DieselMonte
Everything posted by DieselMonte
  1. More Work done. Rear brakes were getting very low, so ordered new pads. Ordered front and rear pads from Mtec, I think it was £50 for both. I ordered them at 11am and they were delivered the next morning. Extremely impressed. Front discs were ordered and were meant to be here last Monday, tracking last updated on the 16th so almost certainly lost. Left is the new Mtec ones, right is the ones that were on it. Swapped discs too which was a bit of an ordeal, but they needed changing. Lucky I never returned the discs that were meant to go on it when the axle was done. All fitted. So far so good. Noticeably more bite in the rear now. Have noticed a bit of squealing about town, whether that's down to them needing to bed in, or them being a bit more aggressive of a pad I'm not sure. If it doesn't get any worse I can live with it. Also noticed the drivers rear wheel bearing is a bit rough, so starting to go. No play in it, yet. Worth noting I used the wheel bearings that were on the vrs axle so all things considered I did well to get 20k+ miles out of it. Other side is fine. Its a fairly straightforward job to do and the bearing itself is pretty cheap so I'll do it myself at some point. Had a bit of an oh **** moment when I saw this sticking out of one of my pilot sports. Very luckily it came out and is not losing air. Ordered and received the timing belt kit too. Gates kit. Checked the belt and from what I can see it's "alright". I could, probably will stretch it to next service. Which at the rate of driving I'm doing will only be another few months. Lastly I've ordered all gaskets needed to swap that turbo. Genuine of course. Will be in sometime next week hopefully.
  2. Finally lives again. New carb kit arrived. All it needed was the gasket really. Put it all together, slapped it on, fresh fuel in the tank and a bit into the fuel bowl. And... First try and it fired right up. New backbox is silent aswell Running pretty rough, High idle and lots of revhang but it IS running and does idle. Did take it out for a few runs of the farm ofcourse. And it pulled superb considering. Obligatory photos. Doesn't look it but it's covered in an inch of dust from sitting up. Got it on the weighbridge and according to that it weighs 740kg without a driver. So now it's back starting, steering and stopping. So nct is in its very near future indeed.
  3. I put 312mm heatshields on the Monte when the brakes were done. Theyre galvanised and after nearly 2 years and over 40k they're so far so good. The standard heatshields that came off it were Swiss cheese though. I have 312mm heat shields to go onto the vrsdi but the bolts for the standard shields are all rounded. I presume I should just use the aforementioned chisel method to get them out?
  4. Is that everything you needed? Any other bits just shout.
  5. So subframe is assembled ready to go back on. Had to cut a notch to make the non vrs passengers console work. I'll never be a surgeon but its good enough for this. Especially since the cut won't be seen. Reused the drivers console too. Suspected I somehow stripped the threads but chased them out in the vice and they seem fine. Have the vrs one spare just in case anyhow. Built up with all the poly stuff from the sdi. And the psb arb bushes I took out of the Monte. They'll do for now. Mondeo links from the sdi too. Used the vrs arb of course. Sdi one is 17mm and the vrs is 19mm. Not really noticeable in a photo. Turbos back on too. Hopefully no more leaks. Hopefully. Made some progress making the hole for the a/c. Didn't have anything on hand to make a nice neat cut, so I improvised. Used the rubber gasket as a template for the sdi. Drilled some small holes just inside the template. Figure I can enlarge the holes until they all go together. Far from the best way to go about it, but once I get the hole finished I can clean up the edges and make it look like less of a hack job.
  6. But it will reduce heatsoak on those lovely summer days just around the corner. Thank you global warming. Diesels on boost a lot more than an equivalent petrol so heatsoak should be more of a concern, am I right in saying that?
  7. Get a Seat Sport style one if you're so keen on an intercooler. It's a proper pig to fit proper but it'd be the best bang for buck. Ebay or wherever will sell knock offs. An intercooler is an intercooler, darkside is seat sport style iirc but with some brackets welded on. My 2 cents is that your standard intercoolers probably got some leaky pipes at the age of it, and being a plastic intercooler could well be leaking a bit already.
  8. Break in miles. Looks fresh!
  9. New carb kit is finally delivered I just need to pick it up. Came all the way from Canada. Was not cheap so I ****ing hope its correct and not ripped. Anyway, was waiting for paint to dry so tinkered on this for a bit. Wirewheeled the brakes front and rear And gave em a lick of hammerite silver. Pointless since they're stuck behind 12 inch steelies but I'll know. Also had some spacers doing nothing so threw them on the rear. 5mm a side. I don't really want to tackle these wheels by myself with the surface rust. Don't think I can make them look "like new". So for now they can look original. May send them off to a professional somewhere down the line. And maybe buy some new wheel nuts. Also refitted the fuel filter assembly back on. Hopefully be running like a champ very soon.
  10. Well just about given up on swapping the firewalls over. After breaking lots of tools and barely making a dent in it that is. I'm now intent on just making a hole in the one in the sdi. Put some dubshed stickers to good use. Good for hiding windscreen cracks. Cleaned up the subframe and Arb off the vrs, they were rough. Coated them in Kurust and then some hammered black same as before. Noticed one of the arb collars are missing, I'll just find something to wrap around it for now. Lot better than the scratched up, rusty subframe it was a few hours before. Using this subframe as it still has the dogbone nut intact. Had some hammerite left so wirewheeled and Cleaned off the knuckles and painted them in situ. Bit more presentable. Cleaned up the bores where the shocks go into and coated them in copper grease. They were a bit rusty inside but Cleaned up well. Went to paint the carriers and found out my tub of pantone 348 had gone off, so sulked and painted them silver instead.
