Everything posted by Carlston
Multiple warning lights - battery issue?
Measure the battery voltage. It should be over 12.0 Volts.
Does the Sportline have stiffer suspension?
I wouldn't call 5Q0411105HB the Sportline counterpart of 5Q0511105GK. 5Q0511105HB has a narrower wire diameter than 5Q0411105GK and a similar number of coil turns, so would appear to be a softer spring. Losing 27mm in length requires a stiffer spring not a softer spring. I can't find any aftermarket springs for 3Q0511115AA. This is often the case for sports springs, as most of the sales for aftermarket springs will be for standard ride height springs.
Enyaq suspension
If you're still not happy on 235/55R19 tyres fitted to 8Jx19 ET45 rims, then higher profile tyres on narrow rims (such as 235/65R17 fitted to 6.5Jx17 ET38 rims from the Kodiaq) would massively improve the ride comfort. 235/65R17 is a much cheaper tyre size than 235/55R19. 17" rims won't clear the front brake calipers if the front discs are bigger than 345mm in diameter, although I'm not aware of any Skodas that have front discs bigger than 345mm. Goodyear EfficientGrip 2 SUV 235/65R17 108V XL https://www.mytyres.co.uk/rshop/tyre/Goodyear/EfficientGrip-2-SUV/235-65-R17-108V-XL/R-439488 Goodyear EfficientGrip 2 SUV 235/55R19 105V XL https://www.mytyres.co.uk/rshop/tyre/Goodyear/EfficientGrip-2-SUV/235-55-R19-105V-XL/R-439483
What OEM part numbers do your current front and rear springs have? Your current front and rear springs might have OEM part numbers 5Q0411105GJ (2 blue dots) and 3Q0511115AK. If so, you would have an option of going up one weight range on the front and/or rear springs. The increase in spring stiffness by going up one weight range is about 5%, as you would be going up from 11.75mm wire thickness to 12mm wire thickness on the front and 12.25mm wire thickness to 12.5mm wire thickness on the rear. 5Q0411105GK is one weight range higher than 5Q0411105GJ. 3Q0511115AL is one weight range higher than 3Q0511115AK. Front Springs (1) 5Q0411105GJ coil spring 2 paint marks blue (1) 5Q0411105GK coil spring 1 paint mark 1 paint mark blue green Rear Springs 1 3Q0511115AK coil spring 1 3Q0511115AL coil spring Sachs 5Q0411105GJ https://www.autodoc.co.uk/sachs/12794755 Sachs 5Q0411105GK https://www.autodoc.co.uk/sachs/13786039 Sachs 3Q0511115AK https://www.autodoc.co.uk/sachs/15244168 Sachs 3Q0511115AL https://www.autodoc.co.uk/sachs/15244179
Superb Mk3 - What tyres are you all using?
Skoda Superb 2020 2.0TSI – Generation: III B8 (3V) Facelift [2020 .. 2022] – Power: 217 hp | 162 kW | 220 PS – Engine: 2.0L, I4, Petrol – Options: Style – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [2020 .. 2021] Tire Rim 215/55R17 94V 6.5Jx17 ET41 2.3 / 2.1 215/55R17 94V 7Jx17 ET40 2.3 / 2.1 235/45R18 94W 8Jx18 ET44 2.4 / 2.2 235/50R17 96W 7.5Jx17 ET40 2.3 / 2.1 235/40R19 96W 8Jx19 ET44 2.4 / 2.2 235/35ZR20 92Y 8Jx20 ET40 2.6 / 2.4 https://www.wheel-size.com/size/skoda/superb/2020/ Uniroyal Rainsport 5 215/55R17 94Y £84.55 https://www.mytyres.co.uk/rshop/tyre/Uniroyal/RainSport-5/215-55-R17-94Y/R-400535 Uniroyal Rainsport 5 235/45R18 98Y XL £102.40 https://www.mytyres.co.uk/rshop/tyre/Uniroyal/RainSport-5/235-45-R18-98Y-XL/R-400548 Uniroyal Rainsport 5 235/40R19 96Y XL £127.80 https://www.mytyres.co.uk/rshop/tyre/Uniroyal/RainSport-5/235-40-R19-96Y-XL/R-402382
Oil Pump Chain = Engine Failure - Is this the CUSB/CUTA engine code in 2015 1.4tdi?
