Everything posted by SkOmk4
Headlight condinsation - anyone else getting it?
That is poor-engineering... I know it's COMMON - the manufacturers are covering the incompetence and design-flaws with "normal behavior" mentioned in the user/owner manual. It was NOT common a decade ago, two decades ago... and with plenty of other cars I drove in similar or worse conditions.
😡 It's getting worse with worse conditions... Today on a longer drive I had about 30 minutes of rain changing from drizzle to torrential (summer-like) rain, on an express way - so pretty high speeds, in temperatures just above 0 Celsius (1 to 3). You can see the outcome in the pictures below... It's the worst condensation I've seen so far in any of the cars I drove (there's been quite a few) on even bitter weather. Thank God I forgot to check the fog lights!!! 🤣
Connections problems
I searched and searched through the Service Manuals and couldn't find the piece of info I need (it's not really on-topic, but it's not that far...) I'm trying to figure out which of the unused positions in the fuse panel have permanent voltage and which are ACC (supplied on contact). I'm planning to install a power-supply hardware kit for a dash-cam and it needs both connections.
Basic led headlights signal bulb replacement
I suppose you already saw the Service Manual instructions for the turn-signal bulb replacement. The official procedure is indeed a nightmare - one has to remove the front bumper, to extract the headlight in order to replace the light bulb. Have a look at the last screenshot - maybe it helps you understand how the bulb socket is fitted. Good luck! (I hope you'll solve it without removing the front bumper!)
Octavia iV, 2020, front 'heated' screen?
There are no wires to be seen on close inspection, simply because the heated windscreen for Octavia (and not only) uses a foil - metallic coating. All you should be able to see is a colored reflection when looking at the car from outside, in the proper light. The reflection is clearly different compared to the side windows, don't really know how to describe it; it is slightly blue-violet-ish - have a look at the picture. Another way to check for heated windscreen is to look for a lighter rectangular-patch on the dark areas left and right of the rear-view mirror. For heated windscreens those two patches are missing the metallic layer to avoid attenuation of electromagnetic waves - checkout the 2nd picture.
Euro NCAP crash test on YouTube
As I was saying yesterday, I'm not impressed (or I'm negatively impressed), simply because the rating of the very same car shouldn't go down. I'd really like to know what's hidden behind this retesting in such a short time. For those not familiar with EuroNcap: it's not often al all to test the same model more than once per generation. In most cases, not even the facelift isn't tested.
I had a very unpleasant surprise the other day, while I was discussing car-safety with a friend and revisited the EuroNcap webpage. It looks like Octavia 4 was retested quite recently (crah-test results uploaded this month) and it managed to score less than the first series of tests back in 2019. It's not a huge difference, but I usually prefer that the safety goes up, not down during the production span of a certain model - I'm expecting the producer to find & eliminate flaws while statistics & feedback is coming from the released cars. If I correctly read the description of the two tests (2019 && 2022), the newer model is missing the Side Pelvis Airbag for the front seats that were fitted to the 2019 tested model. All in all, the car scored less on all chapters, with a minor increase in "Safety Assist" which I personally think is mostly marketing BS... Why am I paying attention to those numbers and believe that any percent counts for the occupants and the pedestrians? Because the only major crash I had was fatal for my previous car and the two passengers inside didn't feel that great for a while... It was also a 5 star EuroNcap with 86% score for the front passengers. Therefore the 92% score of the 2019 Octavia was an important factor in choosing my next car after the accident, when I placed the order back in 2021. The question is: the Octavia delivered to me in Nov.2022 is it a 92% or an 86%? One might say "it's marginal difference, so why do you care?"; 'cause that marginal difference might be the difference between one broken rib and several broken ribs (or worse)... Simply compare the crash-test dummies diagrams for the adult occupants between the two tests, and you'll see what I mean. 2019: https://www.euroncap.com/en/results/skoda/octavia/39136 2022: https://www.euroncap.com/en/results/skoda/octavia/47756
Wow, that looks impressive; badly impressive, not in a good way. Is the condensation frozen too? I'm suggesting a new standard feature for the LED headlights: heated front sides of the headlights.
Remotely Lock & Unlock Doors Using MySkoda App
I clearly remember needing two keys - that was for the configuration of the Primary User in the car. Indeed, if you are happy with being defined as Guest you don't need both keys. The dealership had to confirm/validate me on some Skoda server - so that my account on Skoda App would be allowed to remotely control the car (lock, unlock etc.). Without that validation you basically have some sort of "read-only" rights - you can see the status, but can't change anything.
Left and right headlights on mine... (ignore the dirt on the car - it was a really ****ty weather) It's the first car (in many I've driven on bad/rainy weather) that has this kind of condensation inside. Was condensation the only reason for replacement? Because that would be a very interesting precedent! However, I'm afraid the humidity that gets inside, doesn't get there via some mechanical defects (such as cracks or faulty seals), but through the ventilation holes at the back of the headlights. If that is indeed the case, I imagine the replacement is not helping, unless the design of the headlight is changed.
