Everything posted by SkOmk4
Mirror Dip Function
The way I see it, if there's no memory function for the mirrors the "Mirror Dip" function will not work properly - see the requirements in the description of the App. That's why the mirror goes all the way down in your case - since it can't store the preferred position that you define. I don't quite remember, but I surely read somewhere on the forum that you need to have electric&memory seats in order to have Mirror Dip work properly.
Delivery times?
Hmm... did your company order Octavia IV? Because the delivery estimates for those went up recently, have a look in the link below at Skoda cars: https://www.marnet-mobility.de/aktuelle-lieferzeiten.html Those are (almost) real-time adjusting delivery estimates for VAG cars in DE, and the delivery for plug-in Octavia changed to Q1/2023 in the past month. Before the end of last year, they were still showing 9-10 months or so... Indeed, deliveries look a bit like lottery - there were recent deliveries in Bulgaria and Greece ordered in October and September (if I remember correctly) and there are orders since March & April still waiting in UK, France, Germany. It's almost impossible to establish a pattern or East-West EU discrepancies... @KBizzle - same here: I keep fooling myself that the software will be (almost) bug-less. But I'm afraid that's something I'm dreaming only to justify the wait. I ordered a TDI in August, so I'll keep waiting for quite a while.
Kessy Go and Start Stop problems
Hmm, I wouldn't worry too much about that... My 14 years-old Megane is smart-enough to cut the power after several minutes (10 or 15, don't remember exactly), even if I'm inside the car with radio on for example. So I'm assuming that Oct.mk4 (that has more computing power than the first mission to the Moon) is able to prevent accidental battery drain. On the other hand, seeing how many software faults were reported here... it makes you wonder how did they make the IT team for the mk4?!?! 🧐
Delivery times?
They're trying to convince us to give up diesel engines, without canceling the Orders from their side... 🤔 I still don't have any info (no build estimation) - ordered 2nd half of August.
Dash cam
Have a look at this topic, you might find an answer:
Auto Hold Not Releasing
Did you contact the dealership? According to @Skodamias there was a software fix for this problem. His car is a 2021, yours being a 2020 I'm guessing it has an older software.
OCTAVIA NX front grill
Looks like @J.R. is right - have a look at this post about the front grill of the MK3: If you have the patience to read all the posts there, it seems that most agree that the entire front bumper needs to be removed to safely "unclip" the frame of the grill.
Turning auto door lock off
AutoLock On/Off can be added to the car's menu - it's now possible via 1-click App in Obd-eleven. I would never turn it off, but since you were concerned about it...
Delivery times?
Yes and no... When I agreed to give up the rear-view cam and the park-assist, the dealer sent me an Addendum to the Contract with a price reduction - corresponding to the two options that were removed.
Delivery times?
Agreed, I didn't invoke the reasons; only the consequences...
Delivery times?
Personally, I think it's related to the changes they made in the option-list for each trim level. When I ordered mine, which is a Style trim, the rear-view camera was on the option list, and I had it added as part of the Clever-Pack. This is no longer available as an option for Style, at least on the local Skoda car Configurator or at the dealer. Now obviously, keeping the option will directly impact the course of the car down the production line newly reconfigured for 2022 models. For instance they will have to produce a Style with the electrical wiring of a higher model. Sure, that's not hard to do, but they prefer to keep things simple for cost reductions (profit maximization).
KPH/MPH
Wow!!! 9 months? What did they have to do? What about the car warranty - do they extend it somehow? You lost about 1/4 of it with the car being at the dealer.
Changing parts on a new car
This light one comes with 0 costs in RO (and other markets), optional to the black interior - depending on the trim level you choose.
vRS Octavia iV - Range, Motorway Driving
Sorry, I fail to really understand this question. Once you're on the motorway at constant cruising speed a car is not using all the engine power (be it IC or EV). Unless you're on the German Autobahn (on a limitless section) "cruising" flat out at the upper speed limit of you car, fighting the air resistance. Just think about it: two different engines (but the same shape and masses - let's say Octavia mk4) doing 130km/h on the same highway, same conditions (wind, slope etc), one having 100hp and the other 245hp - they will need the same amount of power to keep that speed constant. And that power is far below those 100hp, I'm guessing somewhere around 25hp. Now if you ask that IC engine (using the hybrid control system) to also charge the battery while cruising at the same constant speed, it will add several HP to do that and this will probably increase the consumption by about 1-2 liters/100km (or decrease the mileage equivalently). Ideally you would want to always have some juice left in the batteries, just to be able to use all the combined power (IC+EC) when you need it.