CUSB and CUTA TDI engines are belt driven according to wikipedia. Engine designation Production Engine code (family) Displacement, configuration, valvetrain, fuel system, aspiration Motive power at rpm max. torque at rpm Gearbox (type), drive Top speed 0–100 km/h [s] (0–62 mph) Combined consumption [l/100 km / mpg imp / mpg US] CO2 [g/km] 1.4 TDI 10/2014–06/2017 CUSB 1,422 cc (86.8 cu in), I3, 12V DOHC belt driven, common rail, turbocharged 90 PS (66 kW; 89 hp)@3000–3250 230 N⋅m (170 lb⋅ft)@1750–2500 5-speed manual, FWD 182 km/h (113 mph) 11.1 s 3.4 L / 83.1 / 69.2 88 g/km 7-speed automatic DSG, FWD 3.6 L / 78.5 / 65.3 94 g/km CUTA 105 PS (77 kW; 104 hp)@3500–3750 250 N⋅m (184 lb⋅ft)@1750–2500 5-speed manual, FWD 193 km/h (120 mph) 10.1 s 3.5 L / 80.71 / 67.2 90 g/km https://en.wikipedia.org/wiki/Škoda_Fabia#Engines_2
Replacement Front Springs for Combi Sportline
Have a look on autodoc.co.uk to see what aftermarket springs are available for your car. It can take many years before a good selection of aftermarket springs becomes available for new models. For example, there isn't a good selection of aftermarket springs for the Superb MK3 2.0TSI 220HP, in which case OEM springs may be needed.
Spacesaver size
What width rim is your 205/65R16 tyre fitted to? If it's fitted to the standard 6.5J Superb MK3 rim, the tyre will be about 215mm wide not 205mm wide. The actual width of a tyre doesn't just depend on the nominal width of the tyre but the width of the rim that it is fitted to. Fitting a tyre to a wider rim increases the actual width of the tyre. Fitting a tyre to a narrower rim decreases the actual width of the tyre. You can see in the Toyo chart below, that a 205/65 tyre fitted to a 6J rim has an actual width of 209mm. PROXES CF2 New Proxes CF2 has been created to take advantage of the latest materials, structures and tread pattern design in order to guarantee a high level of safety, durability, savings, and comfort. Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 205/65 R16 95V 8.6 672 209 5.5-6-7.5 https://www.toyo.co.uk/tirefinder/index/width/205/aspect/65/rim/16 A 205/65 tyre fitted to a 6.5J rim has an actual width of about 215mm. A 215/60 tyre fitted a a 6J rim has an actual width of about 215mm. Therefore, a 205/65 tyre fitted to a 6.5J rim has exactly the SAME width as a 215/60 tyre fitted to a 6J rim.
Black smoke, poor acceleration in my SDI
If the problem is caused by a clogged air filter, the smoke won't stop immediately. It could take about 50 miles for the smoke to slowly stop. Of course, the problem might not be caused by a clogged air filter. But it's the easiest and cheapest thing to check first. Don't run the engine without an air filter, as that let's grit into the engine which causes permanent engine damage.
Check the air filter, it might need changing.
Spacesaver size
You might be able to fit a 215/60R16 on a 6Jx16 ET40 or ET43 rim. The 6Jx16 ET40 rim is used on the Superb MK1. The 6Jx16 ET43 rim is used on the Karoq. Don't try a 215/60R16 on the standard 6.5Jx16 ET41 rim because that will raise the carpet slightly. Fitting a 215/60R16 to a 6J rim instead of a 6.5J rim makes it about 6mm narrower. As you can see from the Toyo tyres chart below, 215/60R16 fitted to a 6.5J rim has an overall width of 221mm (not the 215mm which you might expect). However, fitting a 215/60R16 to a 0.5" narrower 6J rim makes the overall width of the tyre about 215mm (or about what you would expect from a 215 tyre size). If you were to fit a 215/60R16 to a 7J rim, the overall width would be about 227mm. If you want to fit a standard space saver spare, Skoda sells a 205/55R16 fitted to a 6.5Jx16 ET46 (from an Octavia MK3) for the Superb MK3 for this purpose. However, the outside diameter of this tyre size is about 5% less than the standard Superb MK3 tyre sizes. PROXES CF2 New Proxes CF2 has been created to take advantage of the latest materials, structures and tread pattern design in order to guarantee a high level of safety, durability, savings, and comfort. Tire Size Tread Depth (mm) Overall Diameter (mm) Overall Width (mm) Approved Rim Width Range (inch) 215/60 R16 99V XL 8.7 664 221 6.0-6.5-7.5 215/60 R16 95H 8.7 664 221 6.0-6.5-7.5 215/60 R16 99H XL 8.7 664 221 6.0-6.5-7.5 https://www.toyo.co.uk/tirefinder/index/width/215/aspect/60/rim/16 Alcar 9490 6Jx16 ET40 Steel Rim (from the Superb MK1) https://www.mytyres.co.uk/rims/details?vehicleId=180505174664549488&rimCode=ALCAR9490 Alcar 6665 6Jx16 ET43 Steel Rim (from the Karoq) https://www.mytyres.co.uk/rims/details?vehicleId=672867581094270064&rimCode=ALCAR6665 Skoda Space Saver Tyre for the Superb MK3 (205/55R16 tyre fitted to 6.5Jx16 ET46 rim) https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-16/p/5E0601011J
