Former
Everything posted by Former
  1. Hi Liz welcome, the chap that used to have an update hasn't been on the forum for months for some reason(s) and the other chap that deals with infotainment IIRC doesn't have it. Assuming (always dangerous) the program relates to other models too you could try a Search of the site to see if anyone else on another model forum has it but you might have to go through the thread/posts.
  2. Oh 😄 I thought it might be some fancy heater ventilation system. I wonder if causes less, more or no difference (not that don't know). Not being able to use it on some setting and the air-con coming on if the blower is on every time I switch to screen annoys me. Like I put I'm going to try not setting to screen straight off on misting (inside) mornings and I was going to try something else someone suggested but I forgot what as I don't get many cold / wet morning starts as it's my wife's car. She travels 2 miles to work and 2 miles back most working days now as she doesn't have to go to other work locations occasionally as much as she used to and she might go on other short journeys too. There are some longer runs sometimes for shopping (food or charity shops mainly) and they can be 10, 20 or 30 miles but as we no longer go to N. Yorks, or other places, there are few longer runs. As I've not put a coin slot meter on the car I notice lot more electrics are used when I'm not in the car. 🙂 I've not notice this with my wife's car, perhaps it happens but I've not noticed. Window open and you can get a face wash from the wipers or water blowing off the screen IIRC. On another thread someone has expressed surprise that the start/stop function has retuned by charging the battery rather than replacing it with new, and there have been other threads with unexpected warnings and issues that have gone away after charging the battery despite the posters taking some convincing because the battery seemed OK and the car starts fine, lets hope it's the same for you with the EPC light.
  3. You have put more charge into the battery. As long as the battery holds the charge and/or you are not depleting the battery storage to how it was previously the start/stop should work (when it should) and you'll not get that and possibly other warnings. Running the battery down low does it no favours, doing it too much and/or too often will weaken it and make it difficult to recover it as much as if you didn't. Think of preventative charging or a battery maintainer or disconnecting the battery if the car isn't going to be used for weeks on end, that will extend the use and life of your existing battery and its replacement. Don't wait for warning lights or messages to come on, be proactive rather than reactive. Or buy a new battery and have to do less, until the cycle begins again. Good luck.
  4. More (quick) thoughts.- As ignition coils start to get towards failing they can sometimes do odd things and not just the one thing many say. Electronics and electrics (items, wires, connectors) can sometimes function differently or not function at different operating temperature so fine, or not, when cold or hot and not function or so well at different temperature. I am personally not keen on Colour Tuner as it is a bit subjective and in the UK at least different petrols and different petrol additives, one ethanol and lead replacement additive gives the the plugs a salmon or darker salmon colour.
  5. 'Intelligent'. 😄 You have to use what you have there but personally as I put I like to use as low amps as I can for as long as I can. ? 🙃 That's not a "feature" I know about but it sounds like the type of thing to help run the car battery down, like 'come home(?) lights. Do you also has KESSY keys? My wife bought one of those for home windows after seeing a friend use one on their very condensated windows, I knew she would, but our windows are very minimal bedroom only really so a couple of uses and it takes up valuable shed space in its box now, for years. Are you sure you don't have a leak somewhere , or carrying damp clothes or dog blankets in the car - but the model does seem to mist up for itself anyway. We've never noticed that, used to notice that with soft tops, not with the old British soft tops mind as they didn't have seals that went on the roof and own other side, British forethought ! 😄. Later modern (at the time) cars had the electric windows drop before / as the door was opened.