Spare Wheel
Imagine that for the same car you topically have 2 wheel sizes specified; 16&17, 17&18 or 18&19 - depending on the model. That means there will be a negligible speed difference between those two. The spare wheel is not intended as a long-term use - it is meant to take you to the nearest tire service in order to repair your flat... So there's no problem with that. e.g.: My 14 years Megane 2 was delivered with 4 16" alloys (205 wide tires) and the spare is a 16" steel (195 wide tire). My GT arrived with 4 18" alloys (225 wide) and the spare is a 17" steel rim (145 wide 😒) limited to 80km/h...
Reversing camera retro fit?
Sure, thanks for the heads up! I'm already decided to go for an OBDeleven Pro, but I'll have to find a proper step-by-step tutorial to correctly code the camera. There's no rush, since my car has no production week specified yet...
Yep, most of the kits I found online have those cables included. The two pictures below are from an online offer of OEM kit which is about 400 Euro here in RO - without installation costs. However, the Chinese alternatives are a lot cheaper, also with cables included, e.g. this one: https://www.aliexpress.com/item/1005003500261883.html?spm=a2g0s.8937460.0.0.52a12e0eFv2g5I I doubt the picture quality will be a lot poorer that the OEM one, since plenty of people were complaining about the original camera...
Can you tell us how complicated it was in terms of wiring? I'm curios what was the factory setup - if there were any existing wires from the dashboard to the back of the car. Or did the retrofit procedure involved new wires from the back to the front of the car? I've seen a tutorial online for VAG rear-view camera retrofit (not an Octavia MK4) and there were 3 main wires to connect: - power supply connected to a fuse-box into the left-side-wall of the trunk; - CAN BUS connection under the back seats; - signal cable from the camera all the way to the MMI controller. All those cables were part of the camera kit and had to be installed during the retrofit.
Delivery times?
They're only doing that to bother "the greens" in Germany... 😉 And in a couple of years those German diesels will arrive in south-eastern Europe as second-hand cars, once the westerns will dramatically restrict diesel engines. Those who are from this part of the continent know what I mean.
Can high beam assist be retro fitted to my 2021 Octavia SEL with front camera?
That would mean it's also possible to be coded? (OBDeleven or VCSD...) Same as for the "cornering lights" and the "traffic sign recognition"? As long as the hardware is there, it's just a matter of enabling/disabling those functions.
Delivery times?
It was a similar situation for me in Bucharest - you can see the details on the previous page of this topic. Long story short, they wanted to know if I would give up the park-assist (had it before, never used) and the rear-view camera (I'd like to have, but it's not a must). The time estimates were ambiguous, but with a quite clear difference: - if I remove the 2 options, the car will be delivered within the initial estimates of the Contract (35-45 weeks starting August), most likely well before the deadline; - if I keep the options they will not be able to specify any delivery estimate, even beyond 45 weeks. I decided that if I won't be able to live without the camera, I'll retrofit it using the money they gave back from the initial Contract. For instance: I wouldn't have given up the Matrix-LED, or the ACC... you should decide based on what's really important for you.
2.0TDI Octy mk3 Winter Wheels on 1.5 TSI Octy mk4?
Right, from the speed point of view the difference is about 3% between the 2 tyre dimensions, which is covered by the speedometer error anyway, so that's not the main concern. Two main reasons not to use the unlisted tyre dimension: - routine checks (authorities may not be too happy with that); - insurance companies; I've heard more than one situation when they refused to cover the expenses following an accident, invoking the technical nonconformity of the car - since the tyres/rims were not those specified in the car's certificate. So personally, I wouldn't use those for the long run, maybe just as a temporary solution over a short time&distance.
Hello skoda octavi 4 Coding List and Adaption
I think mods like SS changed to "last setting", or driving mode changed to "last setting" are just a matter of time. Let's not forget SFD was locked for OBDelleven until few days ago. Also, it's a bit confusing for some people (me included) the fact that OBD11 tweaks can now be found on no less than 3 separate topics on this mk4 forum. Those could be easily merged... @TheUltraRunner on a different forum, of my other car, we used to call the start-stop "the second button to push inside the car", first one being the engine start button. And yes, it used to be a dedicated physical button, no need to boot-up a computer for that... 🤕
Delivery times?
@Zhivkov00 Hello neighbor (same region of Europe), really interesting news from you! I thought the sales/delivery policy was similar in our countries... but no! I was called recently (last week) by the dealer to give up the rear-view camera in order to have the car built in the next few months. To be clear: not sooner, but sometime next year... They underlined that the Factory message was clear: keeping park-assist and rear-view camera on the car, will delay the production beyond the initial delivery time-window. Even the western-markets are now lacking the optional rear-view mirror. But it's standard on vRS if I understood corectly, so that might explain why you don't have to remove it... Anyway, fingers crossed - hope you get your vRS soon!
Sorry, not sure what to answer to that, I'd hate to give a wrong advice. I'll have to wait several more months before I can test the procedure on my own Octavia. Try surfing the web for a step-by-step guide, or pop the question on the other OBD11 topic, where they already played with mods.