Skoda fabia alloy wheels
The wheel bolts are M14x1.5x27 and will fit all Fabias and Polos with a PCD 5/100 10 WHT001812 wheel bolt M14X1,5X27 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/FAB/year/2006/drive_standart/453/hg_ug/601/subcategory/601010/part_id/2543667/lang/e
Kilen Online Spring Catalogue https://www.kilensprings.com/springs-catalouges/onlinecatalogue.asp
Advice please for tyre/wheel size for 1 ton load trailer
If the OP plates his trailer to more than 750kg he could easily run into trouble. Let's say the OP plates his trailer at 1,500kg and tows it with a 2,000kg MAM car, then that's legal because the total MAM of the car and trailer hasn't gone over 3,500kg. But if the OP swaps his car to one with a MAM of 2,001kg, he's driving with no licence as the combined MAM of the car and trailer has now gone over 3,500kg (ie. 2,001kg + 1,500kg = 3,501kg).
With trailers, it's the plated weight that is important. I suggest you plate it at 750kg. This is important if you don't have a category B+E on your driving licence. If you passed your car driving test before 1997 you will automatically have been awarded category B+E in additional to category B. Since 1997, an additional trailer driving test has been needed to be awarded the category B+E. If your trailer is plated for more than 750kg you can't legally tow it without a category B+E even if you don't have the trailer loaded to more than 750kg gross weight. As you measured the hub centre bore at 56.2mm, I suspect that it is actually 56.1mm and not 56.6mm. 56.2mm would make the hub a very sloppy fit in a 56.6mm rim so I doubt it was made for that size. Alcar 7160 4Jx15 ET35 4/100 56.1 Steel Rims https://www.oponeo.pl/felga-stalowa/alcar-kfz-7160#19282293 https://www.mytyres.co.uk/rims/details?vehicleId=173418272467718756&rimCode=ALCAR7160 Vredestein Quatrac 5 155/60R15 74T https://www.camskill.co.uk/m138b0s7984p133931/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_155_60_R15_74T_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_1_Noise%3A_68dB 74 (375kg) load index allows for up to 750kg maximum axle weight. It's illegal to drive along with an unevenly loaded trailer.
How many wheels does the trailer have? What is the centre bore? Possible centre bores for 4/100 rims 54.1mm 56.1mm 56.6mm 57.1mm 59.1mm 60.1mm
Oil Change Sump Plug
It looks like a captive steel washer. https://www.autodoc.co.uk/topran/2724721
Skoda fabia 1.4 tdi has 70bhp, 75bhp and 80bhp versions
Model Years Engine and code Displacement Power Torque Diesel 1.4 TDI 6V 2005–2007 I3 BNM 1422 cc 51 kW (69 PS; 68 hp) at 4000 rpm 155 N⋅m (114 lb⋅ft) at 1600–2800 rpm 1.4 TDI 6V 2003–2005 I3 AMF 1422 cc 55 kW (75 PS; 74 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm 1.4 TDI 6V 2005–2008 I3 BNV 1422 cc 59 kW (80 PS; 79 hp) at 4000 rpm 195 N⋅m (144 lb⋅ft) at 2200 rpm https://en.wikipedia.org/wiki/Škoda_Fabia#Engines SKODA FABIA 6Y 2003-2005 1.4 TDI 55 kW / 75 PS, 195 Nm (standard) performance increase Displacement 1422 cc Torque 235 Nm at 2200 rpm More efficient 24 HP / 18 kW, 40 Nm Top speed 168 km / h https://www.dtintecno.de/cars/1-4-tdi-55-kw-75-ps:6047 SKODA FABIA 6Y 2005 - 2007 1.4 TDI 51 kW / 69 PS, 155 Nm (standard) performance increase Displacement 1422 cc Torque 190 Nm at 2000 rpm More efficient 26 HP / 19 kW, 35 Nm Top speed 166 km / h https://www.dtintecno.de/cars/1-4-tdi-51-kw-69-ps:6046 SKODA FABIA 6Y 2005 - 2007 1.4 TDI 59 kW / 80 PS, 195 Nm (standard) performance increase Displacement 1422 cc Torque 235 Nm at 2100 rpm More efficient 24 HP / 18 kW, 40 Nm Top speed 175 km / h https://www.dtintecno.de/cars/1-4-tdi-59-kw-80-ps:6048
What engine do you have? If it's the 2.0TDI 184HP then the sump OEM part number is N90813202 27 N 90813202 seal bolt with sealing ring M14X1,5X22 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2014/drive_standart/753/hg_ug/103/subcategory/103043/part_id/2541323/lang/e This is a very common part used in many VW group engines. Even the Skoda Citigo uses this part. N90813202 https://www.autodoc.co.uk/car-parts/oem/n90813202?search=OEN+N90813202&page=1&supplier[0]=10249&supplier[1]=101&supplier[2]=1156 Why do you want to replace it as the part is reusable as long as it's not damaged? If you want to change the washer, you can measure it and find many copper washers on ebay in many different sizes. The inside diameter, outside diameter, and thickness will all vary.