  6. My thoughts - Might not be one single thing but a combination (or might be one one thing) so I am now looking at things in the round rather than lasered down to plug colours only (and I agree with you can have two sets of two colours of plugs from a single carb). I would have a look at the Triumph forums that use a similar engine for some clues perhaps to your issue(s). Starting on three suggests that's an issue too, are you sure it's three, suggest HT side from cap to plug, or is it two getting too much or too little fuel as per plugs. Electronic igniter heads can go off and dissy caps being crap is not uncommon from the cheaper makers / suppliers (and their rotor arms). Also electronic dissy top leaves usually very worn and never very long lasting mechanical dissy bottom (well British ones anyway) and rebuilt last a couple years of use before wobbling out again but perfectly useable for a couple of decades perhaps. Bosch rotor arm have a 5 whatsit resistor in them that can start to break down before it fails that might also hinder starts and setting up and running, if the rotor arm is still in good condition you can sweat out the resistor and remove it and bridge the gap. If you have what is called a red rotor arm from one of the cheaper suppliers you get what you pay for but even Bosch and Beru can go. Sparks plugs are genuine and not counterfeit or the very cheap ones from the cheap suppliers of cheap ignitor heads and ignition kits and cheap HT leads. The shut off test previously described is very good if your able to do it and you can get and handle what will be hot plugs (easier on a X-flow than when the exhaust manifold is within skin blistering error area). Vacuum hose is best to be marked vacuum hose or thicker wall not flimsy thin walled old rubber. Thinking of which what colour is anything coming out of the exhaust tail pipe after full engine warm up at idle? Care must be taken with where any hoses off the engine come and go and blanking off. You put your engine was same as the Wikki photo but then that there was a variation, are you able to see a period photo of your exact engine set up to your model and year in case there are other variations, owners alter things over decades so unless you have a concours correct car exactly the same model and year it is difficult to know which is correct (from factory at least). I would be going back to just after setting valve clearances and rechecking everything, if you know someone with the same parts, and they are fully working well, you could try swapping over your parts to their car to test them and their parts on your car. Just because something has been rebuilt doesn't always mean it has been done well or mistakes not made or faulty parts fitted, just because a part is new doesn't mean it cannot be faulty, or even the correct part sometimes. I had 30+ years of buying and fitting ****-poor "classic" car parts, generally period New Old Stock parts (if still available) or working or serviceable genuine old parts are often much better than new made parts. (well for UK anyway) . A different person looking at or working on the car can sometimes spot the obvious you have overlooked or previously checked or not bothered to check as "it won't / can't be that". Wow, that was a lot, enough for now. 😄
  7. A reasonable quality old analogue meter could be better than a new cheaper digital but it does depend on a number of variable. To get an idea of how accurate it is you could if you have them available test against a new battery or batteries 9v, 6v, 3v, 1.5v, two three or four 1.5v pushed together in series and look up what the actual readings should be then do repeats of the tests to see if the needle varies its position. VW would have 12v at 30% of charge so yes very low but as you say you don't know the reliability of the test equipment. Even if the battery was showing a 12.3 or 12.4v on a reliable meter personally I'd still fully charge the battery, also some chargers give a voltage reading so you can compare that against a reading you take at the same time with the analogue multimeter and you can see how the two compare. Fine having fully charged the battery then you want to know the battery holds that charge reasonably, so reading a few days later, if you wanted you could put load on to the battery too to se how much it drops and recovers. Alternator charging can vary with the computer program doing its stuff, but as you say the alter alternator is at least doing something, easier to test the battery with a battery tester. What many forget is the battery also doesn't like hot weather so weaknesses can be from then accumulate and then show up more come the cold weather and additional heavier use of the battery. With a more modern VW start/stop car, even a 2016 and especially a 2019 (and newer) I'd charge it just after the very hot weather of summer ready for autumn and going into winter and again during the Xmas/New Year break. Some suggest charging at change over to and from winter tyres but that might not be enough, prevention is better than cure. Your past month's and A1 use shouldn't have bothered the battery unless it was already low or gone too low too often previously but some would say 4 years out of the battery is good (not me). For the vast condensation on the windscreen we use two Pingi bag dehumidifiers, a moist synthetic chamois, sun visors turned to reflect air back to windscreen rather than letting it go to the roof - and waiting - but I think I've discovered the worst thing to do is put the blower on to the windscreen as this seems to dump the damp air from the heater box and venting straight on to the screen in a self-defeating act of the demisting. But I don't drive my wife's car often enough to confirm this or find out how long to wait before putting the demisting on to the windscreen. If I'm not with my wife I lower both front windows as until last year my "daily" car was from 1973 so I'm used to scrapping all windows before starting the car, chamois the inside of windows, lowering the front (and only) windows, not bothering with the heater until it warms up a bit, pulling the choke, start the car, adjust the choke and drive off. Chamois windscreen as required. So the plastics and all the glass causing misting of the Fabia cabin pees me off (I still clear all the windows before I get in the car). 