Mk4 VRS Manual box - Clutch slipping at 18 months old with 19k miles. Skoda saying they won’t help
TBH, I don't know how to answer to that... I can only hope you didn't get the point I was making.
Agreed, so why do I have a limited warranty on my DSG? Oh, in case you missed the info, mine is a DGS also - it's mentioned in the signature. Is Skoda assuming that UK DSG drivers are better skilled than Romanian ones? (just kidding on a sad fact...)
So if I correctly understand those terms, the DSG clutch (pressure plate and center disks) is covered for the full warranty offered with the car, both years and mileage??? 😲 As I mentioned, mine is covered for maximum 1 year or 30.000 km - whatever limit is first reached... 3rd world countries - always get less advantages compared to civilized ones...
👍 Not sure about that error though... maybe it's trying to retrieve older settings that are not available. You've also had a SW version change - that might also be a cause (you mentioned the system was offline continuously since before the upgrade). Did you try to configure users? You can easily do that following the step-by-step guide in the phone App. You'll need both keys with you to register as Primary User. If the "settings could not be loaded" error persists, it is probably worth trying a Factory Reset - that way you'll start with a clean slate.
I see. If the dealer already worked on updating from 1806 to 1896, I'm assuming they already discovered the Online Services issues, so probably the fuse 19 trick will not work. But you might as well try it, since there's nothing to be affected by it, and it's also quite easy to do.
No, certainly unplugging and plugging such a fuse will not void any warranty. It was discussed here on different topics that removing fuse #19 for minutes helped resetting the online services of the car. After the registration on the App on your phone - are you able to see the car in the App? If yes, does it say it is Activated or Not? Did you manage to register as Primary User in the car? Or the malfunctioning of the Online Services of the car didn't allow you to follow all those steps?
- Mk4 VRS Manual box - Clutch slipping at 18 months old with 19k miles. Skoda saying they won’t help
I was really shocked to see how short the warranty for the clutch is for the mk4. My Warranty Certificate says "1 year, no more than 30.000 km" for the clutch - which I find ridiculous... Imagine someone has a clutch issue after more than 1 year, but after only 1.000 km (not too likely, but possible) What's the clutch warranty for a TSI VRS?- Fuel gauge slow to move from full
Nothing too fancy, just check my signature - both owned from new... plus about a dozen rental cars, various brands, from small to compact cars. - tire noise is now sorted: it's the factory Goodyear set that is too noisy, my winter set sounds great&quiet (I wrote on the other topic); - brake pedal noise on release - there are a few others mentioning it on another topic here;- Fuel gauge slow to move from full
Sure, it's not worrying me at all, but I'm slightly bothered by the noise. It's simple physics - smart engineers would have found simple solutions, it's not really reinventing the wheel. It seems my expectations were too high for this car... factory tire noise, brake pedal noise, fuel tank noise - all less obvious on my previous cars.- Fuel gauge slow to move from full
Hmm... that's strange! Different tank shape/layout? What's the engine on your car?- Fuel gauge slow to move from full
Besides the fuel level staying at Max for longer than expected (which is almost the "new norm" in automotive as you mentioned), is anyone else around here bothered by the noise made by the fuel smashing against the tank top or walls? It's occurring when the tank is almost full, and it's most obvious at slow speed maneuvers, e.g. braking for a speed-bump, forward-reverse while parking etc. I've heard it before in other cars, but in Octavia 4 it seems to be the loudest.- Winter wheels
To be honest, I didn't expect such a big noise difference, even after your post... ...but the time came to compare my winter set with the factory one. Huge difference between the silence of the Bridgestone Blizzak LM005 Extraload (on 16" rims) and the noise/resonance of the Goodyear Efficient Grip (on 17"). They're the same width, I used the same pressure (~2.6) but there's no comparison between the noise level. It's the first time I was able to hear some faint aerodynamic noise at high speed (either from the A-pillar or from the side mirrors - not sure); with the summer set it was covered by the tire noise. Finally, the car sounds fairly well soundproofed; I was quite disappointed with the summer tires, which means that (at least for me) the Goodyear's are rubbish and I'm looking forward to replacing them.- Brake pedal feel - 1.5 manual
Hmm... it's a good thing I searched the Forum, because I was starting to worry. The noise of the brake pedal (when releasing a bit faster) is a feature also on the 2.0 TDI DSG - just as @MCG1975 was mentioning for his manual. On the other hand I have no complains about the feel of the pedal - I'm quite happy with the long travel of the pedal. The noise however, was a bit worrying the first few times I heard it.- Climate controls - settings saved?
Don't get me wrong guys, I'm on Auto for 99% of the time while driving cars that have automatic climate control. It's just that I'm used to being informed by the system what's on/off and when... in this case A/C on or off. - Mk4 VRS Manual box - Clutch slipping at 18 months old with 19k miles. Skoda saying they won’t help
