 right 1 PR-G02/G03/ G04/G38/G39/ G40/G41 (1) 6R0 407 152 E track control arm, complete D - 29.06.2010>> right 1 PR-G02/G03/ G04/G38/G39/ G40/G41 (1) 6R0 407 151 D track control arm, complete left 1 PR-G01/G07 (1) 6R0 407 152 D track control arm, complete right 1 PR-G01/G07 2 1J0 407 181 bonded rubber bush rear 2 PR-G02/G03/ G04/G38/G39/ G40/G41 (2) 6R0 407 181 B bonded rubber bush 1 PR-G01,G07 3 357 407 182 bonded rubber bush front 2 https://skoda.7zap.com/en/cz/fabia/fab/2014-697/4/407-407010/#1 Left wishbone G02/G03/G04/G38/G39/G40/G41 https://www.autodoc.co.uk/topran/8210327 Right wishbone G02/G03/G04/G38/G39/G40/G41 https://www.autodoc.co.uk/topran/8210331
  11. The standard tyre sizes on the Octavia MK3 RS have about the same outside diameter. Outside diameter 225/45R17 634.3mm 225/40R18 637.2mm 225/35R19 640.1mm There is less than 1% difference in the outside diameter between all three sizes.
  12. If the 3.5% increase in gearing made no difference, Skoda would have increased the gearing themselves. Gearing is carefully optimised by the manufacturer before a new car comes onto the market, as undergearing a car increases fuel consumption and emissions. Even if you were happy with the 3.5% increased gearing, the increased sidewall height would raise the car's centre of gravity by 11.25mm. Bear in mind that the RS is lowered by 15mm to improved handling, yet by fitting these bigger outside diameter tyres you are throwing away most of this gain.
  13. Outside diameter 225/40R18 637.2mm 225/45R18 659.7mm Therefore, the 225/45R18 size has an outside diameter 3.5% bigger than the 225/40R18 size. This is quite a lot as anything more than 1.5% to 2% can significantly compromise the gearing, particularly 1st gear and top gear. If you want more sidewall, going down to 225/45R17 (with suitable rims) would make more sense. 225/45R17 is also a much cheaper tyre size than 225/45R18, perhaps saving around £250 on a set of 5 new tyres.
  14. If you're on 185/60R15, then these are good for all year round use, including mild snow but especially good in cold rain. Vredestein Quatrac 185/60R15 88H XL https://www.camskill.co.uk/m138b0s7989p202141/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_185_60_R15_88H_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_70dB
  15. Kilen and Lesjofors recommend 5Q0411105HR front springs and 5Q0511115AM rear springs for the Octavia MK3 Scout 2.0TDI 4x4 with manual gearbox. Kilen and Lesjofors recommend 5Q0411105HS front springs and 5Q0511115AM rear springs for the Octavia MK3 Scout 2.0TDI 4x4 with DSG automatic gearbox. The only rear shock absorber listed on the Skoda parts catalogue for the Octavia MK3 Scout is 5E0513029C. Rear shock absorber 5E0513029C 7 5E0 513 029 C gas shock absorber rear 2 PR-1JB+K8D https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/#7 Kilen online catalogue https://www.kilensprings.com/springs-catalouges/onlinecatalogue.asp Lesjofors online catalogue https://www.lesjofors-automotive.com/springs-catalouges/onlinecatalogue.asp Kilen and Lesjofors are the same springs made in the same factory in Sweden. It may be best to purchase genuine Skoda shock absorbers for the Scout rather than aftermarket ones, as you may have difficulty finding increased ride height aftermarket shock absorbers. This is because aftermarket shock absorbers mainly cater for the standard ride height market.
  16. 205/50R15 is the wrong size for the Octavia MK2 4x4. I think you meant 205/60R15, which is a much bigger tyre.
  17. E0A 1D0 5SJ 5RV 1KJ 6FB 1AT 3FA 1N3 1NL H7D 4UP B09 3QT 4X3 4A3 8ZF J0L QI6 8GU 6Y0 9AK 8RM 7T6 8AY 8QL 8X1 4F2 B09 7MG QN0 3L6 9P3 Q2J 7X1 9ZG 8WD 7A0 3GG 7AL G15 L30 7P1 F0A 3S9 2UA E0A = No special edition 1D0 = Without trailer hitch 5SJ = Left exterior mirror: convex 5RV = Right exterior mirror: aspherical 1KJ = Disc brakes, rear 6FB = Body-colored exterior mirror housings 1AT = Electronic stabilization program (ESP) 3FA = Without roof insert (standard roof) 1N3 = Speed-related variable steering assist (Servotronic) 1NL = Covers for alloy wheels H7D = Tires 225/40 R18 92Y xl 4UP = Drivers and front passenger air bag with knee air bag and front passenger air bag deactivation B09 = Type approval Great Britain and NorthernIreland 3QT = 3-point seat belts with tensioner and height adjustment, front 4X3 = Side air bag front with curtain air bag 4A3 = Seat heater for front seats separately controlled 8ZF = Inside side window antenna J0L = Battery 340 A (70 Ah) QI6 = Service indicator 30,000 km or 2 year ( variable ) 8GU = Alternator 140 A 6Y0 = Without cruise control warning system 9AK = Climatronic with impact pressure control free of cfc 8RM = 8 speakers (passive) 7T6 = Navigation system (MID) 8AY = Radio/navigation system 8QL = Key for locking system with remote control 8X1 = Headlight washer system 4F2 = Central locking system "Keyless Entry" B09 = Type approval Great Britain and NorthernIreland 7MG = Emission standard EU5 QN0 = Without drawers under front seats 3L6 = Electric seat adjustment for both front seats, drivers seat with memory system 9P3 = Seat belt reminder, electric contact in buckle Q2J = Comfort front seats 7X1 = Park distance control 9ZG = Mobile phone preparation with hands-freespeaking system 8WD = Integrated front fog light 7A0 = Without CD changer/CD player 3GG = Plane rear cargo area 7AL = Anti-theft alarm system, passenger compartment control, backup horn and towing protection G15 = Front shock absorption L30 = Suspension range 30 installation control only, no requirement forecast 7P1 = Power adjustable lumbar support in frontseats F0A = No special purpose vehicle, standard equipment 3S9 = Roof rails 2UA = Standard design VW Codes Decoder http://igorweb.org/equidec.aspx Front springs (1) 1K0 411 105 BP coil spring 1 paint mark 1 paint mark 1 paint mark also marked with: 2 paint marks 1 paint mark red white red orange white 2 PR-L30 Front shock absorbers G15 (8) 3C0 413 031 AS gas shock absorber 2 PR-G15 https://skoda.7zap.com/en/cz/superb/sup/2012-632/4/411-411001/
  18. Jurid are listing 312mm front discs for the 184HP 4x4 model. https://www.autodoc.co.uk/car-parts/brake-disc-10132/skoda/octavia/octavia-combi-5e5/108648-2-0-tdi-4x4?supplier[0]=48&criteria[100][1]=VA
  19. Jurid also lists 288mm front discs on the Octavia MK3 2.0TDI 150HP 4x4 https://www.autodoc.co.uk/car-parts/brake-disc-10132/skoda/octavia/octavia-combi-5e5/59490-2-0-tdi-4x4?supplier[0]=48&criteria[100][1]=VA Jurid are one of the few brands that actually seem to know what size brake discs are fitted to various models. Most other brands just seem to list all the possibilities.