😄 Back to your car, if the EPC light stays off with more power in the battery then you might be lucky and that was part of illuminating, happy days. You will find out if it comes on again before the battery gets low again. Personally I like to have all error codes cleared only as like with a full battery you know your starting point is good but as I've lost access to my neighbour's scan tool and I can't I don't worry about it. Again let us know your readings after fully recharged and a next day and a number of days after that. If you use the same multimeter hopefully it'll be consistent with it's inaccuracy so give relative consistent comparative readings. A mate wanted to check his new bit less cheap digital multimeter against his other two cheap digital ones and the reasonably priced one he bought me as a present, all four gave different readings with his latest purchase being the furthest away from the reading my one gave. Good luck, imagine if all car repairs and maintenance was as clean hands and as easy as plugging a charger maintainer and walking away. 🙂
  8. Could be so many things a scan tool is handy to help with diagnosis but you still need to diagnose the information the scan tool gives as it can't always point you at the exact cause but more in the right direction or to test items to rule them in or out, for example a sensor could be a massager rather than the culprit. You can only ask if the Cranwell person is able to help you worst that can happen us they're unable to you've lost nothing by asking. If the car is in the garage for a week then a perfect time to put it on a long slow charge with an appropriate charger maintainer, don't go for a quicker and higher charger if you have the choice, Follow the instructions in the car's Owner's Manual (and charger's manual) for correct charging. You can then check the battery at the battery posts the day after the charging has fully finish to get a better idea of the battery's state of charge, then check again a couple or more days after that to see if there's a significant drop. The reading obviously want to be done the same for consistent results and depending on when you take them any part volts the car's computers and other items might still be using at rest. As a belt and braces if you want after full charging you could start the car put the headlights and aircon on then turn the steering wheels full lock both ways and this should let the computer know the battery is now able to cope, or go out for a short drive. You've really need to flog a battery close to death before the car wont start which is part of the problem of owners really running the car batteries down too far too often. If you are really (really) lucky perhaps even the EPC warning might not return but you'll have to see on that. At four years old there are additional bits of servicing above just an engine oil & filter and a "free health check" that even Dealerships do on the car, if they haven't been done that might (or might not) help to contribute to warnings and/or a lack of use of the car. Good luck let us know how you are getting along with it or the ends results.
  9. Personally if I didn't have access to a scan tool that is appropriate to a VW brand vehicle I would take the very easy and clean hands approach of using an appropriate battery charger and maintainer and fully charging the battery. Others may have other ideas and you can choose to follow whatever advice you please. Going up the motorway should sort things with battery anyway but if your outgoings are a lot not more than your income then they may not make up for past over use or if for some reason the alternator or whatever else is faulty. A battery that is too low can throw up all sorts of unexpected warnings and issues. Whatever is the cause of the issue, especially electrical, and the computers and their programs run on electric (5v) having and knowing the battery is fully charged is a good stating point. Alternatively you could see if there's anyone near to you on the VCDS list able to help you. -Briskoda VCDS Owners Map (click me) Or check to see if there are any Recalls or updates for your car. - https://www.skoda-auto.com/services/recall-campaigns
  10. Even if the oils are similar at certain points of measure it doesn't mean they are the same let alone near identical but that doesn't matter and you would have to ask the manufacturer or blender about the differences - but both could be appropriate and fine for your car. Bear in mind the commercial reasons for changing titles and make up of oils covered before. It's like tyres the latest version maybe not as good or appropriate to some (or all) as the previous version(s) or it might it might be better. I've bought and used oils that are not current to the oil manufacturer or blender's website or marketing and sales, much of it is to do with fashion and marketing and sales rather than technical advances or improvements. That covers all good synthetic oils at whatever multigrade.
  11. If you stick with the smallest wheel size Skoda and their customers' fashion will allow on the model certainly not and even if you perhaps go up one size to get more overwide and lower ratio tyres - but if you're used to steel wheels of nearer a less fashionable size why would you. If you go up to the largest and least most fragile style of alloy you can get on the model and worry about its appearance or severely damaging it down a pothole or up a kerb then you might consider an insurance - but again if you're used to steel wheels of nearer a less fashionable size why would you.