Skoda Fabia MK1 Center Bore: 57.1 mm PCD: 5x100 Thread Size: M14 x 1.5 165/70R14 5Jx14 ET35 185/60R14 6Jx14 ET43 195/55R15 6Jx15 ET43 If you're looking for non-standard sizes, 185/65R14 6Jx14 ET37 and 195/55R15 6Jx15 ET43 from the Skoda Roomster are two possible options. https://www.wheel-size.com/size/skoda/roomster/2006/
Estate and spare wheel
Spare wheel replacement kit (1025CZK is about £34.21) Intended for OCTAVIA IV OEM part number: 5E3093860 https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/5E3093860 Complete spare wheel 18" (3586CZK is about £119.68) Intended for OCTAVIA IV OEM part number 5E3601011B https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-18/p/5E3601011B With the above OEM part numbers you should be able to order from any Skoda parts department.
Winter wheel options
Some steel rims that would fit the Superb MK3 6.5Jx16 ET41 (Standard Specification) https://www.oponeo.pl/felga-stalowa/alcar-kfz-8426#22066666 6.5Jx17 ET41 (Standard Specification) https://www.oponeo.pl/felga-stalowa/alcar-kfz-hybridrad-132801#21063847 7.5Jx18 ET50 (Non-standard Offset) https://www.oponeo.pl/felga-stalowa/alcar-kfz-9373#22127632 8.0Jx18 ET45 (Non-standard Offset) https://www.oponeo.pl/felga-stalowa/alcar-kfz-9383#22127634 8.0Jx19 ET45 (Non-standard Offset) https://www.oponeo.pl/felga-stalowa/alcar-kfz-9393#22127633 Standard Superb MK3 Alloy Rims 6.5Jx16 ET41 6.5Jx17 ET41 7.0Jx17 ET40 7.5Jx18 ET46 8.0Jx18 ET44 8.0Jx19 ET44 https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?sort=priceAsc&q=%3AscoreDesc%3AcarType%3ASuperb%2BIII%2B%282015%2B%29&show=Page#
Wheels
205/60R15 is a less common and more expensive tyre size than 205/55R16. 205/55R16 is Europe's most popular car tyre size. The standard 16" rim size on the Octavia MK2 is 6.5Jx16 ET50. Alcar 9915 6.5Jx16 ET50 5/112 57.1 Steel Rims https://www.mytyres.co.uk/rims/details?vehicleId=182468352675943536&rimCode=ALCAR9915 Alloy Rims for Octavia MK2 https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?sort=priceAsc&q=%3AscoreDesc%3AcarType%3AOctavia%2BII%2B%282008-2013%29%3AcarType%3AOctavia%2BII%2B%282004-2008%29# Vredestein Quatrac 6 205/55R16 81H All-Season Tyre https://www.camskill.co.uk/m139b0s8003p202103/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_205_55_R16_91H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_70dB
ALCAR 9021 6.5x17 ET38 Steel Rim £ 41.30 https://www.mytyres.co.uk/rims/details?vehicleId=639488607098246256&rimCode=ALCAR9021
Michelin crossclimate+ Vs Goodyear vector 4seasons gen-3
Vredestein are gradually replacing the Quatrac 5 with the Quatrac. The Quatrac now doesn't have a number, although I have noticed at least one online tyre seller incorrectly calling it the Quatrac 6. The replacement started last year and was due to finish this year. 15" sizes seem to have now gone over to the new Quatrac, but 14" sizes are still available in the old Quatrac 5 model.
