Everything posted by Agustnr
Knuckles on the iv
Does anybody know what type metal knuckles the superb 3 iv (hybrid) uses? Is it steel or aluminium?
iV model stage 1 tune
Oh man so sorry I didn't even see this message. Yes I did, I actually managed a 280 hp 480 nm tune. It feels really good in sport mode
Underneath the bumper, should be a cutout if it's fitted
VCDS options on Superb III
Put the car in reverse, select L or R (depending if lhd or rhd), then adjust the mirror until it looks good to you, now the car will remember that setting when you reverse and have the mirror on R/L
Or R if you live outside UK
Override ACC
Override ACC
That you can turn off and I turned that **** right off, I manually adjust the speed lol. ACC is nice for heavy traffic and long journeys
Override ACC
That doesn't override it. As soon as you let go it starts again
Override ACC
Hi Does anyone know if you can override the ACC when it thinks the road ahead is somehow too bendy (when it isn't at all)or it thinks you're going on an off ramp? I've tried pressing the right wheel button, holding the accelerator while doing it.
Just make sure your car is unloaded and preferably on level ground too, otherwise you'll have a wonky beam that doesn't align. It's good if you can mark on a wall where the beam should be.
Oh yeah it would be quite a feat if someone managed to fit halogens into a xenon bracket hahah
Quality Xenons aren't cheap haha
Skoda Superb - iV charge flap actuator sticking
Had that one time but it was really cold, I guess there was some water that froze on the pin so it jammed it incorrectly. Pushing on it many times somehow released it
How To: Heated Windscreen Retrofit
Sorry for bumping this and asking a stupid question, but should you ideally do the wiring prior to the windscreen fitting or it doesn't matter?
New Superb Owner
1. It should be connected to your key. 2. Yes. 5F - Multimedia Adaptation Vehicle function list BAP Traffic sign recognition 0x21 > Activated Traffic sign recognition 0x21 msg bus > Databus extended Front traffic assist 0x41 > activated Front traffic assist 0x41 msg bus > Terminal 15 A5 (Driver Assistance) Security access - 20103 Control unit Long Coding Byte 16 Bit 04 click on the circle to enable 17 (Dashboard) Control unit Long Coding Byte 5 Bit 02 click on the circle to enable That should be all 3. Yes A5 (Driver Assistance) Long Coding Point of Intervention > Early setting over menu Lane Assist off Text > Disabled Configuration for lane departure warning KL15 > Last setting Lane assist system mode > Selection over menu 17 (Dashboard) Long Coding Lane assistant > Yes Lane changing assistance > Yes Lane change assistant, BAP distance > Yes Lane retention assistant, BAP distance > Yes 4. Turn the knob on your drivers door for the mirror on R and then when you hit reverse it should dip, otherwise if it doesn't, then manually dip it and it should save the dip you chose.
Superb Mk4
Wait so the hybrid is down on power?? From 160 kw with the 1.4 tsi to 150 kw on the 1.5 tsi? surely not right?
I live in Iceland so unless you do as well then Boost ehf! Their website leads to this site. Maybe it's the same tool. https://www.bensky.co.uk/tuning-database
Just got a remap on my superb iv, allegedly it is about 280 hp and 480 nm of torque. Even just using the car in normal hybrid mode I can already feel a huuuuge difference.
If your car is facelift it's not possible anymore
As far as I'm aware they beam LEDs into a Plexiglass which are controlled by independent LEDs, that way they can use the same strip but have different LEDs
Skoda Superb DCC missing or not
The easiest way for you to identify if your car has DCC is if you go into drive mode and customise by tapping "Individual" and the first option should be labelled DCC, if you don't have that, you don't have DCC
What's your odometer at..?
2020 at 33 803 km
New Skoda Driver Question
Take both keys and have them in the car, then go through the settings to make yourself as the primary driver and then delete the old owner
Remote boot opening
Maybe have it scanned for fault codes, it's possible that there's a fault in the system
DCC Slider adjustment option mod
Thanks man. Appreciate it. Now to find a place that has odis/vcp in Iceland... Lol