  12. So you knew where the power curves and figures were on those two occasions from the two particular rolling road(s) as they and your car were at that those particular times to give you some idea unless you have changed things on the car since to make a significant difference you will have a reasonable idea allowing for age, wear and tear since. Sorry I missed this bit in your post. You will I'm sure be happier with this oil and certainly through winter and perhaps even summer but I'm sure we will hear reports back. Just for the pre-established sake of looking at the numbers - Eneos Premium 10W-40 Synthetic Kinematic viscosity (40°C) - 99.6 mm2 /s Kinematic viscosity (100°C) - 14.7 mm2 /s Viscosity index - 154 (API SL/CF, VW 500.00/505.00) - "Note: The above typical properties may be changed without notice. (February 2006)" - https://oilgroupbg.com/pdf/eneos/eneos-premium-10w40.pdf I could not find Premium as a current oil on Eneos Europe's website for a more up to date spec sheet but this was the result of the oil selection search for as near as I could get with their system for your car, note the alternatives, should warm you up on a cold day, 😁 - https://jx-nippon-uk.ewp.earlweb.net/equipment/felicia_estate_ii_1_3_50kw_FawEcWamX
  13. I have a positive for the Total Quartz 15w-50 m i n e r a l you no longer have the 3 minute plus at higher revs. 😁 I decided to replace the trowel with a shovel and put my happy hat on. 😁
  14. @D.FYLAKTOS the Total Quartz 15w-50 m i n e r a l oil doesn't suit you and perhaps your car - perhaps another 15w-50 mineral or better still good synthetic might suit you and you car (or perhaps not) it doesn't matter as you will never try another another 15w. Sorry I didn't make myself clear with not believing something until you see it with your own eyes that was not about the 15W-50 m i n e r a l but that if the most suitable oil for you was suggested at the very start you might try it and still find, to you, a compromise so you would still go on the journey you have taken and then forget that the first one was possibly the best as you (and possibly your car with some) may have disliked some effect of every oil you tried. Your car is 23 years old and has been modified so unless you put it on a rolling road you won't know the exact figures and peak power and torque points or level of curves but you have driven it enough to have a reasonable idea of how it performs in the way you drive it. Now you have totally dismissed the Total Quartz 15w-50 m i n e r a l and 15w I would suggest as I probably included a while back (but perhaps I didn't) try a good quality 10w-50 s y n t h e t i c. This is only what I think will suit you and the car, others may think differently. I hope I have laboured the point enough (or as we over here might say "laid it on with a trowel") of a good quality synthetic for you.
  15. My thoughts on the £108 as I live in England and once took a car to Birmingham for repair. Proper MAP sensor looks to be about £35 (if I saw the correct one, could be more, could be less), then there is the labour (and overhead and running costs) diagnosis and find fault, replace part, other checks and tests for battery. Better value to have someone trustworthy and reliable and do the job well and proper (and at short notice) than someone on the cheap that usually turns out later to be expensive to sort or put right. It would cost more in labour to clean and repair the loose pins and then perhaps find it still plays up after fitting or worse still after mikefelicia This is the UK not elsewhere, land and houses are usually very much overvalued so a good percentage of income is used on them and most people pay their taxes including business (some very reluctantly) to keep the society running despite its present state. Marshall Skoda Dealership is a labour rate of £95 per hour. - https://www.marshall.co.uk/skoda/service/fixed-priced-servicing
  16. Your English is great. I could well be wrong but "mains" I think means main bearings. Trying to hammer home the point again, it is the Total Quartz 15w-50 mineral oil that is disappointing you, the oil as a whole, and no doubt its 15w grade will be contributing but a different and (proper) synthetic 15w oil may give slightly different results. Google tells me there are 400 different types of oranges, they are all oranges but they vary. There is one multigrade of oil that I would try given all you and Thefeliciahacker have put as you both own and run the cars in Greece but there was and is no point me suggesting it until you have tried alternatives to judge against as, like my wife, you are a person that needs "to see it with their own eyes to believe it". Even then it might, as all the others, and like everything about a car, have compromises. There is no need for it but you might be better using different multigrades for summer and winter. When summer and winter starts and finishes weather and temperature wise I would have no idea, it's all mixed up in England now. Perhaps the oil will fair better with the highways and mountain roads test particularly if you can drive in a spirited way on the mountains.
  17. Yeap, Sod's Law usually applies and it's rarely sunny or better still as you pull in to a pub car park. But that happened to me with my 1973 Midget about seven years ago. End of a nice few days runaround of Wales with friends in their Toyota Supra. We were going for a light lunch and then part ways, A bit before we arrive there was a slight misfire so I said to the boss we'd have lunch and worry about it after. Sod's Law it was the rotor arm needed a brush up and I'd decided the dissy didn't need attention at the recent service I'd done. Same cars but in France a number of years earlier and jump leads were out because the ultra reliable Supra (still is at 25+ years old) wouldn't start but who'd believe it was the Midget jump starting the Supra and not the other way round. My mate blamed the Italian battery fitted to the car when he bought it and very begrudgingly had to buy a high priced mediocre battery at the end of that day as we had to get the leads out again at the start of the car display and run. He had to leave the engine running after going round a few times as we sat at a pavement table having lunch and then me and others going round the town, car sat running for a couple of hours in about mid twenty's heat with only the occasional blip of the accelerator, it didn't miss a beat or get warm. If it'd been the Midget I'd have just found a slight slope to park it on and switched it off.