  11. I shall get the sawzall then. And some tigerseal to fill what I've already cut.
  12. Good afternoon everyone. I'm in the midst of reshelling my vrs into my sdi and decided to swap the firewalls over, as the vrs one has the hole for Aircon and I'm intent on swapping EVERYTHING over. It's held in by 6-7 13mm bolts which I have removed, however it's also held in with some of the strongest seam sealer I've seen. I've tried heat, which didn't do much. Used cutting wheels which just destroyed them and made enough smoke that I'm glad there isn't a smoke detector in the shed. Used a Stanley knife to try cut away at it bit by bit which did nothing but destroy the blades. And even went so far as to try wedge a chisel in between the firewall and the chassis which only served to break the chisel. Surely someone's encountered something like this before and can give me some help? All else fails I'll drill the required hole in this firewall and do it that way. Thanks.
  13. Stripped away at the vrs subframe, drivers console came out like butter, passengers side though... It did not want to play ball. And in typical fabia fashion, the bolts snapped. Atleast it snapped in a way I could separated it from the subframe. Ill reuse the vrs subframe as it still has the nut for the dogbone welded on, and the drivers console too. I'll use the sdis passengers console and just cut a notch in it for the 6 speed. So may as well use the PSB consoles now for the sake of it. And left some stuff to soak in vinegar for the last day or two. Took the carriers out and got to work on them. Now sitting primed ready for paint. The bolts for the Heatshields on the vrs hubs are very corroded so not sure how I'll get them out. May end up running no heatshields in the end, not ideal. Engine bay and inside is stripped bare so taking on removing the seam sealer from the bulkhead. It's not coming out easy. Will take a long time to chip away at it enough to remove the bulkhead.
  14. Plenty done this weekend Drivers side splash guard has been changed. And 2 new Meyle Balljoints put on. Only the drivers needed replacing but they're cheap and easy to do so did both. Done in 40 minutes. The drivers side one was BAD and it was only on 6 months. Was mentioned by the nct tester when it was tested last month, and it had just started knocking then. Should not have passed like that imo. The passengers side was absolutely fine. And FINALLY, I've got my hands on a Garrett GTC1549VZ, a CR170 turbo. Looks to have been recently rebuilt, the core looks very fresh. Might still be worth dropping it off at someone who knows what they're looking at, just to be sure its been rebuilt right. Had been looking at a hybridised XMan version but the person selling that wouldn't post it, unfortunate. And I took it to Dubshed too, If youre up before 11 you can get into the show and shine outside. I was put out in the nosebleeds. Only found out they have a car wash on site once I was up there, I'll know for next year. Bit funny trying to explain to people that its not a vrs but a 1.6 diesel and that no, I didn't put that bodykit on it's standard. Was a great day anyway. May have found someone there who can map in this new turbo when it goes on. So on top of juggling the vrsdi, the justy and even just maintaining this, I'm going to try have that turbo on before June. And there's work to be done before that, Even though it was serviced in December it'll be due another service in about a month. Timing belts due so that'll be done then also. And I'll definitely be needing another 2 tyres before June. Much to do, no money to do it. What's new.
  15. Did vrs' not all come with the flappy paddles? I'd have thought them all being dsg would mean it's standard
  16. First is one for your vrs no hook Second is the ate ones You've already been sorted but this might help someone in the future
  17. He does Ate calipers and therefore pads are used on mk2 fabia vrs and most montes. Conveniently vw also use the same ate caliper and pads for the 312mm setup.
  18. Wiring loom is fully out of the vrs now Came across another obstacle in that the bulkhead is different, it doesn't have the hole for ac. Seems like it's removable so I'll swap it over at some point. Just more work. Also got a new return line And 312mm carriers So of course I've started stripping down the brakes. Plenty of life left in them clearly.
  19. Not me jealous. UK has a much easier time getting insurance than us in Ireland. Almost every insurer won't quote a car over 20 year old, some even as low as 14 year old. The justy is a pita to get insurance for as classic insurance won't cover anyone under 25. And won't cover any subaru. In their eyes my 50hp justy is as dangerous as an sti. Farce
  20. Almost everything out. Only thing that needs to come out is the wiring for the dome light. Pile of parts grows bigger again
  21. And nothing of value was lost
  22. Didnt know that about irish spec ones. I've seen a white one like mine at work, original irish one now with Trinity's. Mines a UK one. Very strange The 16s would have been far better suited for our roads although in fairness I've yet to bend or damage one of my rims on our potholes. Popped a tyre once but the wheel was absolutely fine.
  23. I spy some toledo tyres I'd be getting them off ASAP. Video very much related. And I was going 10 under the limit, 40 in a 50 As toot says those are gigaros, fabia vrs wheels. Didn't know some montes had them fitted. Presumed all uk ones got Trinity's like these.
  24. I well believe it, it would explain the different wiring. Whether that's attached to the top or its fitted to the tank I've no clue. Would be very stupid if it wasn't just attached to the tank. I'm hoping whatever happens I can reuse the fuel lines on the sdi. The vrs has a very rough looking fuel cooler, and the way its positioned is just asking for something to shoot up and bust it. I intend on repurposing the black trim and headlining into the sdi. Funny enough I bought some black dye to dye all of the carpets and such. It's good stuff but very strong. Will probably still use it to make everything a slightly darker black. I think it'll look great in my car with the sport (bohemia(?)) seats and door cards I already have. Tell you what though, I've noticed more and more bits of extra sound deadening on the vrs compared to the sdi. It all looks factory. Whether it's a spec thing or a year thing I don't know.
