Everything posted by NottsIan
Karoq cam belt change - start saving now !
I suspect you may be right, either that or VAG will come clean and change the recommended replacement period
Seems from anecdotal evidence as though VAG have fitted an improved cambelt to these engines which in theory has an extended lifetime. They therefore decided that there was no need for a simple cambelt change mechanism as it is no longer a periodic requirement. There's obviously still a potential need for a cambelt to be removed and changed when other work may be required on the engine. In the factory, when they build engines, they set the cambelt timing electronically so decided that a similar system could be used for the 'once in a blue moon' case where it needed to be done in the dealer network. Of course, the test kit to do this is expensive, its not a problem in manufacturing, they're doing hundreds of engines and its economic. Of course, the franchised dealers are now forced/obliged to have this expensive kit which, in theory, is hardly ever used. The dealers dont like this, so decide (with the manufacturer approval in some regions?) to continue to advise that cambelt changes are necessary and thus make a suitable return on their investment in the test kit. or am I just getting sceptical in my old ageπ
Why make a process so complicated when with a little thought they could have made it impossible! Looks like they've made it difficult to lock the camshafts and therefore it needs electronically checking and adjusting when the belt has been replaced
as if they would π I just think they are using the fact that it has ACT technology to attempt to rip off the customer for what is in effect no different to a normal cambelt change.
I'll buy the possible extra stress requiring the change but I don't understand any extra labour. It's still just a DOHC engine as far as the cambelt change. You just need to lock both camshafts and crank in position and change the belt and tensioner. Where does the ACT affect this procedure ? https://www.vwgenuineparts.co.uk/vw_act_active_cylinder_technology_explained.shtml
Problem with selecting Driving Modes, other than Normal.
I think the theory is that, when trying to maintain a constant speed. on level or slightly downhill, the car decerates much slower with the clutches disengaged. So the small amount of fuel used in idle is less than would be used by constant throttle on off. That's the theory anyway...
I believe MY21 DSG vehicles onwards 'coast' in NORMAL mode as well. Mine certainly does...
Telephone
I was sure this had been asked before and it wasnt possible, certainly the manual doesnt say it is. However, apparently it looks like it SHOULD be possible to accept using the rh rotating button
- Telephone
Door locking / unlocking problem with door handles
or the car battery not fully charged due to lack of use/short trips. To reduce emissions, charging systems these days do not charge at maximum rate, rather they target something like 80% state of charge for the battery and reduce alternator output accordingly. If used for short trips then the battery may not achieve full charge and the vehicle shuts down some systems like start/stop and keyless entry to conserve the battery. I used to have a Ford focus which regularly disabled keyless entry, only after a good long run would the battery be fully charged and keyless start working again. I dont know for sure but I would guess that the Skoda (and other VAG vehicles) system is very similar
dsg 7 dry
The DQ200 is designed for applications up to 250Nm torque. That's probably a conservative limit but 340Nm sounds a bit much to ask of it ! edit : roottoot beat me to it
dsg 7 dry
In the dry clutch dsg box, the clutch is separate from the gearbox (similar to a normal manual gearbox) so any particles due to clutch wear don't mix with the gearbox oil. As with a manual gearbox there's no requirement to change gearbox oil. In the wet clutch version, the clutch is in the same oil and so needs changing at regular intervals to ensure that any contamination from clutch wear doesnt cause gearbox wear.
Mystery fastening
Nor here. None of my cars ever came with one as standard. I had to buy one a few years ago when I took my car to the Netherlands (via France & Belgium), I've transferred it to every car sinceπ
Mystery fastening
keyfob battery failing with *no* warning
I think the later keys ( MY2021 on) were slightly different and take a CR2032. Mine (Oct 21) certainly came fitted with a CR2032 and IIRC is marked inside as requiring a CR2032
Satnav ...again
TBH I find that a right pain, is there any way to get the nav to go straight to maps ? Although, for any real trips I've given up on the Skoda Nav and use google maps via Android auto. I found the builtin nav unreliable and took some weird routes
Replace key battery message
Mine is a KESSY key! and as I said the inside of the cover speciifes CR2032. The CR2032 certainly isnt a tight fit in my key
Having opened the key on my MY21 ( Sep 21 build ) , it has a CR2032 battery and the inside of the cover is marked as CR2032. Seems like the later keys were designed for 2032. Hopefully the increased capacity of the 2032 means they may last a bit longer ...
Driving on the left France etc
Doesn't climate control do that automatically if the outside temp is high ?
The Camera Parking System Is Currently Unavailable - Karoq Sportline 1.5 (2020)
Yes, I've had this occur once
AFAIK all that travel mode does is to cutoff the 'uptick' to the left on a rhd vehicle on the dipped headlights. So the lights present a flat beam.
Have you checked the digital manual for your vehicle on the Skoda connect portal. That should be the exact manual for your vehicle. Mine ( a MY21 SEL ) certainly has ( according to the manual ) a 'Travel mode' setting for the lights
Wiper noise
I lasted a,whole two weeks before I replaced mine with Bosch onesπ
Keyless entry
Your keys have motion sensors which disable the key if its not moved for a while. So when the key is stationery in your house the method of 'reading' your key and relaying to the car won't work.
Brake lights staying on in stop/start
You've likely got Auto Hold enabled. This automatically holds the brakes on when you stop.