  18. Scan tools can do that sometimes but more often it's a diagnostic tool and needs correct interpretation as with any other form of diagnosis so you are lucky to have a good mechanic. Even then the basics that have always applied need to be covered as they always have. The scanner can often point in the right direction or sometimes tell you nothing or lead a poor mechanic in the wrong direction. Cars are ancient technology with more and more electronics on them to eek out as much as possibly from the same basic systems, and of course adding another layer of complexity and things to go wrong. 😄 Look at your Triumph as having given you 49 years of pleasure from it and perhaps consider passing it on to someone else to get pleasure from it and perhaps ride it. A friend of mine (75) had three bikes including one old and one more modern Triumph (I know nothing of motorbikes) sold all the bikes, and three of his cars, because of health issues. A previous neighbour of mine only got a car, well a small Thames van, when he was 50 before that he had motorbikes then with sidecar when the kids came along, IIRC one of his was a BSA Golden Flash, he thought it was fantastic when I brought him back a postcard with drawing of the bike I saw in a car museum somewhere as he had no photos of it.
  19. There's full and proper servicing of the whole car and there's Dealership engine oil & filter change and "free visual health check", have you got a full past servicing history to see what's been done and when and what might have tardy and/or missed. Usually better to get any tuning done after the car is fully sorted as it is, first make sure the brakes, steering, suspension (all include tyres) are good and any driving or safety electrics. Other way to increase power to weight is to lighten the car - so throw those golf clubs out. 😄 (I imagined you as being younger than 50. 😄) You'll do as you think but you've had a lot of good advice in your threads. Good luck.
  20. See previous posts. Yeap, I get the same search results. - Mann W 712/43 Model type 1.3 Engine code 136 B/M, AMH ccm 1289 kW 50 HP 68 Year of manufacture 10/94 → 08/01 https://catalog.mann-filter.com/EU/eng/vehicle/MANN-FILTER Katalog Europa/Vehicles/CARS %2B TRANSPORTERS/SKODA/Felicia/1.3 136 B~M, AMH (T00000000330313)
  21. Not all but rarer to find honest figures, most run ego gauges to get more work and give the customers what they crave, telling the truth upsets many customers and they go off to those that will tell them what they want to hear. Most only want highest power figures rather than real world usable torque - and anyway less power can be more rewarding but modern cars are so big and heavy and all the electronic assistance make the driver more remote from the drive. But it's horses for courses (or as many horses as you can get). 😊
  22. In that case forget any expensive cosmetics and perhaps mapping for now instead check or carry out a full and proper service of the car and drive it to get used to what you like and don't like about it, I'd give it 6-12 months - plus you might need the money for other stuff on the car. Think about improving parts and components as the existing tire or failure. Not all improvements are improvements and some can make matters worse. We've all been there, eager to go through the catalogue of improvements yo find some , or all, don't satisfy. Unfortunately it's often easier to learn by our own mistakes than by the mistakes others tell us about but those could save us lots of time, trouble and money I went out of the thousands of pounds of improvements and "improvement" many years back. Good luck.
  23. Don't worry - you'll mix up and forget more as you get older, something to look forward to. 😊
  24. Try never to get near this stage as then the battery is far too low and could have caused other issues and warning on your VW start/stop car, not to mention it won't be doing the battery any good - prevention is better than cure. My advise is as much as you can when required fully charge the battery in your circumstances then you will better better and extended life out of your existing battery and its replacement. Good luck.
  25. My wife's 2015 90 hatch factory suspension isn't great and not very long lasting and it very, very rarely gets anything close to spirited driving. Very unpopular view I know but best tuning is driver training, and it's transferable to other cars (and I've had a very little and still am not a good driver), then timely full servicing, maintenance and repairs and good quality appropriate tyres. Cosmetics is just personal taste and fashion (like the oversized wheels and tyres from the factory let alone upsized later) for fashion remember the three spoke alloy wheels. Put on whatever cosmetics please you, probably best if they're legal, and if you later want to sell the car if they'll be appreciated by those you want to sell to, or accept you've had the enjoyment of them and suck up any loss from them (or perhaps you might gain if you chose to suit the sales potential). Just having a fully cleaned and polished car, fully inside and out, usually looks very good and perhaps good contrasting colours (currently fashionable or not). Don't spend all your money and have none left for timely full servicing, maintenance and repairs, German engineering quality ain't what it used be last century, or Mk1 Fabia or Mk2 Fabia from what I've read here. Mostly, enjoy your car the way you want. 👍