  20. Many of the build codes are unreadable on that photo. However, a couple of the build codes look like they might be G04 and L14...which would suggest sports suspension. Front springs L14 (1) 6Q0 411 105 N coil spring 3 paint marks 2 paint marks red green 2 PR-L14 Front shock absorbers G04 8 6Q0 413 031 BL shock absorbers front 2 https://skoda.7zap.com/en/cz/fabia/fab/2012-697/4/411-411020/#8 Engine code CAYC 1.6 TDI CR DPF 77 kW 2010–2014 CAYC (EA189) 1598 ccm, I4, 16V, DOHC, common-rail, turbocharged 77 kW (105 PS; 103 hp) at 4400 rpm 250 Nm. (184 lb•ft) at 1500–2500 rpm 5-speed manual (MQ250), FWD 188 km/h (117 mph) 10.9 4.2 / 67.3 / 56.0 109 https://en.wikipedia.org/wiki/Škoda_Fabia#Engines_2
  21. Slightly oversize 245/40R19 are already available in the following Continental SportContact 7 245/40R19 98Y XL https://www.blackcircles.com/catalogue/continental/sport-contact-7/245/40/R19/Y/98/m?tyre=42565789 Goodyear Eagle F1 Asymmetric 6 245/40R19 98Y XL https://www.mytyres.co.uk/rshop/tyre/Goodyear/Eagle-F1-Asymmetric-6/245-40-R19-98Y-XL/D-126540 Michelin Pilot Sport 5 245/40R19 98Y XL https://www.camskill.co.uk/m55b0s326p209257/Michelin_Tyres_Car_Michelin_Pilot_Sport_5_PS5_-_245_40_R19_(98Y)_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_72dB The SportContact 7 won the latest tyreview test performing really well in both the wet and dry, and the Goodyear Eagle F1 SuperSport came in 4th place. They didn't test the Goodyear Eagle F1 Asymmetric 6 or the Michelin Pilot Sport 5. https://www.tyrereviews.com/Article/2022-Tyre-Reviews-UHP-Summer-Tyre-Test.htm
  22. The Monte Carlo is just a trim specification, so is likely to be have standard ride height suspension. It's not an RS model. What are your build codes? Take a photo of the white label/sticker in the spare wheel well area under the carpet, as that shows some of the build codes. If you've got build code G02, which is standard ride height, then your front shock absorber have OEM part number 6Q0413031BJ as shown below. Front shock absorbers 6Q0413031BJ 8 6Q0 413 031 BJ shock absorbers front 2 PR-G02 https://skoda.7zap.com/en/cz/fabia/fab/2012-697/4/411-411001/#8 Here's an example of a white label/sticker showing some build codes
  23. The thrill of a fast accelerating car is very short lived, as you soon get used to it. It's a bit like taking a big-dipper ride at a theme park. Fun at first, but do it all day and it soon gets boring. Even an F1 driver soon gets used to the acceleration of his car which is in a different league to the relatively slow 276bhp Superb 4x4.
  24. I doubt any new Skoda alloy rims are powder coated. Powder coating is more suited to steel. When applied to aluminium, the alloy rim gives off gases when put in the oven at about 200 degrees centigrade to melt the powder and cure the paint. This results in bubbles forming in the paint, so not a high quality finish. It's also difficult to remove powder coating if you want to repaint them at a later date. However, I could be wrong about some of these details...so do ask an expert. 5E0601025D 1 5E0 601 025 D aluminium rim 7JX17 ET49 4 PR-C7E DENOM 5E0601025D 8Z8 diamond silver 2011.12... https://skoda.7zap.com/en/cz/octavia/oct/2016-753/6/601-601070/
  25. This one is probably the right size. Check the dimensions against your current battery, particularly the length of 207mm. Also check the orientation of the battery terminals. Varta C30 (Width 175mm, Height 190mm, Length 207mm) https://www.varta-automotive.com/en-gb/products/varta-silver-dynamic/554-400-053 https://www.ebay.co.uk/itm/393494393854?hash=item5b9e17f3fe:g:DtIAAOSw91VhwK8s
